Re: Pointy Skiff
Thanks...
--- Inbolger@yahoogroups.com, "KEVIN A. DONOHUE" <kadonohue@...>
> circled number 5
> From: rmsuchy1<mailto:rmsuchy1@...>
> To:bolger@yahoogroups.com<mailto:bolger@yahoogroups.com>
> Sent: Friday, October 05, 2007 8:17 PM
> Subject: [bolger] Pointy Skiff
> How do I locate the number 2 and 3 bulkheads? I have looked and
looked
> for a measurement, and have yet to see one.
circled number 5
How do I locate the number 2 and 3 bulkheads? I have looked and looked
2' and 5', the hash marks are 1 foot apart each, hence 8 spaces on an 8' sheet of plywood.
It states "for'd" and "after" face of frame at 2 and 5 feet.
it is a very pretty boat, I would add a skeg for better tracking.
The last part sounds like a good idea 7/16 is not a
lot for nails or screws to get a hold of. I would say
bead it and then glass it as well. At this point what
is going to look nicer??
Blessings Krissie
> Hi,
> I over looked adding 1/4" to the bottem measurements
> cut out for a
> Pointy Skiff.
> Due to this, I am ending up with a 7/16" external
> chine instead of a
> 3/4" one.
> Should I add an internal chine between bulkheads or
> glass the external
> chines (as directed) and bead the internal chine
> with epoxy?
> Thanks
The fish are biting.
Get more visitors on your site using Yahoo! Search Marketing.
http://searchmarketing.yahoo.com/arp/sponsoredsearch_v2.php
use glass tape set in epoxy putty on the inside in lieu of an interior
chine. Keep the 7/16ths on the outside. You should be set for a long
time. My Pointy Skiff (made of luan and framing lumber) is now 18
years old and used every summer.
Mind you, there is a fair amount of patching and repairing on the
rotted sections each year. I think the transom is almost 100% glass at
this point! June Bug may be the summer project to replace both Diablo
and Pointy as the Birdwatcher develops slowly.
Happy building.
david jost
On 2/8/07, sloppytypist <kadonohue@...> wrote:
> Due to this, I am ending up with a 7/16" external chine instead of a
> 3/4" one.
7/16th shouldn't be a problem at all.
Not needed.
> or glass the external chines (as directed)
I would put fiberglass tape and epoxy on the external chines.
If the plans call for fiberglass cloth and epoxy on the external chine, do it.
> and bead the internal chine with epoxy?
A good idea, mostly to keep dirt from accumulating in that crack.
Some fiberglass cloth tape and epoxy on the inside of the chine would
be really nice, but probably not critically important.
Hi,
I over looked adding 1/4" to the bottem measurements cut out for a
Pointy Skiff.
3/4" one.
Should I add an internal chine between bulkheads or glass the external
chines (as directed) and bead the internal chine with epoxy?
Thanks
