Re: Strip building materials
JG
Will keep my eyes open for heavier strip plank stock. Will there be
a big change in the bevel required? what style hull are you
designing? round bilges obviously, but how tight. if it gets real
tight near the bow you may have an easier time planeing the bevel
than routing.
Dan
http://dansdories.googlepages.com
--- Inbolger@yahoogroups.com, "gilberj55" <gilberj55@...> wrote:
> Hi Danial,
> Thanks for the reply. I have looked ot your site and really like
your
> developed dories. As you say those boats use a pretty much
constant
> radius on the bilge and a constant bevel will work quite well. The
> shape I am working on is a little more complex and I'd have to
change
> the bevel over the length at least in the area of the turn of the
> bilge. Whether its worth milling all the wood (cove and bead) or
just
> beveling as required,first on the table saw and then adjusting the
> bevel by hand, I,ll have to consider.
> its early in the project here. I still have to finish the design.
> JG
> --- Inbolger@yahoogroups.com, "danoyes1" <danoyes1@> wrote:
> > Hi there JG
> > what size and shape are you looking to strip?
> > Kyak, fishing schooner, or somewhere in between?
> > I strip plank the Ipswich Bay 18' (photos section) class knock-
> about
> > and have no use for the cove and bead, I also don't need to
plane
> > individual strips as the design has a constant radius chine,
just
> > run the strips through the table saw set at a predetermined
angle
> > and I'm done.
> > Daniel
> > --- Inbolger@yahoogroups.com, "gilberj55" <gilberj55@> wrote:
> > > Thanks to all.
> > > I know I can do the machining myself but am considering
> > alternatives,
> > > if available at a reasonable price.
> > > JG
> > > --- Inbolger@yahoogroups.com, Kristine Bennett <femmpaws@>
> > > > Jeff I have not seen anything like that I know they
> > > > make bits for doing that. I'll look around to see if I
> > > > can find the bits.
> > > > Blessings Krissie
> > > > --- gilberj55 <gilberj55@> wrote:
> > > > > I have been considering a project which may strip
> > > > > built. I am looking
> > > > > for sources of boat building wood pre-machined into
> > > > > strips (with cove
> > > > > and bead). So far I have only found sources of
> > > > > strips for canoe/kayak
> > > > > (1/4 inch) construction. I would be looking for
> > > > > minimum 1/2 inch thick
> > > > > up to 3/4 inch, the difference being taken up with
> > > > > more or less framing.
> > > > > The cost may be prohibitive.
> > > > > Anyone know of sources????
> > > > > JG
_____________________________________________________________________
> > _
> > > ______________You snooze, you lose. Get messages ASAP with
> > AutoCheck
> > > > in the all-new Yahoo! Mail Beta.
http://advision.webevents.yahoo.com/mailbeta/newmail_html.html
Hi Danial,
Thanks for the reply. I have looked ot your site and really like your
developed dories. As you say those boats use a pretty much constant
shape I am working on is a little more complex and I'd have to change
bilge. Whether its worth milling all the wood (cove and bead) or just
JG
--- Inbolger@yahoogroups.com, "danoyes1" <danoyes1@...> wrote:
> Hi there JG
about
> and have no use for the cove and bead, I also don't need to plane
> individual strips as the design has a constant radius chine, just
> run the strips through the table saw set at a predetermined angle
> and I'm done.
> Daniel
> > Thanks to all.
> alternatives,
> > JG
> > > can find the bits.
> > > Blessings Krissie
> > > > built. I am looking
> > > > strips (with cove
> > > > JG
> _
> AutoCheck
Hi there JG
I strip plank the Ipswich Bay 18' (photos section) class knock-about
and I'm done.
Daniel
> Thanks to all.
alternatives,
> JG
> > can find the bits.
> > Blessings Krissie
> > > built. I am looking
> > > strips (with cove
> > > JG
_
AutoCheck
Thanks to all.
I know I can do the machining myself but am considering alternatives,
JG
> can find the bits.
> Blessings Krissie
> > built. I am looking
> > strips (with cove
> > JG
______________You snooze, you lose. Get messages ASAP with AutoCheck
can find the bits.
Blessings Krissie
> built. I am looking
> strips (with cove
> JG
____________________________________________________________________________________You snooze, you lose. Get messages ASAP with AutoCheck
I built a 16 ft strip canoe. Cut the strips myself on a table saw & bought a set of cove & bead router bits & set up 2 router tables. Took a while but all came out fine. Boat looks great. Only problem was it took me for ever to get the 2 different bits set to exactly the same height. when your working with only 1/4 " just a 64th is a huge error.
Dave
gilberj55 <gilberj55@...> wrote: I have been considering a project which may strip built. I am looking
for sources of boat building wood pre-machined into strips (with cove
and bead). So far I have only found sources of strips for canoe/kayak
(1/4 inch) construction. I would be looking for minimum 1/2 inch thick
up to 3/4 inch, the difference being taken up with more or less framing.
JG
Now that's room service! Choose from over 150,000 hotels
in 45,000 destinations on Yahoo! Travel to find your fit.
It would be my guess that to buy the tools to make your owen or barrow
the tools and just buy the bead and cove bits would be cheaper then
buying and shipping costs.
Tools needed are a table saw with a long extention on the back and
feather boards to keep wood lined up. Router with table and extentions
both ends and feathering boards to keep feed tight. One beed and one
cove bit.
You could be set up for under $500 if you bought everything and used
scrap wood for the extentions and feathering boards. To go first class
could easly cost $1500 with a spendy sawtable, shaper and cutting bits
to start your owen bead and cove busness. Any good wood working book on
use of woodworking tools can show you how simple it is to do.
Jon
thick
framing.
> JG
JG
