Re: [bolger] adding jibb to bobcat
Chris-
A jib for for light winds will help you keep moving, but it won't help you
point better. :o( The added sail area forward will move the center of
effort forward and you'll probably have a lee helm when using the jib. The
jib will work fine on anything from a reach to running though, so go for
it. I've seen photos of "real" Cape Cod catboats flying reaching jibs and
such.
On Mon, 26 Jun 2000 03:57:54 -0000, you wrote:
> hi All
> I just returned from sailing my bobcat, and I have a problem that I
> need some advice on,... if I may.
> Being a Cat boat "Folly" does not point to the wind very well and is
> very sluggish in light wind,...
> I would like to add a small jibb...
John <jkohnen@...>
http://www.boat-links.com/
A paranoid is a man who knows a little of what's going on.
<William Burroughs>
Hi Chris
I tend to agree with what Bill just wrote. Moreover, if I remember
well, your Folly flies a polytarp sail. What about a "real" one made
from Dacron? I'm pretty sure that a properly cut gaff sail will
make Folly much happier...
Best, Pippo
--- Inbolger@egroups.com, "Chris Flynn" <manta@l...> wrote:
> hi All
> need some advice on, if I may.
is
> very sluggish in light wind, she is GREAT in winds that are 10+( I
> know most of you are going "well DUH!!! It is a gaff rigged cat
boat"
> I knew that when I built her.. But in Indiana our winds are very
> fickle( as we say in the heartland) I would like to add a small
jibb
> ( and bowsprit) to her for winds like we had today ( 5-8 from the
> north) I would only use it in the winds that were like today (
which
> is quite often latley) what type should I put on her.. should it be
> like the one that is on a light scooner? ( one that has a boom or
> clubfoot) or one that is like a bermuda rigg? ( one that come past
> the mast)
> I am new to all this, and do not know how to figure the amount
> square footage and how it should be configured..Any suggestions
would
> be welcomed!!!thanks
> Chris Flynn
> Flynn's Folly
> _/)
hi All
know most of you are going "well DUH!!! It is a gaff rigged cat boat"
fickle( as we say in the heartland) I would like to add a small jibb
north) I would only use it in the winds that were like today ( which
the mast)
I am new to all this, and do not know how to figure the amount of
square footage and how it should be configured..Any suggestions would
Chris Flynn
Flynn's Folly
_/)
