Re: Shortened June Bug
--- Inbolger@yahoogroups.com, "Bruce Hector" <bruce_hector@...>
I'd guess you will find the shorter boat easier to row, particularly
with a bit of a load.....less surface area....The longer boat would
be slightly faster, but at normal cruising speeds, the shorter boat
will be noticably easier.
It will probably be slightly less initially stable.....just not quite
as much of the flat bottom area to sit on. As you add an additional
person the overall stability will reduce just a little more....
(lighter total boat weight, with two people with higher CG's ), with
the shorter boat....not so much as to be very obvious in service, but
less nonetheless, (is that a pun??).
With your particular needs relative to your girl friend I'd probably
build the bigger boat, but in almost any other case I'd go with a 12-
14 foot rowing boat.
I'd be interrested following your choice and the results.
JG
>Hi Bruce,
JG
> Any thoughts on how an 11/12th. shortening of a June Bug to 14 foot6
> inches would work out? I'd simply lay her out on 11 inch stationsof
> instead of 12s.
> Would I lose much in speed as I gained a bit in stability?
> At that legth she'd be a tad lighter and easier to slip in and out
> my short box pick up.amout
> My girlfriend has advanced Multiple Sclerosis and we need all the
> stability we can get. I've managed to get her in and out of Twisted
> Seagull a few times, but it was a close run thing. TS has a great
> of side flare and loves to toss the crew out next to the dock. Ifshe
> were tossed, there's no way I could get her back in the boat.
> Bruce Hector
> 2007 Kingston Messabout, September 7,8 & 9.
> Rideau Acres Campground
> Kingston, Ontario, Canada
> > I'll shorten a Surf (Crab Skiff) 15'6"X 3'7" by building on 11 inchBolger design 287, Surf (Crab Skiff) really is a cool boat. I just
> > stations and the width will be perfect as she'll end up at 14 and be
> > wider.
> > Plus that clipper bow stem looks so cool!
> > Thanks.
> > Bruce
modeled it in Freeship, (because I was concerned that shortening the
station spacing would change the 'rake' of the side panels).. I
checked this and found that 11 inch stations does change the rake, but
only a small amount, about the width of a sawkerf.
Beware that Surf (which has a pointy stern) 4 inches, is quite a bit
different than Junebug, which has a wide transom, 24 inches.
Concerning stability, width and pointy ends are a 'trade off'.
Predicting the stability is anybody's guess, but I suspect that they
are about equal.
picture here:
http://hallman.org/bolger/287/surf.png
freeship file here:
http://hallman.org/bolger/287/surf.fbm
How about a quick and dirty Pickup Squared by Jim M.. It's already 45"
wide and 11' long. Outside chines glued up with PLP, polytarp sail,
etc. Should come together with stolen hours between now and September.
Then build something else fancier if you like.
Bryant
Bryant
--- Inbolger@yahoogroups.com, "Bruce Hector" <bruce_hector@...> wrote:
> You're right, I should have checked.
> wider.
> Thanks.
> Bruce
Bruce, why would shortening JB increase stability? If
the beam remains the same won't stability decrease as
you reduce the length, and thus volume, of the boat?
Anyway, I think either length June Bug would have
great intitial stability.
--- Bruce Hector <bruce_hector@...> wrote:
Looking for earth-friendly autos?
Browse Top Cars by "Green Rating" at Yahoo! Autos' Green Center.
http://autos.yahoo.com/green_center/
> Any thoughts on how an 11/12th. shortening of a June____________________________________________________________________________________
> Bug to 14 foot 6
> inch stations
> instead of 12s.
> stability?
> slip in and out of
> need all the
> out of Twisted
> TS has a great amout
> the dock. If she
> the boat.
> Bruce Hector
wider.
Thanks.
Bruce
wider.
Thanks.
Bruce
On 3/5/07, Bruce Hector <bruce_hector@...> wrote:
Yes, it sure looks like the maximum possible stability due to the wide
flat bottom.
If you wanted to increase that stability, I suppose stability could be
increased by upping width from the existing 3' - 3 1/2".
http://hallman.org/bolger/Junebug/
>I am pretty sure that June Bug, as original, is 14 feet long.
> Any thoughts on how an 11/12th. shortening of a June Bug to 14 foot 6
> instead of 12s.
flat bottom.
instead of 12s.
At that legth she'd be a tad lighter and easier to slip in and out of
Seagull a few times, but it was a close run thing. TS has a great amout
of side flare and loves to toss the crew out next to the dock. If she
Bruce Hector
instead of 12s.
Bruce Hector
