Re: alternative boat glue for epoxy allergy???
Or,in the case of the replica 'Cuckoo' Chesterfield
canal narrowboat that the society will be constructing
in about 12 months time(we're waiting for the wood to
season),turpentine,boiled linseed oil and horse
manure.The carpenter who will be building the 70ft
boat specified grain,not grass fed horses to provide
the last item.Incidentally,as far as I
know,Chesterfield Cuckoos were the only narrow boats
to be sailed.Leeboards were available but not
generally used on the river Trent(the canal linked
Chesterfield to the Trent)although in later years
usual practise was to get a tow from one of the Trent
tugs,as did the Humber keels.However they occasionally
penetrated as far as the wash,which involved coastal
sailing,and leeboards were used for that.Which makes
me think that PCB should have specified detachable
leeboards on Weston Martyr and not the bigeboard used
cheers
Andy Airey
Send instant messages to your online friendshttp://uk.messenger.yahoo.com
cheers
Andy Airey
On 10/6/07, Robb <Robb@...> wrote:
which is still holding up after a decade. Regardless, I have switched
now entirely to epoxy glue because it is so excellent and cheap. I
use gloves and entirely avoid skin contact, and work with good
ventilation in my shop (one wall is missing!)
There is one condition where Gorilla Glue is much superior to epoxy:
that is when working outdoors in the rain, and/or with 'green' wet
wood.
>I used a (Gorilla Glue type) polyurethane glue on my Bolger Spur II,
> Hmmmmmm......this is the first time I've ever heard anything negative about gorilla glue.
wood.
Proper prep of all woods before gluing is sanding. This is the one
mistake most people make the other is to not coat both surfaces befor
putting tigather. The first causes poor bond surface the second glue
starvation. Both mistakes lead to week glue joints in area of stress.
Proper prep helps prevent shear failures. Dried woods be it kilm
dried or seasond have closed cells on the surface sanding opens it up
for the glue to soak in for better bond.
Jon
Jon
--- Inbolger@yahoogroups.com, "Bob Slimak" <otter55806@...> wrote:
> One more post on resorcinol and epoxy
> I first used epoxy as a child around 1959 or 60, thereabouts. It
was
> not on the market to everyone, but my Dad was the supervisor of the
> research machine shop for Bemis company, making prototype machines
> for the plastic industry. I also had plastic bags when no one know
> what they were. Who knew what a mess for the environment plastics
> would turn out to be! Anyway, decades later when I was building my
> Bruce Roberts Spray, and had an both epoxy joints fail on 7 inch
high
> in a place where they were subjuect to high shear loads, I asked
him
> about it and he said the lab guys say epoxy is great except for
> shear. I'm sure epoxy has improved a lot since then, but not
wanting
> to take a chance on my wood mast I went back to resorcinol. The
> reason for this was that, before WWII my Dad worked as a machinest
> for General Dairy. They made the huge blades for the churns from
> oak, lamimated with resorcinal into a large plank, about 6" X 12" I
> seem to recall. Then they put this laminated piece into a huge
> steambox where it was twisted to make the churn blades, paddles,
> whatever they called them. Any glue that can survive that can be
> trusted.
> I, of course, do use epoxy because I am too impatient to try to
make
> the perfect joints necessary when I don't have thousands of dollars
> worth of joiners, planers, etc. to make such joints. Remember,
> before epoxy a GOOD glue joint was expected to be .oo5 inches,
> something not possible with my $89.95 table saw from Menards:(
> Bob
> PS - My Spray is still around the area, and the mast is still good
> after 23 years.
> -- Inbolger@yahoogroups.com, "bill shamblin" <bshamblin2002@>
> wrote:
> > thanks everyone! this is the information i needed.
> > bill in nc
> > --- Inbolger@yahoogroups.com, "David" <arbordg@> wrote:
> > > It was Fine WW, I believe. They tested both "good" joints
> > and "sloppy"
> > > joints. The Titebond III did, indeed, come out ahead of the
tested
> > > group - which included Gorilla Glue, but did not, IIRC, include
> > either
> > > resorcinol or plastic resin glue. I might also note that the
epoxy
> > > tested was not one I was experienced with. I'm not sure it was
> > > representative of those typically used for boatbuilding, but
> > probably
> > > it was close enough.
> > > I like Titebond III, and - as a professional woodworker - have
> been
> > > using it increasingly. However, if I remember the article
> > correctly,
> > > they did not address the issues of repairability, or
> reversibility,
> > > neither of which are good traits for T III.
> > > Repairability is whether an adhesive will glue to itself. Many
> > folks
> > > say T III won't. My experience is not as bad as some of the
> stories
> > > offered, but it seems a bit iffy. I've not enough experience
yet
> to
> > > say for sure what factors come into play. My sense is that the
> more
> > > fresh wood fibre exposed the better and the earlier in the cure
> the
> > > better. Epoxy and resorcinol have good repairability. Gorilla
> > glue -
> > > also not trustworthy.
> > > Reversibility is whether a cured/dried glued joint can be
undone.
> > For
> > > example, antique furniture was usually assembled with some sort
> > > hide glue. Hide glue can be reversed with the application of
> heat -
> > > esp. moist heat. A conservator of fine antiques would never do
> > repairs
> > > using epoxy, or PVA glue (like standard Titebond), or modifed
PVA
> > > (like T III). Partly, that's for historical accuracy, and
partly
> > it's
> > > for the sake of being able to make future repairs without
> damaging
> > a
> > > valuable piece of furniture. The closest any of the typical
marine
> > > adhesives comes to reversibility is epoxy. If heated to maybe
> 160 -
> > > 200 degrees F(depending on the brand/formulation), it will
begin
> to
> > > reliquify.
> > > As for my distrust of Gorilla Glue, it may just be my
impatient,
> > surly
> > > side kicking in when faced with some new "miracle goo". I tried
> it
> > on
> > > several small projects for my own use. I made some test panels.
> > Some
> > > panels I left out to weather, some I did some destruction
testing
> > on,
> > > and some I did the boil test on. I was not impressed with the
> > results.
> > > I've also seen a few reliable sources echo my concerns (such as
> the
> > > Fine WW test mentioned above). However, several of my 'Ol Coot
> > buddies
> > > have built their boats primarily with GG. None have fallen
apart
> > yet,
> > > and neither has yours. My cynical self says, talk to me 10
years
> > from
> > > now. Talk to me after your boatcover leaks and she sits with a
> > bilge
> > > full of water for months. Talk to me after you go through some
> > heavy
> > > weather, and she gets tossed and beat beyond what you ever
> expected
> > > her to. I hope those reports will be good, but I'm a bit
> skeptical.
> > > Cheers & Smears,
> > > David Graybeal
> > > Portland, OR
> > > "These are my principles, and if you don't like them... well,
> I've
> > got
> > > others" -- Groucho Marx
> > > --- Inbolger@yahoogroups.com, "fredschum" <fredschum@> wrote:
> > > > I think it was Fine Woodworking that did a comparative glue
> test
> > a
> > > > few months ago and determined that Titebond III was the best,
> > > > slightly ahead of epoxy. It rated the polyurethane glue last.
> > The
> > > > test did not include underwater exposure. However, Titebond
is
> a
> > > > waterproof glue. Guzwell, of Trekka fame, became allergic to
> > epoxy
> > > > and built a boat using a two-part (aliphatic acid-hardened, I
> > think)
> > > > glue. The article was in Wooden Boat some years ago.
> > > > --- Inbolger@yahoogroups.com, "bill shamblin"
<bshamblin2002@>
> > > > wrote:
> > > > > builders,
> > > > > what is the best hull building glue ( for fir/pine/exterior
> > grade
> > > > > plywood ) for one who has developed epoxy allergy???
> > > > > my last boat was built with 1 part poly-urethane glue ( pl
> > premium
> > > > > construction )which let go after about 2 years around the
> > chines,
> > > > > mostly i suspect, because 1- i took out the dry wall screws
> > after
> > > > the
> > > > > glue dried and 2- i didnt fully cover the hull with
> fiberglass
> > > > inside
> > > > > and out (which i will do this time.)
> > > > > im doing a small boat - a double Brick 4x16.
> > > > > thanks,
> > > > > bill in NC
I first used epoxy as a child around 1959 or 60, thereabouts. It was
Bruce Roberts Spray, and had an both epoxy joints fail on 7 inch high
in a place where they were subjuect to high shear loads, I asked him
shear. I'm sure epoxy has improved a lot since then, but not wanting
trusted.
I, of course, do use epoxy because I am too impatient to try to make
Bob
after 23 years.
-- Inbolger@yahoogroups.com, "bill shamblin" <bshamblin2002@...>
trusted.
Bob
after 23 years.
>been
> bill in nc
> and "sloppy"
> > joints. The Titebond III did, indeed, come out ahead of the tested
> either
> > resorcinol or plastic resin glue. I might also note that the epoxy
> probably
> > using it increasingly. However, if I remember the articlereversibility,
> correctly,
> > neither of which are good traits for T III.stories
> folks
> > offered, but it seems a bit iffy. I've not enough experience yetto
> > say for sure what factors come into play. My sense is that themore
> > fresh wood fibre exposed the better and the earlier in the curethe
> > better. Epoxy and resorcinol have good repairability. Gorillaheat -
> glue -
> > Reversibility is whether a cured/dried glued joint can be undone.
> For
> > example, antique furniture was usually assembled with some sort of
> > esp. moist heat. A conservator of fine antiques would never dodamaging
> repairs
> > using epoxy, or PVA glue (like standard Titebond), or modifed PVA
> > (like T III). Partly, that's for historical accuracy, and partly
> it's
> a160 -
> > valuable piece of furniture. The closest any of the typical marine
> > 200 degrees F(depending on the brand/formulation), it will beginto
> > reliquify.it
> > As for my distrust of Gorilla Glue, it may just be my impatient,
> surly
> onthe
> Some
> > panels I left out to weather, some I did some destruction testing
> on,
> results.
> > Fine WW test mentioned above). However, several of my 'Ol Cootexpected
> buddies
> > have built their boats primarily with GG. None have fallen apart
> yet,
> > and neither has yours. My cynical self says, talk to me 10 years
> from
> bilge
> heavy
> > her to. I hope those reports will be good, but I'm a bitskeptical.
> >I've
> > Cheers & Smears,
> > David Graybeal
> > Portland, OR
> gottest
> aa
> The
> > > test did not include underwater exposure. However, Titebond is
> > > waterproof glue. Guzwell, of Trekka fame, became allergic tofiberglass
> epoxy
> think)
> > > --- Inbolger@yahoogroups.com, "bill shamblin" <bshamblin2002@>
> > > wrote:
> > > > builders,
> grade
> premium
> chines,
> after
> > > the
> > > inside
> > > > thanks,
> > > > bill in NC
bill in nc
bill in nc
and "sloppy"
either
probably
> I like Titebond III, and - as a professional woodworker - have been
correctly,
> they did not address the issues of repairability, or reversibility,
folks
> say T III won't. My experience is not as bad as some of the stories
> offered, but it seems a bit iffy. I've not enough experience yet to
> say for sure what factors come into play. My sense is that the more
> fresh wood fibre exposed the better and the earlier in the cure the
glue -
For
> hide glue. Hide glue can be reversed with the application of heat -
repairs
it's
> for the sake of being able to make future repairs without damaging
> adhesives comes to reversibility is epoxy. If heated to maybe 160 -
> 200 degrees F(depending on the brand/formulation), it will begin to
> reliquify.
surly
> side kicking in when faced with some new "miracle goo". I tried it
on
Some
on,
results.
> I've also seen a few reliable sources echo my concerns (such as the
buddies
yet,
from
bilge
heavy
> weather, and she gets tossed and beat beyond what you ever expected
> her to. I hope those reports will be good, but I'm a bit skeptical.
> Cheers & Smears,
> David Graybeal
> Portland, OR
> "These are my principles, and if you don't like them... well, I've
got
> > I think it was Fine Woodworking that did a comparative glue test
The
> > test did not include underwater exposure. However, Titebond is a
epoxy
think)
> > wrote:
> > > builders,
grade
premium
chines,
after
> > the
> > > glue dried and 2- i didnt fully cover the hull with fiberglass
> > inside
> > > thanks,
> > > bill in NC
It was Fine WW, I believe. They tested both "good" joints and "sloppy"
group - which included Gorilla Glue, but did not, IIRC, include either
representative of those typically used for boatbuilding, but probably
using it increasingly. However, if I remember the article correctly,
Repairability is whether an adhesive will glue to itself. Many folks
better. Epoxy and resorcinol have good repairability. Gorilla glue -
Reversibility is whether a cured/dried glued joint can be undone. For
esp. moist heat. A conservator of fine antiques would never do repairs
(like T III). Partly, that's for historical accuracy, and partly it's
for the sake of being able to make future repairs without damaging a
reliquify.
As for my distrust of Gorilla Glue, it may just be my impatient, surly
side kicking in when faced with some new "miracle goo". I tried it on
several small projects for my own use. I made some test panels. Some
panels I left out to weather, some I did some destruction testing on,
and some I did the boil test on. I was not impressed with the results.
Fine WW test mentioned above). However, several of my 'Ol Coot buddies
have built their boats primarily with GG. None have fallen apart yet,
and neither has yours. My cynical self says, talk to me 10 years from
now. Talk to me after your boatcover leaks and she sits with a bilge
full of water for months. Talk to me after you go through some heavy
Cheers & Smears,
David Graybeal
Portland, OR
"These are my principles, and if you don't like them... well, I've got
reliquify.
Cheers & Smears,
David Graybeal
Portland, OR
--- Inbolger@yahoogroups.com, "fredschum" <fredschum@...> wrote:
> I think it was Fine Woodworking that did a comparative glue test a
> slightly ahead of epoxy. It rated the polyurethane glue last. The
> waterproof glue. Guzwell, of Trekka fame, became allergic to epoxy
> and built a boat using a two-part (aliphatic acid-hardened, I think)
> wrote:
> > builders,
> > what is the best hull building glue ( for fir/pine/exterior grade
> > my last boat was built with 1 part poly-urethane glue ( pl premium
> > construction )which let go after about 2 years around the chines,
> > mostly i suspect, because 1- i took out the dry wall screws after
> the
> inside
> > thanks,
> > bill in NC
Glad to see you havn't had problems but my info came frol the Wood
Products Testing Lab. Good thing you use tight fits the stringth
drops quickly when it fomes to fill gaps. Read the small print on the
back it says WATER RESISTANT not proof.
Jon
Jon
negative about gorilla glue. I've built numerous small boats like
bolger skimmers and other similar 2 sheet boats.....sometimes without
even taping the chines at all and I've NEVER had any problem
whatsoever. Dave Zeiger who designed the trilobyte boats even
recommends it OVER epoxy for construction. For years I refused to
use anything other than epoxy but I've finally come off my addiction
and building boats is MUCH more enjoyable and faster with the other
glues. on an important boat I do glass the bottom but it certainly
isn't out of fear of the gorilla glue failing. I stongly question
the validity of any report of it failing. My latest skimmer is on
year 7 of its life and it has been outside 99% of the time. I am
currently using it on all of the internal framing on my Robbsboat.
Do a good enough job on your cutting so that you don't have any
cracks and gorilla glue won't come apart. Robb
> From: David
> To:bolger@yahoogroups.com
> Sent: Sunday, October 07, 2007 12:28 AM
> Subject: [bolger] Re: alternative boat glue for epoxy allergy???
> I'm with Jon & Kenneth. My personal experience with Gorilla Glue &
> it's clones has not been good. I've largely stopped using it.
> The resorcinol is a good option, if you're willing & able to take
> care necessary to achieve close-tolerance joinery, and allow for
> sufficient clamping pressure. It has been used for boatbuilding &
> airplane construction for many decades, and was the adhesive of
choice
> prior to the widespread availability of epoxies.
> Epoxy is just as good, if not better as an adhesive. The added
> advantages are: sloppy, quicker joints are fine - even good;
minimum
> clamping is required; it also serves as a high-build, water-
resistant
> primer coat for painted or varnished finishes - in fact, a
variety of
> available additives make it useful for a wide range of tasks.
> Seems like you have three options: use epoxy, but take
extraordinary
> steps to protect yourself from exposure (seems doable, but watch
for
> symptoms!); switch to resorcinol glue, and live with it's
limitations
> (also doable); switch to traditional boatbuilding techniques
(nothing
> wrong with that, but is slower with more of a learning curve).
> Cheers,
> David Graybeal
> Portland, OR
> "Argue for your limitations and sure enough, they're yours" --
Richard
> Bach
> --- Inbolger@yahoogroups.com, Kenneth Grome <bagacayboatworks@>
> > Gorilla glue has been reported to fail in more than one boating
forum.
> > Apparently it does not live up to the hype.
> > Sincerely,
> > Ken Grome
> > Bagacay Boatworks
> > www.bagacayboatworks.com
Hmmmmmm......this is the first time I've ever heard anything negative about gorilla glue. I've built numerous small boats like bolger skimmers and other similar 2 sheet boats.....sometimes without even taping the chines at all and I've NEVER had any problem whatsoever. Dave Zeiger who designed the trilobyte boats even recommends it OVER epoxy for construction. For years I refused to use anything other than epoxy but I've finally come off my addiction and building boats is MUCH more enjoyable and faster with the other glues. on an important boat I do glass the bottom but it certainly isn't out of fear of the gorilla glue failing. I stongly question the validity of any report of it failing. My latest skimmer is on year 7 of its life and it has been outside 99% of the time. I am currently using it on all of the internal framing on my Robbsboat. Do a good enough job on your cutting so that you don't have any cracks and gorilla glue won't come apart. Robb
The resorcinol is a good option, if you're willing & able to take the
airplane construction for many decades, and was the adhesive of choice
advantages are: sloppy, quicker joints are fine - even good; minimum
clamping is required; it also serves as a high-build, water-resistant
primer coat for painted or varnished finishes - in fact, a variety of
Seems like you have three options: use epoxy, but take extraordinary
steps to protect yourself from exposure (seems doable, but watch for
symptoms!); switch to resorcinol glue, and live with it's limitations
(also doable); switch to traditional boatbuilding techniques (nothing
David Graybeal
Portland, OR
"Argue for your limitations and sure enough, they're yours" -- Richard
Bach
--- Inbolger@yahoogroups.com, Kenneth Grome <bagacayboatworks@...> wrote:
> Gorilla glue has been reported to fail in more than one boating forum.
> Sincerely,
> Ken Grome
> Bagacay Boatworks
David Graybeal
Portland, OR
Bach
David Graybeal
Portland, OR
Bach
> Sincerely,
> Ken Grome
> Bagacay Boatworks
Ken Grome
Bagacay Boatworks
Ken Grome
Bagacay Boatworks
> No disrespect for John but the fine print
> on the back of Gorila glue here in the us
> says it is water resistant.
No disrespect for John but the fine print on the back of Gorila glue
here in the us says it is water resistant.
Jon
Jon
> wrote:
> That's bad luck with the expoxy. I use epoxy but John Welsford has
> little discussion about glue here,
>http://tinyurl.com/2ueezj
> Resorcinol has been used on boats, it requires that you learn how
> to use it. Jamestown Distributors might have it.
> Charles Rouse
> > builders,
premium
> the
> inside
> > thanks,
> > bill in NC
--- Inbolger@yahoogroups.com, "bill shamblin" <bshamblin2002@...>
That's bad luck with the expoxy. I use epoxy but John Welsford has a
Charles Rouse
Charles Rouse
>the
> builders,
> glue dried and 2- i didnt fully cover the hull with fiberglassinside
> thanks,
> bill in NC
> Excellent boats have been built for many centuries without epoxy.Or trunnels and tar and oakum.
> They used plenty of nails, screws, and caulking.
> what is the best hull building glue ( for fir/pine/exterior gradeExcellent boats have been built for many centuries without epoxy.
I will second that on the TB-III TB-II and the Gorila glue types are
only water RESISTANT in the fine print. Glues like PL don't soak in
as well and so they only surface glue. If you are going to glass
afterwards why not use the same precautions you use to glass to glue.
Proper protection with nonfully cured epoxy like gloves and masks at
all times though a pain saves the itch.
Jon
Jon
think)
> wrote:
> > builders,
premium
> the
> inside
> > thanks,
> > bill in NC
>the
> builders,
> thanks,
> bill in NC
builders,
mostly i suspect, because 1- i took out the dry wall screws after the
glue dried and 2- i didnt fully cover the hull with fiberglass inside
thanks,
bill in NC
thanks,
bill in NC
