Re: [bolger] Micro triangular chines?
Glen:
This is sort of "belt and braces" approach. IMHO if you are going to glass
the inside of the chine, just leave out what PCB calls the most rot-prone
area of the boat; namely the chine log. Instead stitch and tape the joint
for a better look, and less weight.
> Will be starting hull construction on my micro within 2 weeks or so, and
have a
> thought I'd like some feedback on (yes, another loony idea from Glen).
> Am considering going with a triangular piece of wood for the chine instead
> the 3/4" x 1" specified, and then after bottom is glued/nailed on,
glassing the
> inside as well as the outside of the chine. Should add some strength, and
be
> easier to clean....
> Wadda think?
> Thanks in advance,
> Glen
> P.S. Really enjoying the list, and thanks for putting up with my
wandering
> mind.....
> Turn your EGROUP into a GROUP BUYING GROUP! Join beMANY! today.
>http://click.egroups.com/1/4124/13/_/3457/_/961783291/
> Bolger rules:
> - no cursing
> - stay on topic
> - use punctuation
> - add content: send "thanks!" and "ditto!" posts off-list.
In the plans, Bolger has given the expanded shape of the sides
only. As you know, after the chines are fitted the bottom is to be
installed (with overlap) and then trimmed to size.
Are your drafting skills up to expanding the shape of the bottom?
This would be necessary in stitch and glue.
--- Inbolger@egroups.com, glen_gibson@3... wrote:> >
> ... was to essentially
> build Micro stitch and glue, with no framing lumber on the
bulkheads...
> I'm still very seriously considering doing it this way...
> The triangular chine log was kind of a compromise....
> Glen
My origional proposal, and the one I'm still considering, was to essentially
build Micro stitch and glue, with no framing lumber on the bulkheads, nice
smooth, wide fillets on all side/bottom/bulkhead joints, along with fiberglass
reinforcements in all those locations, like the way Sam Devlin builds boats.
Glen
"Richard Spelling" <richard@...> on 06/23/2000 11:33:08 AM
Please respond tobolger@egroups.com
Sent by: "Richard Spelling" <richard@...>
To:bolger@egroups.com
cc: (Glen Gibson/HQ/3Com)
Subject: Re: [bolger] Micro triangular chines?
If your going to glass it inside anyway, why not just do a stich-n-glue for
the chine?
Nothing wrong with doing it that way... I would think that if you had a nice
sized, say 1 1/2 x 1 1/2 triangular chine log, glassing the inside would be
overkill...
Richard Spelling,http://www.spellingbusiness.com/boats
From the muddy waters of Oklahoma
To: <bolger@egroups.com>
Sent: Friday, June 23, 2000 1:00 PM
Subject: [bolger] Micro triangular chines?
have a
glassing the
be
> easier to clean....
> Wadda think?
Was the salesman clueless? Productopia has the answers.
http://click.egroups.com/1/4633/13/_/3457/_/961785311/
Bolger rules:
- no cursing
- stay on topic
- use punctuation
the chine?
overkill...
have a
glassing the
be
> easier to clean....
> Wadda think?
