Re: [bolger] Re: Fer-A-Llite
Watcha building Krissie? I got the plans and the spruce (local) for an
LMA Taylorcraft.
Kristine Bennett wrote:
> I don't think Burt or Dick Rutan are into boat building.... ;) But we do know they did make a space shot with The White Knight and Spaceship One.
> It's OK Bill I'm a crazy home built aircraft nut as well! As it stands the airplane will get built before the boat. Oh we will be using some ideas that Burt help get into mainstream aircraft.
> Blessings Krissie
>BllFs6@...wrote:
> In a message dated 12/18/2007 7:40:46 PM Central Standard Time,
>halgordon@...writes:
> > Wow... it has sailing, space travel, and Darwin Awards wrapped up in one
> > neat little package!
> Man.....I can finally quit searching the net....I've found my
> niche....please tell me Bolger and Burt Rutan are in this mix....
> I think I am getting the vapors!
> Did someone say duct tape?
> swooning Blll
Blessings Krissie
swooning Blll
**************************************See AOL's top rated recipes
(http://food.aol.com/top-rated-recipes?NCID=aoltop00030000000004)
Never miss a thing. Make Yahoo your homepage.
swooning Blll
> -p
> On Dec 18, 2007 4:32 PM, Hal Gordon <halgordon@...> wrote:
> > --- Inbolger@yahoogroups.com, Dan Burrill <dan@> wrote:
> > > Hal Gordon wrote:
> > > > Has anyone used this product? The 1,000 day sailboat has me intriqued.
> > > > Hit a freighter
> > > > head-on with no damage to the hull? Wow!
> > > > Hal Gordon
> > > > _
> > > > .ferrocement
> > > Too good to be true? Probably, IMHO.
> > > The schooner Anne (aka Tantra) almost certainly did not hit a freighter
> > > head on, her weak and feeble bowsprit (made from thin-walled, spiral
> > > welded steel more normally used for drainpipes and similar, non
> > > load-bearing structures) bent because of the strain put on it by the
> > > genoa. Hitting the freighter is simply a cover story made up by Reid
> > > Stowe because he doesn't want to admit that his boat is a slowly sinking
> > > POS.
> > > As for Fer-A-Lite, as far as I'm aware it's reasonably similar to
> > > ferrocement, only without most of the advantages. The main problem with
> > > Fer-A-Lite is that the steel and resin used to construct it
> > > expand/contract at vastly different rates (steel and cement do so at
> > > about the same rate), making it pretty much inevitable that the hull
> > > will crack and crumble over time (something that shouldn't happen to a
> > > well-made ferrocement hull).
> > > If you haven't already, I suggest checking out
> > > 1000daysofhell.blogspot.com - a site with a somewhat different view of
> > > Reid & Soanya's attempt to drift around the world for three years or so.
> > > There's also a thread on sailinganarchy.com, but I don't suggest looking
> > > at that unless you've got a lot of time on your hands (it's currently at
> > > over 8,400 posts and rapidly getting bigger).
> > > Dan Burrill
> > >Thanks Dan,
> > I needed fresh info.
> > Hal
> > - no cursing, flaming, trolling, spamming, respamming, or flogging dead
> > horses
> > - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930, Fax:
> > (978) 282-1349
> > Yahoo! Groups Links
>1000daysofhell was an eye-opener. See where a little mis-information will take one.
Thanks for the corrections.
Hal
-p
> --- Inbolger@yahoogroups.com, Dan Burrill <dan@...> wrote:
> > > Hit a freighter
> > > Hal Gordon
> > > _
> > > .ferrocement
> > POS.
> > Dan Burrill
> >Thanks Dan,
> Hal
> horses
> (978) 282-1349
> > Hit a freighter
> > Hal Gordon
> > _
> > .ferrocement
> POS.
> Dan Burrill
>Thanks Dan,
Hal
> Hit a freighter
> Hal Gordon
> _
> .ferrocement
POS.
Dan Burrill
Has anyone used this product? The 1,000 day sailboat has me intriqued. Hit a freighter
Hal Gordon
