Re: [bolger] Epoxy as dangerous goods
Daniel Pike wrote:
> Hello:
> 1. How do you get precipitate out of epoxy. I guess mine got a bit
> too cold. I remember reading that you should heat it up, but how hot
> do you have to get it?
> 2. Does anyone know the "dangerous goods" status of epoxy? Can it be
> sent on a plane or taken in your luggage? By mail?
Put the epoxy in a pan of water and heat the water up until it is clear. I had to do this a
lot in Nome.
I get epoxy through the mail all the time. If I were to carry it my luggage , my principal
worry would be the protection of the containers. No fun getting a broken container in your
luggage and having it run into someone else's luggage.
_ _ _ _ _
% Harrywelshman@...
>How do you get precipitate out of epoxy?
According to the system 3 resin I have, all you have to do is heat slowly to
above 125F for a little while. I had a small bottle crystalize on me, stored in
the garage in California over the winter, and I just put it in a pan of hot
water until it went clear on me, and it seems to be perfectly OK. I've used it
a couple of times since, worked fine.
I would suggest, however, that you check with the manufacturer of the epoxy that
you have. Never know, might be differences in this area.
Good luck,
Glen
"Daniel Pike" <dan.pike@...> on 06/13/2000 12:25:25 AM
Please respond tobolger@egroups.com
Sent by: "Daniel Pike" <dan.pike@...>
To:bolger@egroups.com
cc: (Glen Gibson/HQ/3Com)
Subject: [bolger] Epoxy as dangerous goods
Hello:
We had a lot of snow this winter (about 8 m, with over 2 m on the
ground), and when it finally melted enough for me to see my beloved
glas-kevlar canoe about 2 weeks ago, it was crushed flat! When I
shovelled the snow off, it popped back up, but the sides are creased
and severely weakened.
So, I am doing repairs now, and have a couple of questions about
epoxy that I'd be greatful if someone could answer:
Thanks in advance,
Daniel Pike,
Tromso, Norway.
Would you like to save big on your phone bill -- and keep on saving
more each month? Join beMANY! Our huge buying group gives you Long Distance
rates which fall monthly, plus an extra $60 in FREE calls!
http://click.egroups.com/1/2567/10/_/3457/_/960881133/
Posting rules:
- please stay on topic
- add your comments at the top and sign your name
- check for "content" before sending: please take "thanks" and "me too!" posts
off-list.
Not very hot. I've warmed epoxy by putting the container in a basin or
bucket of hot water. The precipitate, or crystallized resin will slowly
melt back to liquid -- you may have to change the water as it cools. MAS
epoxy folks recommended putting it in the microwave oven for short (10
second?) bursts, but I never had the nerve to try it.
For the "dangerous goods" status, try phoning an airline or post office.
Good luck,
Jamie Orr
Sent: Tuesday, June 13, 2000 12:25 AM
Hello:
Thanks in advance,
Daniel Pike,
Tromso, Norway.
Posting rules:
posts off-list.
