Re: Three River Launched!
Always liked K/W - especially the food. My daughter graduated from WLU.
Any thoughts about the Kingston Messabout in September?
Bryant- north of Peterborough
--- Inbolger@yahoogroups.com, "bh100014" <ben.ho@...> wrote:
> Thanks!
> Launched at the Conestogo Lake in Ontario. It's a small lake where
> we have a sailing club. That's where my boat(s) reside.
> Ben
> --- Inbolger@yahoogroups.com, "Bryant Owen" <mariner@> wrote:
> > Terrific job. Where did you launch?
> > Bryant
> > --- Inbolger@yahoogroups.com, "bh100014" <ben.ho@> wrote:
> > > The Chebcaao Three Rivers was launched last Sunday with much
> > > fanfare, under a beautiful sky with a moderate breeze. The local
> > > newspaper even sent a crew out to report on the story (building
> a 20
> > > footer in ones' garage, in landlocked Waterloo is newsworthy!).
> > > Everything went quite well. I was relieved that the trailer
> > > launching & recovery was fairly straight forward, as the boat
> ramp
> > > at our sailing club has a very shallow gradient limited by the
> shore
> > > line. I've posted some pictures on the Photos file under Ben's
> Three
> > > Rivers. Some points of interest:
> > > - I put the boat & trailer through the landfill weigh scale. It
> > > comes up to about 2200 lb. The trailer is a heavy duty one,
> > > including the spare tire is around 700 lb, so the boat weighs
> 1500
> > > lb. This seems about right, as I added 250 lb of
> battery/ballast,
> > > plus a heavy-duty cabin roof.
> > > - With a cross wind of about 5 knots, the boat takes a
> surprising
> > > amount of effort to hold on to at the bow/stern lines. My
> reference
> > > is my 17 ft Marsh Hen, which has a fairly high side for its
> length,
> > > and the Hen takes much less effort. I've mostly single handed
> the
> > > Hen for launch/sail/recover, and assumed I can do the same with
> the
> > > Chebacco; now I am not too sure...
> > > - The wind died (that was when the sailing photo was taken), and
> we
> > > puttered around with the electric motor, sometimes with a full
> load
> > > of spectators. I like the motor! Nice and quiet, just turn the
> > > handle and it goes. The rudder is pleasantly responsive with a
> very
> > > tight turning radius. (Does it begin to sound like a sport car?)
> > > - After a while the wind picked back up to 10 kts. She sailed
> well
> > > in this wind, and is extremely stable (again with my 17 ft Hen
> as
> > > reference). Response is slower than the Hen, which can be
> expected
> > > given two times the weight. Very sure-footed, comes about with
> no
> > > hesitation. At this wind there's a slight weather helm, just
> about
> > > right.
> > > - The mizzen doesn't seem to do much, but I think I have much to
> > > learn yet about trimming the mizzen.
> > > - The raising/lower of the gaff takes more effort than I
> thought.
> > > Also, the gaff jaw rubs hard against the mast such that several
> > > spots were stripped bare of varnish, even though the jaw is
> covered
> > > with leather. I think I need to sheath the mast section with a
> piece
> > > of SS sheet. Does anyone else have this problem??
> > > - A hundred other small things need to be worked on, such as
> where
> > > to hang the fenders so they don't destroy the rub rail....but
> > > overall I am quite happy so far.
> > > Cheers
> > > Ben
Thanks!
Ben
> Bryant
a 20
ramp
shore
Three
1500
battery/ballast,
surprising
reference
length,
we
load
very
well
as
expected
no
about
> > right.
thought.
covered
piece
where
> > Cheers
> > Ben
Bruce wrote "...Q: Recently I experienced an occasion where I could not get
her to run downwind. What might have caused this?"
Intriguing. What actually happened? The boat wouldn't turn downwind from a
reach or would not make any progress downwind?What point of sail were you
on, how were the sails set? &c.Tides / currents? Sea state?
I celebrate your success! Congratulations.
I too am learning the tricks of sailing a cat yawl, after decades of
sailing a sloop.
Trimming a mizzen is all about 'helm balance'. Sheet it tight when
you want to point up, and loose otherwise. This means quickly
sheeting tight and unsheeting during a tack.
> - The raising/lower of the gaff takes more effort than I thought.
Me too. I ended up double parting my gaff throat halyard because of
this. I also double parted the topping lifts.
I decided, if I were to 'do over', my gaff jaws could and should have
been built wider open.
( I have a cat yawl question of my own...someone might answer...)
Q: Recently I experienced an occasion where I could not get her to run
Bryant
> newspaper even sent a crew out to report on the story (building a 20
> launching & recovery was fairly straight forward, as the boat ramp
> at our sailing club has a very shallow gradient limited by the shore
> line. I've posted some pictures on the Photos file under Ben's Three
> including the spare tire is around 700 lb, so the boat weighs 1500
> lb. This seems about right, as I added 250 lb of battery/ballast,
> - With a cross wind of about 5 knots, the boat takes a surprising
> amount of effort to hold on to at the bow/stern lines. My reference
> is my 17 ft Marsh Hen, which has a fairly high side for its length,
> and the Hen takes much less effort. I've mostly single handed the
> Hen for launch/sail/recover, and assumed I can do the same with the
> - The wind died (that was when the sailing photo was taken), and we
> puttered around with the electric motor, sometimes with a full load
> handle and it goes. The rudder is pleasantly responsive with a very
> - After a while the wind picked back up to 10 kts. She sailed well
> in this wind, and is extremely stable (again with my 17 ft Hen as
> reference). Response is slower than the Hen, which can be expected
> given two times the weight. Very sure-footed, comes about with no
> hesitation. At this wind there's a slight weather helm, just about
> right.
> spots were stripped bare of varnish, even though the jaw is covered
> with leather. I think I need to sheath the mast section with a piece
> - A hundred other small things need to be worked on, such as where
> Cheers
> Ben
Ben,
Looks like you did a beautiful job. Chebacco is a shapely boat, and
you have really maximized that asset with your paint job. Now begins
the task of Keeping It looking that beautiful <G>
David Graybeal
Portland, OR
"Order is the shape upon which beauty depends" -- Pearl S. Buck
> right.
> Cheers
> Ben
Congratulatons Ben! Beautiful boat. Wishing you many years of
enjoyment ahead.
Fairwinds and smooth seas!
Dennis Lancaster
Old Shoe building in Bellingham, WA
20
shore
Three
> right.
piece
> Cheers
> Ben
right.
Cheers
Ben
