Re: [bolger] Re: -Car top boat weight?
I don't know, Rick..not sure if any kind of goat would be comfortable
for a guy that large...you might wanta think about gettin' a burro, maybe a
small horse.
Tyson in Galveston
Biggest Grammy Award surprises of all
time on AOL Music.
(http://music.aol.com/grammys/pictures/never-won-a-grammy?NCID=aolcmp00300000002548)
Speaking of Cartoper, do you think it would be a comfortable goat for a 6' 3" guy and one companion?
Rick
----- Original Message ----
Sent: Saturday, February 9, 2008 2:36:20 PM
Subject: [bolger] Re: -Car top boat weight?
--- In bolger@yahoogroups. com, "eep_05" <eep_05@...> wrote:
>> Is this boat too heavy for me to use as a cartoper?
> I usually hear 80 lbs as a rule of thumb, but how much of a stretch
is
> 100 lbs for a sedan with roof racks? I'm not lifting onto a truck or
van.
> thanks, eep
I car topped a 13'10" 130lb Laser all over North America, and I never
had a problem, at all, getting it on or off of the truck by myself.
The secret is to lift one end at a time . . . .
Good luck!
Dave Gentry
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now.http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
is
van.
> thanks, eep
Good luck!
Dave Gentry
I am roughly same ht & wt. 100lb would not be too much of a stretch if
properly done. 120 would be too much, so not much room for growth. Watch
the weight rating on the rack. My Outback wagon is rated for 100lb.
Remember that you must also carry the rig.
Unless you have an overwhelming need to roll your own, I think you should
consider something like "Cartopper" available from H.H. Payson at
http://www.instantboats.comfor $40
Christopher C. Wetherill
eep_05
Sent: Friday, February 08, 2008 1:28 PM
Subject: [bolger] -Car top boat weight?
I'm trying to design / build a sailboat to explore Casco bay and the
New meadows aria.
I have settled on a 12 foot flat bottom stitch and glue skiff.
However, if I build out of 5.2 mm plywood at 20 lbs per sheet, then by
the time I add air boxes and decks to make the hull stiff and buoyant,
adding glass and glue it is close to 100 lbs. I am 72" and 200 lbs.
I usually hear 80 lbs as a rule of thumb, but how much of a stretch is
100 lbs for a sedan with roof racks? I'm not lifting onto a truck or van.
thanks, eep
> New meadows aria.
van.
> thanks, eep
If you're careful, you can build a ply 12 footer alot lighter than
that. Should be able easy enough to get it around 75 lbs. You'll be
alot happier lifting that on the roof than a hundred pounder. That and
few roof racks these days will hold 100 lbs. happily.
Bill H.
New meadows aria.
thanks, eep
