Re: Casting from Gypsy
Hi, uh, shall I call you Sloppy?
> I had the same problem as you. I went with the 10'6" Pointy Skiff.I
> fish with my 50# dog it is fine.
That's how big my alleged PWD is, too. The question with Pointy is
how satisfying is it to row for a long time and distance. A longer,
leaner design might be more enjoyable - like the two I use now.
> Another option would be the 12' Fisherman's skiff. I would recommend
> putting a skeg on either.
That one has crossed my mind as well.
> I have read that the cross braces on the QT can be removed if you add
> frames. Look in Duckworks projects section. It sounds as if you
> *might* remove them without modification.
Yeah, modifying QT is a snap and I should have done it right off the
bat. I was trying to save weight so I could carry it, but now that I
concocted a "boat barrow" I don't have to worry about it so much.
> Do you have any photos of you QT build.
> I am looking at the power version of the QT, as the Pointy skiff has
> rocker.
I don't have any QT photos posted on my website, although I do have
some in my files somewhere. The problem is that the machine I use for
image processessing and to maintain my website went Tango Uniform in
July and I haven't got around to fixing or replacing it yet. Stay
tuned.
Jon Kolb
Hi Mike,
> It isn't a Bolger, but have you looked at the modified McInnis
Bateau in
> John Gardner's _Building Classic Small Craft vol 2_ ? The original
> design is multichine plywood that might lend itself to modern tape
> glue, and is said to be 63 lb and stable enough to stand in while
casting.
Thanks for the suggestion. I have the book and will look that one up.
Jon Kolb
<jon@...> wrote:
> Bob and all,
> > You don't have to stand to fly cast. Read the July issue of
Canoe &
> > Kayak to see how popular fly fishing from kayaks has become! I
did
> some
> > fly fishing from my solo canoe last winter in Florida without any
> > problems. Well, no problems with the casting anyway. I had never
> > fished saltwater before and found out that I hadn't a clue as to
> what
> > kind of flies to use, so the catching wasn't to great!
> Thanks to everyone for the suggestions. I should have mentioned
that
> I'm only interested in light rowing designs. A couple of the lakes
I
> like to fish are hand launch only, no IC engines, and some of them
> can't be reached with trailers. Some others are simply easier on
> boat on if it can fit in the bed of the pickup instead of being
> hammered to death by trailering over bad roads.
> Kayaks, or double paddle canoes in my case, certainly work fine and
I
> have use mine for fishing. I've also rowed/trolled my Long Light
Dory
> and Michalak Robote craft for over five hours at a time. Time
flies
> when the fish are hitting. When they aren't, good rowing qualities
> are a must in order to get satisfying workout. The motivation for
my
> question was the desire to stand up and stretch my legs and back
after
> sitting for so long, without having to beach and get out of the
boat.
> I can stand briefly in the dory, but I'm with Sam that this is much
> better to do on the shore than in the middle of the lake.
> I thought of Gypsy first because it is a known performer under
oars,
> is quick and cheap to build, and I have the plans at hand. Junebug
> would also fit my requirements, as would Redmond's Whisp, and
probably
> a couple of Welsford's designs. I don't see where the Nicholls
> Flyfisher will be any more stable than a Junebug or the others.
> I built a Michalk QT Skiff that still needs some interior finishing
> before launching, but I don't like the way the cross-braces
clutter
> up the interior, especially if my dog is aboard. I should have,
> may still, deck over the ends to solve this problem. I doubt I
have
> $100 in the boat, so it can be an ongoing experiment.
> Jon Kolb
Hi Jon,
rocker.
Good Luck
It isn't a Bolger, but have you looked at the modified McInnis Bateau in
design is multichine plywood that might lend itself to modern tape and
glue, and is said to be 63 lb and stable enough to stand in while casting.
- Mike
Bob and all,
> You don't have to stand to fly cast. Read the July issue of Canoe &
> Kayak to see how popular fly fishing from kayaks has become! I did
some
what
Thanks to everyone for the suggestions. I should have mentioned that
I'm only interested in light rowing designs. A couple of the lakes I
can't be reached with trailers. Some others are simply easier on the
Kayaks, or double paddle canoes in my case, certainly work fine and I
have use mine for fishing. I've also rowed/trolled my Long Light Dory
and Michalak Robote craft for over five hours at a time. Time flies
are a must in order to get satisfying workout. The motivation for my
question was the desire to stand up and stretch my legs and back after
sitting for so long, without having to beach and get out of the boat.
I thought of Gypsy first because it is a known performer under oars,
would also fit my requirements, as would Redmond's Whisp, and probably
before launching, but I don't like the way the cross-braces clutter
up the interior, especially if my dog is aboard. I should have, and
may still, deck over the ends to solve this problem. I doubt I have
Jon Kolb
Kayak to see how popular fly fishing from kayaks has become! I did some
fished saltwater before and found out that I hadn't a clue as to what
Bob
<jon@...> wrote:
> Anyone with a Gypsy care to comment on whether it's stable enough to
> stand up and fly-fish or cast from? Both my Long Light Dory and
> Michalak Robote are too tender for these activities, the latter
> disastrously so (although they work great for trolling).
> Thanks,
> Jon Kolb
Maybe called a "Brick"
Bryant Owen wrote:
> As stable as it is, June Bug would not be my first choice for a
> casting boat if that was it's main purpose.
> All things considered - and if money/time are not a major issue -
> there are more flyfishing specific designs out there. Nicholl's Lutra
> Flyfisher comes to mind. (see Duckworks Plan section).
> Having said that, I'd certainly argue for the development of a good
> "cost efficient" fly fishing boat.
> Bryant
> --- Inbolger@yahoogroups.com<mailto:bolger%40yahoogroups.com>,
> "Bruce Hallman" <bruce@...> wrote:
> > On 9/17/07, Harry James <welshman@...> wrote:
> > > You need a June Bug for that.
> > See specifically this picture:
> >http://www.akzeigers.com/Images/stability02.jpg
> <http://www.akzeigers.com/Images/stability02.jpg>
> > Amazing.
> > The slab sides give initial stability. Both for the June Bug, but
> > also for all the Bolger designs with slab sides. (First hand
> > testimony: With the Tortoise and the Micro too.)
> How about Jim Mikalak's Jonsboat? As an added
> bonus, the plans are free with his "Boatbuilding
> for Beginners and Beyond" book.
Yes they are, and Jon boats are known to be some of the best fly fishing
boats out there. Few designers create plans for boats that are easier
to build than Jim Michalak too.
Ken Grome
Bagacay Boatworks
www.bagacayboatworks.com
> Robote with a Toto outrigger?
Two Pirogues with a bridgedeck?
Fishcat.
Oddly I was thinking more along the lines of rowing version of Jon Jr.
Jonboat is great but a bit oversized for the job at hand. Absolutely
right about the book. Almost built a Jonboat this spring and you can
definitely do it with what's in the book.
Bryant
>http://www.duckworksbbs.com/plans/jim/jonsboat/index.htm
> as an added bonus, the plans are free with his "Boatbuilding for
Beginners
> and Beyond" book.
> "Govern a great nation as you would cook a small fish. Do not overdo
it."
> -- Lao Tzu
good
Beginners
> and Beyond" book.
overdo it."
> -- Lao Tzu
as an added bonus, the plans are free with his "Boatbuilding for Beginners
and Beyond" book.
"Govern a great nation as you would cook a small fish. Do not overdo it."
-- Lao Tzu
Bryant
> Amazing.
Thanks Bruce for picking out the individual image I was aiming at when I
pointed to Mark's site. I would like to point out one other pic on the
site that I have mentioned before as it is one of the all time great
Bolger boat sailing shots. I used it as my wallpaper on my computer when
I was deployed to remind me of home.
http://www.akzeigers.com/Images/bernersjb.jpg
> Amazing.
Nope
http://www.akzeigers.com/JB.html
> Thanks,
> Jon Kolb
Amazing.
The key to standing and fly-casting from a Long Light
Dory is to keep it on the beach. I never had any
stability problems stnding in mine unless it was in
the water. Sam
--- adventures_in_astrophotography
> stable enough to
> Light Dory and
> the latter
> trolling).
> Thanks,
> Jon Kolb
Take the Internet to Go: Yahoo!Go puts the Internet in your pocket: mail, news, photos & more.
http://mobile.yahoo.com/go?refer=1GNXIC
No, it's not stable at all when you are not sailing. I do not recomend it
for fly-fish neither stand up :)
¿Perhaps a June bug?
Regards, Máximo.
Jon Kolb
