Re: Birdwatcher 2 construction page
Nels,
You have a good eye for details.
glass, the inner coaming was added to give a little more stiffness. We
decided to apply the coaming in 2 thinner layers, added the second
layer after the sides were attached. Took a bit of filing and scarph
in place to fit the nothches. The inner coaming is Philipine Mahogany
and was too hard to bend otherwise.
I guess once the inner coamings fit into their notches
fantastic job drawing it as it actually fits. Once lined up, a few
temporary screws and glue and fillet. Easy as long as there are 2
people working at aligning and holding in place.
adds more epoxy to bury the cloth, self levels pretty well. Not
perfect but better than if we had waited until it was upright. Less
epoxy wasted dripping down.
Chine logs. We used 2 layers of 3/4 by 2 1/2 and 3/4 by 1 and
something with the angles precut. We put them on one at a time. Shaped
the top with a 1 inch roundover bit, belt sander and hand block. They
came out pretty well.
http://www.raptornails.com/
The nails hold very well, don't have the shear strength of metal
nails, but they don't damage planes/saw blades and can be sanded. We
screwed the first layer of the bottom and used mostly the polymer
nails with a few screws on the second layer, glass right over them.
They are good to tack scarphs so they don't slip before you get a
clamp on them.
wrapped very well around the chine logs. Got one other coat of epoxy
on, now we have to wait until our next epoxy shipment arrives. Have
used 3 1/2 gallons to this point with very little waste. Have never
used more than a gallon on any boat we have built in the past.
Have a happy and a safe July 4th to all.
R & K
> I see you completely glassed the side panels and installed the inner24 and a half feet of 6 mm plywood is very flimsy, even with the
> coamings and stems before temporarily attaching them to the bulkheads.
> Then attaching the stems to the other panel permanently. Then
> filleting and taping the bulkheads to the side panels and removing the
> temporary screws? Any problems getting the panels to bend into place
> and line up?
> and the marking lines on the inside of the panels lined up with theWe set up the frames and marked the panels as Phil drew them. He did a
> bulkheads you were all set to bond it all together. The advantage of
> having the bulkheads stabilized and aligned beforehand.
> Also all the glassing was done on a horizontal table.You don't get runs when its flat, squeegee the glass and then a roller
> Was it a bit of a challenge getting those chine logs into place? Wouldproblem?
> maybe using two courses of thinner logs have been easier or not a
>You can find the polymer nails and gun at :
> I am also interested in your using polymer nails. Do you have a
> special nailer to drive them? Did you also use them to hold the second
> bottom layer in place while it cured?
clamp on them.
> All the best with glassing the bottom. Once that is done the hull isFirst of 2 layers of 10 oz cloth has been applied to the bottom,
> locked in!
R & K
--- Inbolger@yahoogroups.com, "Rex and Kathie Payne" <rkpayne96@...>
you are making excellent progress.
I have a few observations and questions, but don't let me interfere
with the work in progress. Maybe some time later once you get the
build completed.
and line up? I guess once the inner coamings fit into their notches
maybe using two courses of thinner logs have been easier or not a problem?
locked in!
> You don't know how lucky I am that Kathie is letting me help her buildI checked in at your website and viewed the updated photos. Looks like
> the BW2. We make good progress together. Glassing the bottom tomorrow.
> R & K
build completed.
locked in!
Memphis, Indiana and Nashville, NC, been through the first, not the last.
I believe the Lake Monroe Messabout is Autumnal Equinox weekend. We
haven't missed showing up at least on Saturday for the last 6 or 7 years.
Thanks for pointing out the photos of Bob Larkins BW2 at the Oregon
Messabout. The jaws on the Solent lug yard appear to work well. Looks
good.
R & K
good.
R & K
> Is not the Lake Monroe Messabout in September some time?
> Funny but I was wearing a T-shirt with s Nashville North logo on it
> yesterday, but I think that it was from a bar in Nashville NC:-)
> Hope you noticed the photos of the BW2 of Bob Larkin in the messabout
> photos - very inspiring! Looks like he has that rig sorted out now,
> with the yard laying nicely against the mast as he boogied past.
> Rex I think it is great to see a husband helping his wife build a boat
> like you are doing.
> Cheers, Nels
like you are doing.
Cheers, Nels
> We have launched there in the past. I'm sure we will again in the
> future. Usually at the Cutright ramp, no wake zone side. Canoes and
> small sailboats.
> R & K
like you are doing.
Cheers, Nels
small sailboats.
R & K
small sailboats.
R & K
--- Inbolger@yahoogroups.com, "cosermann" <arielmiller@...> wrote:
> Maybe we can look forward to seeing this boat on Lake Monroe then?
> Regards,
> Eric
> --- Inbolger@yahoogroups.com, "Rex and Kathie Payne" <rkpayne96@>
> wrote:
> > Nels,
> > We are located just outside of Nashville, Indiana, that is
> > approximately 3 miles from little else.
Eric
Eric
> Nels,
Hey, don't knock it. You're only 70 miles from the great city of Memphis, IN.
Sent: Wednesday, June 27, 2007 11:13 PM
Subject: [bolger] Re: Birdwatcher 2 construction page
Nels,
Recent Activity
a.. 7New Members
b.. 26New Photos
c.. 1New Files
Visit Your Group
SPONSORED LINKS
a.. Bolger center
b.. Bolger
c.. Phil bolger
Health Zone
Look your best!
Groups to help you
look & feel great.
Yahoo! Finance
It's Now Personal
Guides, news,
advice & more.
HDTV Support
on Yahoo! Groups
Help with Samsung
HDTVs and devices
can never have enough clamps.
Paul H.
>My dad, who taught me everything I know about wood working, told me you
> Nels,
> approximately 3 miles from little else. Clamps are sort of a personal
> tool, they look great in photos, don't complain often, and do their
> work without leaving holes that need filling later. Should you come by
> and need a clamp and can return it by next day, we will be happy to
> oblige. Look forward to your acquaintence.
> R & K
Paul H.
Nels,
R & K
R & K
> wrote:
> > My wife and I have started construction on a Birdwatcher 2.
> > Progress can be viewed at :
> >http://homepage.mac.com/rkpayneboats/Birdwatcher2
> > Rex and Kathie
> Thanks to you both for sharing the great photos of your build. I
> really found the setting up of the building table and the bulkhead
> support molds to be interesting and worthy of emulating.
> Just wondering where you are located - in case I need to borrow some
> clamps;-)
> Nels
clamps;-)
> Rex and Kathie
clamps;-)
Rex and Kathie
Rex and Kathie
