Re: teleflex steering
Not a bad idea, Mike. The cable isn't the free-to-float style - it
goes through the motor tilt tube. That and the beam of the boat and
the radius is pretty much fixed.
The cable exits the sheath as a shaft that enters a tube fixed to its
own end fitting - that tube slides inside the motor tile tube. In
addition to being a tight bend, most of the problem appears to be rust
between the two.
/jammed
motor tube /
---|--------------------------------|-- actuator, covered with tube?
motor tube
I had a look at some bass boats with some Seastar hydraulics - nice,
but about $500-600. I think the morse cable *must* come out
regardless; and mechanic told me - "oh yeah, motor *must* come off to
get cable out!"
Gregg
--- Inbolger@yahoogroups.com, <mkriley@...> wrote:
> this sounds like a improper installation.
> the cable has to be free to float and not fastened down and it
needs a large radius for a bend, if it takes a lot of force it is
installed wrong.
> there is a plastic inner sheath and a metal inner cable that will
cut if in a tight bend.
> Fasten the cable with oversize cable clampdowns and rotate the cable
so the inner one is bearing on a new spot
> mike
the cable has to be free to float and not fastened down and it needs a large radius for a bend, if it takes a lot of force it is installed wrong.
there is a plastic inner sheath and a metal inner cable that will cut if in a tight bend.
Fasten the cable with oversize cable clampdowns and rotate the cable so the inner one is bearing on a new spot
mike
