Re: [bolger] Tiny cat Build
http://www.duckworksmagazine.com/04/s/columns/magen/17/ron.cfm
It is worth mentioning the "Payson joint' type of butt joint. That is
the type specified by PCB Topaz, and it works fine being both strong
and invisible.
and invisible.
I have found it helpful to cut,sand,grind,etc a 45 degree bevel on all
sides of the butt block before using it. Much easier at this stage than
after it's attached and I'm trying to glass over it. Clyde
> On 10/3/07, Tim Anderson <lebateautim@...[Non-text portions of this message have been removed]
> <mailto:lebateautim%40earthlink.net>> wrote:
> > Scarf joints always bend fairer than butt blocked joints
> True in theory, but in practice on a small boat like Tiny Cat, the
> butt joint is perfectly fine. (and quicker). My advice to improve the
> looks, use the butt joint, and then spend the time you save on a
> better paint job.
> (Also, I don't recall the panel cut layout for Tiny Cat, but Bolger in
> well known for very tight panel cut layouts, and the scarfed joint
> could easily cost you an extra sheet of plywood.)
Hi......I have never found any advantage whatsoever to scarf plywood. I've built alot of boats and some of them have been through all kinds of abuse. I've never seen any reason to take the time to scarf. I also seriously doubt if it is any stronger. Robb
Sent: Wednesday, October 03, 2007 5:55 PM
Subject: [bolger] Re: Tiny cat Build
In defense of butt blocks: I used butt blocks in my Chebacco, and I
invite anyone to find any flat spots or locate the joints from
outside. I used butt blocks of the same plywood that made up the
panels. I believe the butts were 6" wide, but can't say for sure
without looking -- I expect I scaled them from the drawings.
I thought about using scarfs, but it would have made the layout more
difficult as Bolger's layout assumes butt blocks. If you chamfer
the edges of the butt before installing, you can get a good finish
inside.
Jamie Orr,
Chebacco "Wayward Lass"
--- Inbolger@yahoogroups.com, "Tim Anderson" <lebateautim@...>
> Scarf joints always bend fairer than butt blocked joints so long
as they are
> allowed to cure before stressing. I glass over the scarf with 4 oz
cloth
> just to be on the safe side. Tim P Anderson
> _____
> From:bolger@yahoogroups.com[mailto:bolger@yahoogroups.com] On
Behalf Of
> Chris Potts
> Sent: Wednesday, October 03, 2007 7:41 AM
> Subject: [bolger] Tiny cat Build
> greetings all,
> I am in the process of building Bolgers Tinycat and am wondering
if
> using Scarf joints in place of the Butt Block method has been
tried.
> It seems like it would work quite will on the bilge pannels as
they
> perhaps would fair better but I don't know? Anyone have any
> experience with a Scarfed joint on a Tinycat build?
inside.
Jamie Orr,
inside.
Jamie Orr,
>as they are
> allowed to cure before stressing. I glass over the scarf with 4 ozcloth
> just to be on the safe side. Tim P AndersonBehalf Of
> _____
> Chris Pottsif
> greetings all,
> using Scarf joints in place of the Butt Block method has beentried.
> It seems like it would work quite will on the bilge pannels asthey
better paint job.
> Scarf joints always bend fairer than butt blocked jointsTrue in theory, but in practice on a small boat like Tiny Cat, the
better paint job.
Scarf joints always bend fairer than butt blocked joints so long as they are
allowed to cure before stressing. I glass over the scarf with 4 oz cloth
_____
Chris Potts
greetings all,
I am in the process of building Bolgers Tinycat and am wondering if
using Scarf joints in place of the Butt Block method has been tried.
It seems like it would work quite will on the bilge pannels as they
_____
Chris Potts
greetings all,
greetings all,
