Re: [bolger] Re: Gluing MDO?
The only gotcha I found was that, when scarfing, the overlay won't feather out. A hooked scarf (blunt ends) would solve the problem, but I just used filler on the 3/4" stuff I was using.
Sent: Saturday, June 23, 2007 12:58 PM
Subject: [bolger] Re: Gluing MDO?
Treat it like any other plywood. Running a belt or ROS with 36 grit
will let you know if there is any small flaw under the overlay (it
wont sand) if both sides are exposed in the style of construction.
With the top grades it is not needed but alwas a good idea anyway. The MDO will glue just fine without it.
Jon
--- Inbolger@yahoogroups.com, David Ryan <david@...> wrote:
> FBBB,
> An MDO question, probably answered a million times:
> Any special requirements when glueing up MDO instant boat style?
> Leave the paper alone? Rough up the paper? Grind down to bare wood?
> YIBB,
> David
With the top grades it is not need but alwas a good idea anyway. The
Jon
Jon
> FBBB,
> YIBB,
> David
FBBB,
