Re: spar dimensions for small lugsail?
--- Inbolger@yahoogroups.com, "macinkos" <smacinko@...> wrote:
Hmmm, sailing an Auray -- sounds fun. As for scantlings, this might be
germane: I put a balanced lug on a Cartopper, and loved it! It was 64
sq ft, with a 9' yard and a 10' boom, both finished round and tapered.
The yard was about 1 3/8" at the thickest, and turned out a little
bendy for the flat-cut sail. The boom was maybe 1 1/4" at most and
worked just right. Turns out that the boom forces on a balanced lug
are much lighter than with a standard gooseneck type boom, because the
rig is inherently self-vanging. On a regular rig, most of the stress
is on the end of the boom, to pull in the upper leech and reduce
twist. With a balanced lug, this is largely done by the tension in the
downhaul and the luff (Make the luff _strong_!). If you put some round
in the head, say 1-2", you can use the downhaul to flatten the sail in
stronger winds.
I put two reefs in, with the second reef just below the throat, and
got a faux-lateen sail of about 35 sqft for big air. Worked great!
Good luck, and post some pictures when you're done.
Lynn
>Auray Punt...
> I am adapting a small balanced lugsail (yard 8'6"; boom 6'2") to an
stronger winds.
Lynn
The yard and boom on my Windsprint are 2x2 spruce with 1/2 x 1/2
reinforcing strips on each side to bear on the mast. The strips on the
yard are about 4 feet long and on the boom about 2 feet (or maybe 6"
shorter for each).
Patrick.
shorter for each).
Patrick.
macinkos wrote:
> I am adapting a small balanced lugsail (yard 8'6"; boom 6'2") to an Auray Punt
> and am curious about spar dimensions. I understand the forces on the boom
> can be considerable but still wonder what that means in the context of this
> small sail.
> Any Windsprint owners out there care to comment? What size boom do you
> use and do you have any problems with flexing spoiling sail shape? My sail is
> considerably smaller than that on the Windsprint so I think your spar
> dimensions could represent an upper bound for me.
> Thanks,
> Seth
small sail.
Seth
small sail.
Seth
