Re: [bolger] Re: The Fastest Rig
http://picasaweb.google.com/shnarg/FaamuSami
<snip>
Any photos of your boat?
avast! Antivirus: Outbound message clean.
Virus Database (VPS): 000736-2, 04/26/2007
Tested on: 4/29/2007 4:01:07 PM
avast! - copyright (c) 1988-2007 ALWIL Software.
http://www.avast.com
<snip>
--- Inbolger@yahoogroups.com, "Carl" <shnarg@...> wrote:
gear at the thwart. Doubles the downwind speed and is easily struck
by un-nesting at the thwart.
to a place suitable for a proper reefing. I keep a pennant flying on
the peak of the sail so that I can prevent flogging on the rare
occasions that you resort to this method. The pennant can be an
attractive addition to your boat.
I believe Peter Lenihan ended up installing a second sprit boom on his
sprit-rigged Elver. Not sure if he put in some reef points.
One could perhaps just drop the upper sprit altogether and let the
peak of the sail fold down in a storm tri-sail shape in a bad blow.
Elver had the advantage of small jib and mizzen to help keep things
balanced.
>the clew of the sail and a thwart,using a boat cushion for chafing
> When I go on a run I do what the old timers did, prop an oar between
> Again refering to ancient practice, they are hard to reef, but aneffective emergency reef is to knock out the sprit. and sail the boat
>Sounds great Carl.
balanced.
When I go on a run I do what the old timers did, prop an oar between the clew of the sail and a thwart,using a boat cushion for chafing gear at the thwart. Doubles the downwind speed and is easily struck by un-nesting at the thwart.
Again refering to ancient practice, they are hard to reef, but an effective emergency reef is to knock out the sprit. and sail the boat to a place suitable for a proper reefing. I keep a pennant flying on the peak of the sail so that I can prevent flogging on the rare occasions that you resort to this method. The pennant can be an attractive addition to your boat.
<snip>For example a sprit sail has no easy way to reef it. In the larger
sizes that sprit becomes quite a handful and it is a loose footed sail
which can bag out when going off the wind.
It's advantages are that the spars are short and can store well in a
small boat. Also it carries a fair amount of it's area up high in
clear air and the head or upper luff has no spar infront of it to
affect the air flow. That is - if the sprit is peaked up higher than
the mast.
Bolger explains that much better than I.
avast! Antivirus: Inbound message clean.
Tested on: 4/29/2007 2:53:57 PM
Tested on: 4/29/2007 3:12:54 PM
the mast.
One of the reasons I bought my Epson 1650 was the friendly driver software that came with it. (and there's still several functions I don't use)
I can scan, format and post the issues for you, or you can scan them (at least 300 dpi) and send them to me and I'll take it from there. Tutoring at the remote is tough, even if you have the identical set-up. Too much of my operation is "Let's try this. Oops! Well then we'll try this" It used to send my wife screaming since she feared the computer gods would exact revenge, (but I knew where their power switch was.)
It is a great article and I'd like to see the additional material. Unfortunately, I don't have the color copy.
Sent: Sunday, April 29, 2007 3:06 PM
Subject: Re: [bolger] Re: The Fastest Rig
I have both WB issues. The first is a 14 page article by Palmer with color photographs and colored bar graphs. It includes the results of the posted linked article as well as additional sea tests and wind tunnel tests, with results for gunter, dipping lug and crab claw sails in addition to the bermudian, sprit and lateen rigs. The results don't lend themselves to simple summary. The second consists of letters to the editor on the topic and an extended response by Palmer.
I have a cheapo reconditioned Lexmark color scanner/printer/copier/fax with the factory software, including OCR. While it fully functional, the fundamentals of figuring out where to store a file, how to retrieve it, how to format it, etc., etc. ... ..,. to how to post it to whatever is the appropriate Bolger list is beyond my ken.
If someone is willing to try to tutor me on-line and off-list, I'll give it a shot. (I'm a dinosauar - my WB collection starts with #20.
Ciao for NIao,
Bill in MN
Jim Kessler <jkess777@...> wrote:
--- Inbolger@yahoogroups.com, "The Peillet-Long Family"
<owlnmole@...> wrote:
> Not for the first time, I have stumbled across some interesting
info
> for boatbuilders which springs from research done in support of
> working sail in the developing world.
> This article -- uploaded to the Files section -- describes a test
by
> Colin Palmer of Gifford Technology of equal-area bermudan, gaff,
> sprit and lateen rigs on identical catamaran hulls with surprising
> results.
> <http://groups.yahoo.com/group/bolger/files/Fastest%20Rig/>
> Sorry, I can't find the source of this article, I found it when
doing
> a Google image search for something else and was in a hurry. I did
> find two references to the author in the Woodenboat online index:
> --Palmer, Colin, author, illustrator and photographer: "Sail and
Hull
> Performance," 92:76
> --Palmer, Colin, author, illustrator and photographer: letter on
rig
> and hull performance, 94:6
> If anyone hase these old magazine and wouldn't mind scanning the
> pages to share, that would be great.
> For that matter, if anyone knows how to reach Colin Palmer (I
believe
> he is active in the British sailing community) and knows how to to
> contact him, or has leads on any more of the his or related work,
> please do share that as well.
> Cheers,
> Matthew
That was very interesting. Thanks for posting it.
Jim
Ahhh...imagining that irresistible "new car" smell?
Check outnew cars at Yahoo! Autos.
beyond my ken.
Great to hear you are still alive and have not gone extinct after all:-)
My son has one of those Lexmarks and it works great, but I am afraid I
am not a very good tutor as he lives quite a ways away.
I would be interested in how the dipping lug and crab claw fared. Also
I figure when anyone is considering a sail option they should be
familar with Bolger's "103 Small Boat Rigs."
the mast.
beyond my ken.
>Hi Bill,
> Ciao for NIao,
> Bill in MN
the mast.
Ciao for NIao,
Bill in MN
Jim
Ciao for NIao,
Bill in MN
>info
> for boatbuilders which springs from research done in support ofby
> Colin Palmer of Gifford Technology of equal-area bermudan, gaff,doing
> results.
> a Google image search for something else and was in a hurry. I didHull
> Performance," 92:76rig
> and hull performance, 94:6believe
> he is active in the British sailing community) and knows how to toThat was very interesting. Thanks for posting it.
> Cheers,
> Matthew
Jim
Jim
>info
> results.
> Cheers,
> Matthew
Jim
Thanks, I updated the entry in the Files section.
--- Inbolger@yahoogroups.com, "derbyrm" <derbyrm@...> wrote:
> Whoever scanned the article cut off the credits, but it appeared in Yachting Monthly for July
1984.
> Roger
> derbyrm@...
http://groups.yahoo.com/group/bolger4photos/
Yachting World - July,1984
> If anyone hase these old magazine and wouldn't mind scanning theThere are scans in the files section here:
Whoever scanned the article cut off the credits, but it appeared in Yachting Monthly for July 1984.
Sent: Sunday, April 29, 2007 8:56 AM
Subject: [bolger] The Fastest Rig
Not for the first time, I have stumbled across some interesting info
This article -- uploaded to the Files section -- describes a test by
results.
Sorry, I can't find the source of this article, I found it when doing
--Palmer, Colin, author, illustrator and photographer: "Sail and Hull
Performance," 92:76
--Palmer, Colin, author, illustrator and photographer: letter on rig
For that matter, if anyone knows how to reach Colin Palmer (I believe
Matthew
results.
Performance," 92:76
Matthew
results.
Performance," 92:76
Matthew
