Re: [bolger] Ready to Raka Roll!
David,
First question: You just wait until the applied coat of resin feels
tacky to the touch but no longer leaves residue sticking to your
finger or glove, and then mix and apply the next coat. This is how
it works with West and Mas epoxies. I have no personal
experience with Raka products, but the chemistry should be the
same.
Second question: I usually try to turn the hull so that I'm working
on a more or less horizontal surface when applying the glass. It is
indeed a good idea to conceal the glass butt on the bottom if it can
be so arranged, if only because it saves you additional work sanding
and filling to a yacht finish. You don't have to do the bottom first to
accomplish this, just fit the glass for the sides so it goes over the
chine and onto the bottom. the glass fabric is flexible enough to do
that that if you've rounded the chine nicely. There is something to
be said for glassing one side on the horizontal, turning the boat
completely upside down and glassing the bottom, then (as the epoxy
on the first side will have started going off and will tolerate some
abuse) turning the boat so that the second side is up and horizontal,
and glass that side. Put clean plastic sheeting or wax paper onto the
staging where it contacts the coated hull to avoid gluing the whole
works together at this point. After this final side is done you can turn
the hull bottom up and proceed with the subsequent coats of epoxy.
As these are thinner and the glass is now wetted out, your work is
much less likely to sag and run, so the boat will require no further
positioning.
I know this all sounds like a complicated process, but I've found it
actually makes the process easier *if* the hull is reasonably easy to
turn with the help on hand,
david m galvin
same.
positioning.
david m galvin
David Ryan wrote:
> FBBB --
> My Raka order just arrived -- 20 yards of cloth and enough epoxy to
> finish the Light Scooner and crank out a couple of pirated punts.
> I am under the impression that if you apply additional epoxy to
> partially cured previous coats, then there is no need for sanding,
> washing, and the bond is superior. If I'm misreading the West
> literature or if it doesn't apply to Raka, someone please let me know!
> My strategy is this: one big piece to cover the bottom, and one long
> skinny piece for each side. I've got 6 oz. 60 inches wide for the
> bottom, and 4 oz. 30 inches wide for the side. I thinking the bottom
> should go on first so the rougher finish of the overlap is hidden on
> the bottom. Any thoughts one way or the other would be most welcome...
>West's Epoxy works came yesterday and they tried a lot of primers that allHey there! Easy on the Despot. They carry all manner of Zinzer
>worked pretty well on dry epoxy the only one I remember is Bullseye.
products, including their "Bullseye" primer in both oil and latex.
CRUMBLING EMPIRE PRODUCTIONS
134 W.26th St. 12th Floor
New York, NY 10001
(212) 247-0296
Don't buy paint from Home Depot go to a paint store and buy some decent
paint and a little service to go with it. The stuff the discount houses
sell is pretty poor quality compared to brand name paints. For a boat you
aren't talking about 10 bucks difference. It's not like epoxy where they
are all using the same raw materials.
Gordon
Gordon Cougergcouger@...
405 624-2855 GMT -6:00
Gordon
> This doesn't sound good at all. I didn't even need three coat ofepoxy?
> paint (and no primer,) on my polyester boat.
> Anyone other paint ideas that can be found at Home Despot for covering
>no
> >Peels off in great sheets, unless you use about three coats of primer.
> >Richard Spelling,http://www.spellingbusiness.com/boats
> >>From the muddy waters of Oklahoma
> >> Speaking of porch paint, it when over lil'winnie's polyester resin
> >> problem, still sticking really tight. Anyone have any experiences
> >> using it over expoxy they'd care to share?
100% acrylic exterior house paint is supposed to go over epoxy very well,
without any primer. Be sure to scrub with brilo pads and mild soapy water.
Everybody, including me, likes porch paint because it's a tough paint, and
they don't want scratches and whatnot on thier boat. Without primer, it
comes off in sheets. When you use primer it sticks well enough, but when you
do get a scratch, the paint pulls away from the primer coat (sticks fine,
but is harder than the primer, small flakes will separate from the primer
where you scratch it)....
Oil based primer doesn't cure well, use water based.
I personaly haven't tried the 100% acrylic latex exterior route, but some
people swear by it.
people swear by it.
To: <bolger@egroups.com>
Sent: Tuesday, June 27, 2000 9:41 PM
Subject: Re: [bolger] Ready to Raka Roll!
epoxy?
> >> Speaking of porch paint, it when over lil'winnie's polyester resin no
> >0% Introductory APR!
> >Instant Approval!
> >Aria Visa - get yours today.
> >http://click.egroups.com/1/6035/13/_/3457/_/962137221/
> >Bolger rules!!!
> >- no cursing
> >- stay on topic
> >- use punctuation
> >- add your comments at the TOP and SIGN your posts
> >- add some content: send "thanks!" and "ditto!" posts off-list.
> New York, NY 10001
> (212) 247-0296
> Get a NextCard Visa, in 30 seconds!
> 1. Fill in the brief application
> 2. Receive approval decision within 30 seconds
> 3. Get rates as low as 2.9% Intro or 9.9% Fixed APR
>http://click.egroups.com/1/5197/13/_/3457/_/962159816/
> - no cursing
> - stay on topic
> - use punctuation
Anyone other paint ideas that can be found at Home Despot for covering epoxy?
New York, NY 10001
(212) 247-0296
>Peels off in great sheets, unless you use about three coats of primer.CRUMBLING EMPIRE PRODUCTIONS
>Instant Approval!
>- no cursing
>- stay on topic
>- use punctuation
New York, NY 10001
(212) 247-0296
