Re: Gypsy glass schedule
I built a Gypsy some years ago and covered the outside with 6 oz.
glass set in epoxy. Epoxy and paint on the inside. Seemed like more
than adequate.
I added a deck and large water-tight compartments to make for easy
self-rescue for after the aforementioned inevitable death roll swim.
Enjoy your Gypsy - it is a fine design.
Romayne
than adequate.
Romayne
Kirill,
I never added a skeg, as I became busy building my Long Micro. My
Gypsy gets very little use these days. I suggest that you build your
Gypsy to spec and try it out. I found that it rowed well, until I
started rowing at top speed. At top speed, the boat will suddenly
jerk/turn 90 degrees (port or starboard, as she sees fit) and
basically slide to a stop. Doesn't make the rower look proficient,
and impedes progress. I do not recall if keeping the dagger board down
helped it track straighter- I probably tried it and it didn't work.
One day I got caught out in some pretty horrible winds and waves and
found myself rowing frantically, into the wind and waves, for the
dock. I rowed with all my might as spray washed over the bow.
Knuckles were white, mouth was dry, swear-words filled the air.
Although I was making very slow progress over-ground, the water
pushing past the hull was enough to cause my Gypsy to twist suddenly
side-to-side; putting me broadside to the waves. This happened
repeatedly and it wasn't fun. The harder I rowed into the wind, the
more it happened.
If I get back into sailing my Gypsy again, I'll add a short skeg. I
don't see how it would harm tracking. There was a discussion about
Gypsy skegs on this group and someone added a skeg. A search should
locate the discussion. I think Susan was involved? Anyone else have
experience with skeggin' their Gypsy?
I don't want to be negative about the Gypsy. It's a truly great boat
and I had a blast building and sailing mine.
One last tidbit of advice. Try cutting your daggerboard and rudder at
45 degrees to the grain of your plywood. I cut mine along the grain
(that is, the plywood grain runs up-and-down, and side-to-side in my
foils). I saw someone cut their daggerboard with the grain running at
45 degree angles; it's supposed to keep the foils from warping. My
dagger board has since warped a bit but it's been around for 10 years now.
Please keep us posted with your progress. Pictures are always appreciated.
Bill, in Ohio
more it happened.
Bill, in Ohio
--- Inbolger@yahoogroups.com, "ksapelkin" <iiqtub5086@...> wrote:
> Hello Bill,
> I agree. It seemed like overkill to me, but to quote chapter and
> verse,
> Payson: Build the new instant boats page 48:
> "Twelve yards of 10-ounce 38-inch cloth will cover her hull
> completely."
> Further:
> "When you're glassing Gypsy's sides, you'll find that a strip of 38-
> inch cloth will reach from one sheer across her bottom and nearly to
> the opposite chine."
> If Gypsy is about 5 yards long and instructions call for 12 yards,
> that seems to indicate that the bottom ends up with TWO layers of 10
> ounce glass.
> BTW he calls for some additional glass at the stem and forefoot to
> protect the boat when beaching.
> Does the skeg detract from the sailing performance?
> Kirill
Hello Bill,
verse,
completely."
Further:
ounce glass.
Kirill
verse,
completely."
Further:
ounce glass.
Kirill
--- Inbolger@yahoogroups.com, "Bill" <kingw@...> wrote:
> Kirill,
> Ten oz. glass!? Wow. I used 4 oz. on the outside of my Gypsy and
> coated the inside with epoxy resin (and paint). My Gypsy is now 10
> years old. If you are beaching your boat a lot, the thicker
> fiberglass might be worth it. I repeatedly wore thru the glass on
> the "nose" of my Gypsy (the very forward-most part of the bottom
> panel), and eventually glued a piece of aluminum there, to take the
> brunt of beaching. The aluminum worked well.
> I've stored my Gypsy outside, upside down for most of her 10
years.
> The 4 oz. glass has held up fine. The one winter I stored her
> upright (with a cover), the cover leaked and she got some water
> inside. I caught it in time, so she wasn't subjected to repeated
> freeze-thaw cycles. Not a good thing, but she survived OK. If
your
> boat will regularly have water sitting inside, it may be prudent to
> use fiberglass on the inside too. There's a recent Diablo demise
> support this suggestion.
> Ten oz. seems like a lot, but it depends on how rough you plan to
be.
> It's a great boat, by the way. It will row straighter with a short
> skeg on the bottom. It sails a little tender, and it death rolls
> when it jibes, but it's a fantastic boat to sail, and you'll get
> plenty of compliments.
> Bill, in Ohio
> --- Inbolger@yahoogroups.com, "ksapelkin" <iiqtub5086@> wrote:
> > Hello,
> > The Gypsy instructions call for 10 oz. glass on the the outside
> the the
> > hull and paint only on the inside.
> > Would it be an improvement to glass the inside as well?
> > To keep weight down I thought to use 10 oz. glass on the bottom
> 4 oz
> > on the bilge and side panels. Inside and out. Likewise 4 oz on
> > framing. 10 oz taping throughout.
> > I settled on Hydrotek for the plywood.
> > Thanks.
> > Kirill
Kirill,
I've stored my Gypsy outside, upside down for most of her 10 years.
freeze-thaw cycles. Not a good thing, but she survived OK. If your
use fiberglass on the inside too. There's a recent Diablo demise to
Ten oz. seems like a lot, but it depends on how rough you plan to be.
Bill, in Ohio
Bill, in Ohio
> Hello,
> The Gypsy instructions call for 10 oz. glass on the the outside of
the the
> To keep weight down I thought to use 10 oz. glass on the bottom and
4 oz
> on the bilge and side panels. Inside and out. Likewise 4 oz on the
> Thanks.
> Kirill
Hello,
The Gypsy instructions call for 10 oz. glass on the the outside of the the
To keep weight down I thought to use 10 oz. glass on the bottom and 4 oz
Thanks.
Kirill
Thanks.
Kirill
