Re: Digest Number 3736
--- Inbolger@yahoogroups.com, "Jon & Wanda(Tink)" <windyjon@...>
> I personaly feal that the incert but joint showen woulkd have a weak
> spot at each end of the incert if inpacted as well as being more
work
> then a regular scarf joint.
Hi Jon,
I totally agree with your observation regarding the "weak
spot....if impacted" but,in my defense, I would like to add that by
the time that Big Bad Boulder stikes you right at the weakest part,it
is my feeling that one may have more pressing issues at hand......:-)
spot at each end of the incert if inpacted as well as being more work
then a regular scarf joint. The second problem is they don't make
1/4" MDO for the incert. On my project I used regular butt blocks of
same ply thickness 1/2 but but went 8" wide. I instaled one sheet
then the butt block, alined the next sheet and attached at butt block
and worked down the sheet. When we had the rolling party no one could
find where they where till it was rolled they didn't show through.
Jon
--- Inbolger@yahoogroups.com, "derbyrm" <derbyrm@...> wrote:
> Your "butt-scarf" looks like a good fix for a sheet that will be
bent. If one is just looking for alignment on a flat panel, a
biscuit joiner works very well.
> Roger
> derbyrm@...
>http://home.insightbb.com/~derbyrm
> From: Peter Lenihan
> To:bolger@yahoogroups.com
> Sent: Tuesday, July 10, 2007 11:37 PM
> Subject: [bolger] Re: Digest Number 3736
> --- Inbolger@yahoogroups.com, Chris Crandall <crandall@> wrote:
> > Right now, I need to butt-join two half-inch MDO sheets. They
lay > flat on a frame, and I've alread epoxied and screwed one of the
two > sheets onto the frame. I am making a main bulkhead, and
am > worrying out how to get them to line up, without
massacring the > smooth finish of the MDO, but getting a good fit.
The length across > the two sheets is about 6-7 feet,
> Hi Chris,
> Check out this link:
http://www.duckworksmagazine.com/00/DM1999/articles/micro2/index.htm
> and scroll about half way down the article to see one possible
route
> that may interest you regarding the joining of two 1/2" MDO
panels.
> It worked well for me :-)
--- Inbolger@yahoogroups.com, Chris Crandall <crandall@...> wrote:
> Roger wrote: "of a study that says men talk just as much as women.
Ha!"
In a related study, it was found that if a small stero playing
popular music was worn by women on a mid length necklace, men would,
in addition to staring at their chests, spend just as much time
listening to them for a change!
Wearing a sensitive pedimeter on a necklace that would record actual
movements during boatbuilding operations, as opposed to time spend in
the moaning chair, doodling chair or Peter Lenihan's well worn bar
stool could be translated into a work/sloth ratio.
Bruce Hector
100/1 each time, all the time/whenever I can.
Don't miss the Great Canadian Kingston Messabout
Sept 7 and 8 2007
Kingston, ON
http://www.brucesboats.com
Your "butt-scarf" looks like a good fix for a sheet that will be bent. If one is just looking for alignment on a flat panel, a biscuit joiner works very well.
> Right now, I need to butt-join two half-inch MDO sheets. They lay > flat on a frame, and I've alread epoxied and screwed one of the two > sheets onto the frame. I am making a main bulkhead, and am > worrying out how to get them to line up, without massacring the > smooth finish of the MDO, but getting a good fit. The length across > the two sheets is about 6-7 feet,
Hi Chris,
and scroll about half way down the article to see one possible route
that may interest you regarding the joining of two 1/2" MDO panels.
Recent Activity
a.. 13New Members
b.. 7New Photos
Visit Your Group
SPONSORED LINKS
a.. Bolger center
b.. Bolger
c.. Phil bolger
Health Zone
Look your best!
Groups to help you
look & feel great.
Yahoo! Finance
It's Now Personal
Guides, news,
advice & more.
Yahoo! Groups
Real Food Group
Share recipes
and favorite meals.
If you are just trying to pull them up tight, why not
use a couple of rachetstraps to pull it tight and a
number of beveled blocks that have plastic under them
to push the ply down as you are pulling it onto place.
If you do it right the screw holes for the blocks will
be in the same place as the ones in the MDO of the
first sheet.
It's the same idea that is used to pull hull plates
into place.
Krissie
> Now the Bolger stuff:
> I wonder to what extent boatbuilding time is
> actually spent
> boatbuilding, as opposed to pondering the next move,
> etc. I cannot
> figure out the exact method for testing it, but I
> think that as much as
> half of my time is spent not moving, but thinking
> about how to get
> something done.
> sheets. They lay flat
> of the two sheets
> worrying out how to
> get them to line up, without massacring the smooth
> finish of the MDO,
> but getting a good fit. The length across the two
> sheets is about 6-7
> feet, and I have no clamps of that length, and do no
> wish to purchase
> 8-foot black pipe for this one time (although I may
> yet do it).
> Getting them to line up is critical--I'm thinking of
> doweling (I have a
> jig somewhere in the shop) or biscuit joining
> (although I'll be using
> epoxy). Otherwise, I'm going to have to screw in
> hunks of wood for
> clamps to hang on to, and screw in another board to
> make the plywood
> line up. Then fix all the screw holes.
> It's taken me a week of thinking or more, with
> little progress. More
> time spent thinking than working.
Never miss an email again!
Yahoo! Toolbar alerts you the instant new Mail arrives.
http://tools.search.yahoo.com/toolbar/features/mail/
Install a minimum of overhanging cleats on one side of the joint to align
the joint. Butter the panel edges with thickened epoxy, assemble, and screw
the second panel to the frame with just a few screws at first. Then pass a
rope loop around the work in the same direction as you would a clamp. Drive
a wedge under the rope, at one panel edge away from the joint, but not too
tightly. Then put in the rest of the frame screws. If possible, remove the
cleats and weight or force the butt joint against a flat surface, using poly
sheet to prevent sticking. Good luck.
Bill
_____
Chris Crandall
Sent: Tuesday, July 10, 2007 11:41 AM
Subject: Re: [bolger] Digest Number 3736
Roger wrote:
> The news shows lately have been reporting the results of a study that says
men talk just as much as women. Ha!
Graeme wrote:
> Crikey, next it'll be that men listen as much too!
As perhaps the world's only combination Bolger-boat-builder and social
psychologist, I cannot stay silent.
First the psychological stuff:
The author of that study, Jamie Pennebaker, is a brilliant methodologist
and an original thinker. The study was based on great methods, and I
post a snippet from Scientific American that explains it:
After working with posttraumatic stress disorder patients for years,
Pennebaker had noticed a deficiency in people's self-reporting of their
experiences. So, he devised "a measure that would capture people's real
life," he says. His device, called EAR (for electronically activated
recorder) is a digital recorder that subjects can store in a sheath
similar to a case for glasses in their purses or pockets. The EAR
samples 30 seconds of ambient noise (including conversations) every 12.5
minutes; carriers cannot tamper with recordings.
Researchers used this device to collect data on the chatter patterns of
396 university students (210 women and 186 men) at colleges in Texas,
Arizona and Mexico. They estimated the total number of words that each
volunteer spoke daily, assuming they were awake 17 of 24 hours. In most
of the samples, the average number of words spoken by men and women were
about the same. Men showed a slightly wider variability in words
uttered, and boasted both the most economical speaker (roughly 500 words
daily) and the most verbose yapping at a whopping 47,000 words a day.
But in the end, the sexes came out just about even in the daily
averages: women at 16,215 words and men at 15,669. In terms of
statistical significance, Pennebaker says, "It's not even remotely close
to different."
If you have access to the original journal article, it is one page long,
and read in about 3 minutes:
http://www.sciencem<http://www.sciencemag.org/cgi/reprint/317/5834/82.pdf>
I wonder to what extent boatbuilding time is actually spent
boatbuilding, as opposed to pondering the next move, etc. I cannot
figure out the exact method for testing it, but I think that as much as
half of my time is spent not moving, but thinking about how to get
something done.
Right now, I need to butt-join two half-inch MDO sheets. They lay flat
on a frame, and I've alread epoxied and screwed one of the two sheets
onto the frame. I am making a main bulkhead, and am worrying out how to
get them to line up, without massacring the smooth finish of the MDO,
but getting a good fit. The length across the two sheets is about 6-7
feet, and I have no clamps of that length, and do no wish to purchase
8-foot black pipe for this one time (although I may yet do it).
Getting them to line up is critical--I'm thinking of doweling (I have a
jig somewhere in the shop) or biscuit joining (although I'll be using
epoxy). Otherwise, I'm going to have to screw in hunks of wood for
clamps to hang on to, and screw in another board to make the plywood
It's taken me a week of thinking or more, with little progress. More
flat
sheets
how to
MDO,
6-7
> feet,
Hi Chris,
Roger wrote:
> The news shows lately have been reporting the results of a study that says men talk just as much as women. Ha!
to different."
something done.
