Re: [bolger] quick build row sail
Basic rule--the quickest boat to build is the one with the fewest pieces. Generally, this is a flat bottomed boat made out of plywood. For two people, a boat in the 15 to 16 ft range using 4 sheets of plywood is a pretty good choice. PCB and Jim Michalak offer several plans for boats that fit into this category and they all work reasonably well as row/sail boats for two in sheltered water and mild to moderate wind. V-bottom/multi-chine/round bottom boats will probably be faster, more seaworthy, and more commodious than a flat bottomed boat. However, such boats have a lot more pieces and take a lot longer to build.
You can spend a lot of time agonizing about the 'best' boat to build. My suggestion is to make a quick decision and build the boat of your choice as quickly and cheaply as possible. As you gain experience, you can become more sophisticated in your choice of a second boat. But sophistication is based on experience and you don't get experience until you start!
JohnT
Sent: Sunday, April 01, 2007 11:40 PM
Subject: [bolger] quick build row sail
Is "gypsy" a good choice for a row sail for two people and a quick or easy build? I need a boat asap.
Thanks much
Checked by AVG Free Edition.
Version: 7.1.413 / Virus Database: 268.18.18/734 - Release Date: 3/26/2007
Gypsy isn't really a two person boat. How about June Bug, quicker build
and friendlier to two people. See the Zieger's link for construction and
use with more than one person.
http://www.akzeigers.com/JB.html
> Thanks much
Build a Brick! Cheap, quick and easy to build.
************************************** See what's free athttp://www.aol.com
Thanks much
