Re:Black Skimmer weight
Oh yeah, that 2700 lb weight includes 4.5hp Evinrude two-cylinder two-stroke
long-shaft, AND group 24 deep-cycle battery.
Wayne Gilham
My Black Skimmer has been weighed at a truck-scale (boat with trailer, then
empty trailer) - confirming actual boat weight is 2700 lb, including masts
and rig. For what it's worth, this boat has the full steel-plate ballast
as-designed, also has about 150 lb of lead-pigs in the bow to counteract the
much lighter hollow Spruce mast now fitted (compared to the original
solid-timber mast as-designed). So this one is pretty much per Phil's
drawings. Trailer is a 3000#-rated single-axle trailer with full roller
support - it weighs about 700 lb, for towing weight of 3400 lb, CONFIRMED.
Wayne Gilham
Tacoma WA
> On Payson's web site the bare hull weight for the Black Skimmer says
> 1200, displacement 2800. It also says 500lbs ballast. Is the weight for
> trailering 1200 plus mast batteries, outboard and sails? I would
think a
> 2000 lb trailer with. an extended tongue would work. Anybody know
> different.
> HJ
I would put the trailerable weight more at around 3,000 lbs, which is
still very light for a 25' boat. Independant Boat Haulers launch and
retrieve mine and they often remark on how light it is.
trailering 1200 plus mast batteries, outboard and sails? I would think a
different.
