Re: Box keel
Batteries make great ballast but aren't you risking a
short circuit by having them in the bilge if you ship
too much water.
cheers
andrew airey
ps
Happy Christmas everybody
___________________________________________________________
All New Yahoo! Mail Tired of Vi@gr@! come-ons? Let our SpamGuard protect you.http://uk.docs.yahoo.com/nowyoucan.html
too much water.
cheers
andrew airey
ps
I have made a lot of tanks over the years at a number
of shops I have work at. The ones that I will not
forget were four tanks all about 22 inchs wide 14
inches tall and 12 feet long with no baffles!
I had got two of them done and then was told the owner
had changed his mind and wanted baffles put in every 2
feet. Talk about tanks from hell! I'm glad I was only
155 lbs at the time but I was still 6 feet tall. I
know there was a whole lot of cursing going on while I
was putting in the baffles.
Oh the boss had me cut out the ends so I could slide
inside the tank to install the baffles on the ones
already made.
Blessings all
Kristine
--- Christopher Wetherill <wetherillc@...>
Do You Yahoo!?
http://mail.yahoo.com
already made.
Blessings all
Kristine
> If I remember my stability lessons correctly, the__________________________________________________
> effect of free
> surface in a tank is a function of breadth to the
> third power and
> length to the first. It is, therefore advantageous
> to orient a large
> tank longitudinally. This makes a tank in a box
> keelquite feasible.
Do You Yahoo!?
One factor I haven't yet seen mentioned is the behaviour at speed on a
power sharpie. The box keel modification to the design for Sneakeasy
was intended to lessen the tendency of the hull to trip on its chine
when turning.
V/R
Chris
when turning.
V/R
Chris
--- Inbolger@yahoogroups.com, "Glenn" <devinetemptations@...> wrote:
> What are the benefits if any of putting a box keel on the Watervan, I
> notice that some designs have them and others don't, there is a
> modified Idaho design here in Australia called the Mundoo, one boat
> called the Nomad has a box keel that holds the battery banks and
> electric motors, my question: is there any other benefits to having a
> box keel.
> Glenn
If I remember my stability lessons correctly, the effect of free
surface in a tank is a function of breadth to the third power and
length to the first. It is, therefore advantageous to orient a large
tank longitudinally. This makes a tank in a box keelquite feasible.
> The half full tank souldn't be any proublem if it's
> baffled. Also with the normal take is it a proublem? A
> tank is a tank. Unless they are real long!
My sweetie and I are talking about building a Fiddler
II and adding a box keel to it. She and I both agree
it needs to be about 5 feet inside and 5-6 would be
great! Four feet is just a bit to short even for her!
My old van was 4-6 inside and it was do-able.
And the way things are looking we may be moving down
in the area of Portland Or. She wants to be closer to
her family. So who knows what's going to happen.
Blessings Krissie
--- Bryant Owen <mariner@...> wrote:
Do You Yahoo!?
Blessings Krissie
> Having spent some time on a Steve Guterman's__________________________________________________
> Watervan at the Kingston
> Messabout (seehttp://tinyurl.com/ybdt68) what you
> notice most is how
> the box keel allows extra headroom when moving fore
> and aft in the
> boat. As you can see in the next shot Watervan at
> rest or under bare
> headway is down a bit at the bow. And I'm not sure
> how a half filled
> belly tank would effect the move to
> planing/deplaning. Just me .02
> Bryant
Do You Yahoo!?
Having spent some time on a Steve Guterman's Watervan at the Kingston
Messabout (seehttp://tinyurl.com/ybdt68) what you notice most is how
the box keel allows extra headroom when moving fore and aft in the
boat. As you can see in the next shot Watervan at rest or under bare
headway is down a bit at the bow. And I'm not sure how a half filled
belly tank would effect the move to planing/deplaning. Just me .02
Bryant
Bryant
> I look a photo of the Watervan side view drawing and
> blew it up to 1 inch to the foot and the box keel
> comes out to 6 inches. So it would be a bit short to
> put batteries in.
> But it would work for a belly tank for fuel.
> Blessings all Krissie
> --- Bruce Hallman <bruce@...> wrote:
> > > Thanks for the feedback, It does look like a good
> > position for
> > > batteries etc.
> > > Glenn
> > Perhaps under the aft bed, but the box keel looks to
> > be only 5 or 6
> > inches deep on Watervan.
> Do You Yahoo!?
put batteries in.
Do You Yahoo!?
put batteries in.
> > Thanks for the feedback, It does look like a good__________________________________________________
> position for
> > batteries etc.
> > Glenn
> be only 5 or 6
Do You Yahoo!?
> Thanks for the feedback, It does look like a good position forPerhaps under the aft bed, but the box keel looks to be only 5 or 6
> batteries etc.
> Glenn
It can also make standing headroom possible. Clyde
> It also changes the waterplane loading at rest. So the[Non-text portions of this message have been removed]
> boat has less of a bow down look to it as in the
> Watervan. It also brakes a wave impact so it's not one
> big WOMP. It also helps to stiffen the bottom of the
> hull as well. It does a number of things all for the
> betterment of the hull I think.
> Blessings Krissie
> --- Bruce Hallman <bruce@...<mailto:bruce%40hallman.org>> wrote:
> > On 12/18/06, Glenn
> > on the Watervan,
> > The main reason Watervan has a box keel is to
> > facilitate planing.
> > When at speed, the hull rises up and efficiently
> > planes on the bottom
> > surface of the 'box keel'.
> Do You Yahoo!?
>http://mail.yahoo.com<http://mail.yahoo.com>
batteries etc.
Glenn
batteries etc.
Glenn
Blessings Krissie
Do You Yahoo!?
Blessings Krissie
> On 12/18/06, Glenn__________________________________________________
> on the Watervan,
> facilitate planing.
Do You Yahoo!?
On 12/18/06, Glenn <devinetemptations@...> wrote:
When at speed, the hull rises up and efficiently planes on the bottom
>The main reason Watervan has a box keel is to facilitate planing.
box keel.
Glenn
box keel.
Glenn
