Re: Small Clam Skiff
Cool!!. Pics!! Must have construction pics!! Gad, Paul, you're really
up and running on this one. Do you have insider knowledge that the
Rideau will be open early this year <G>>
Bryant
--- Inbolger@yahoogroups.com, "Paul McLellan" <paulmclellan@...> wrote:
> Progress is fast on this boat. Yesterday I assembled the sides, transom
> and frames. I did it upright on two saw horses and dry fit everything
> first. It went together like a dream, with no adjustments required.
> Then I took it apart, cut the notches for the chines, gunwhales and
> limber holes and glued it together. This is a good looking boat for a
> box. The sheer lines and forward rocker are sweet and it looks better
> than I thought it would. This morning I removed all the screws and
> will start to glue in he chine logs and prepare for the bottom. I
> think a layer of 1" llumber for the shoe then glassed AND a 2 x 4
> sounds interesting and I will consider this. Since I am a use to
> destruction type and beach boats under all sorts of circumstance, the 2
> x 4 would be sacraficial and provide significant area for side drift
> and turning. It would also sit well on the trailer.
> before assembling, I had faired the sides, frames and glassed both
> sides of the bottom so very little finishing will be required to meet
> my orange peel standard.
> All in all this boat has been a great experience, cheap so far and will
> make a great work boat.
> I had considered putting about 3 inches of rocker aft since it will be
> a hull speed boat most of the time but declined. I do see a lot of
> merit in this approach for someone who wants a larger, practical human
> or electric powered craft.
> Build on but use your boats. regards Paul
I like its all business style.
I was thinking along the same lines, as designed, it would be very
tough to pull up a beach.
Build it your way and give it a try.
Obviously, you will loose the stability from the weight of the
bottom.
If you get fex in the sides or bottom, add a splash rail to the
sides and bilge strips to the bottom, or try one 1/2" shoe.
I like the 2x4 keel as well, would certainly help with tracking.
Good luck and keep us posted.
Sloppy
--- Inbolger@yahoogroups.com, "donschultz8275" <donschultz@...>
> According to the essay in "BOATS WITH AN OPEN MIND", the design
was
> intended to be a rugged boat which would carry substantial power.
> IMO the reduced scantlings should work ok for the smallest motor.
> It seems possible that once on plane w' the 9.9 there MAY be an
issue
> with directional stability because of the shallower "shoe". A
quick
> fix will be adding a 2x4 down the middle of the shoe. If there is
> any issue with the bottom flexing in heavy chop, you could add a
> couple of 2X4s across as frames to stiffen things. But hey,
that's
> just a guess.
> I would build it light as you are thinking. If there are problems
> they are easily fixed.
> Don
> --- Inbolger@yahoogroups.com, "Paul McLellan" <paulmclellan@>
> wrote:
> > I would be interested to hear any comments on the performance of
> the
> > small Clamskiff. We were so impressed with the performance of
> > Junebug last summer I was inspired to continue the fleet.
> > I am building the small clam skiff from the plan in Dynamite
> Paysons
> > newest book. It will be lightweight with 1/4 inch sides and
> frames,
> > with only one layer of 1/2 inch ply on the bottom. the sides,
> bottom
> > and frame panels will be glassed, with an additional layer of
glass
> on
> > the forward bottom. I plan to use 1x8 inch lumber for the skid
> panel
> > for the bottom. Hopefully this boat will run adequately with
> Honda
> > 2 hp as a lightweight utility, workboat and in a pinch can be
> carried
> > on the roof of the Houseboat the Happy adventure. In the off
> season I
> > could use the 9.9 yamaha on the clamskiff for more adventures on
> the
> > colder water of the St. lawrence and Ottawa Rivers in early
spring
> and
> > late fall. I do have aspirations to make a davit for the Happy
> > adventure with the capicity to lift the clamskiff on and off the
> roof
> > but this is still in the thinking phase. Woohoo another boat
for
> the
> > fleet and the ever growing pile of boat in the backyard.
According to the essay in "BOATS WITH AN OPEN MIND", the design was
It seems possible that once on plane w' the 9.9 there MAY be an issue
with directional stability because of the shallower "shoe". A quick
couple of 2X4s across as frames to stiffen things. But hey, that's
just a guess.
Don
> small Clamskiff. We were so impressed with the performance of the
Paysons
frames,
bottom
> and frame panels will be glassed, with an additional layer of glass
on
panel
> for the bottom. Hopefully this boat will run adequately with the
Honda
carried
season I
> colder water of the St. lawrence and Ottawa Rivers in early spring
roof
> but this is still in the thinking phase. Woohoo another boat for
You go Paul! But you have to bring it to Bruce's Messabout.
Bryant
> I would be interested to hear any comments on the performance of the
> I am building the small clam skiff from the plan in Dynamite Paysons
> newest book. It will be lightweight with 1/4 inch sides and frames,
> with only one layer of 1/2 inch ply on the bottom. the sides, bottom
> and frame panels will be glassed, with an additional layer of glass on
> the forward bottom. I plan to use 1x8 inch lumber for the skid panel
> for the bottom. Hopefully this boat will run adequately with the Honda
> 2 hp as a lightweight utility, workboat and in a pinch can be carried
> on the roof of the Houseboat the Happy adventure. In the off season I
> could use the 9.9 yamaha on the clamskiff for more adventures on the
> colder water of the St. lawrence and Ottawa Rivers in early spring and
> adventure with the capicity to lift the clamskiff on and off the roof
> but this is still in the thinking phase. Woohoo another boat for the
