Re: Jessie Cooper isometrics
Nice modelling Bruce.
JC Tomboy is coming along now that the weather is warming up. February
has been grand here in Seattle. I'm getting set up to do a birdsmouth
mainmast replacement. Then glass the new bottom - with I think 3 or
more layers of 6 oz - 'cause it sticks to the bottom better than 10oz.
Which at this point is (not) upside down.
Paul
Paul
>http://flickr.com/photos/hallman/2294982362/
> I keep coming back to Jessie Cooper, which seems to hit just exactly
> the sweet spot for a perfect marina cruiser sailboat.
--- Inbolger@yahoogroups.com, "loosemoosefilmworks"
<loosemoosefilmworks@...> wrote:
Thanks Bob for the comments regarding the lug - I've looked LM II
lustingly but the is too big.
When I built my Wish II I changed the smallish jib headed main
to a standing lug and added some extra ballast to compensate.
Jim
Jim
>three layers of 12MM)
> We built Loose Moose (our Jessie Cooper) using a plywood bottom (
> with two layers of 10 OZ glass over all and overkill on the chinehaving tape plus both bottom
> coures overlap the chine as well as the side panel glass...whichheld up very well and last we
> heard was still going strong!better than anyone would have
> It was certainly a great boat... quite liveable and it sailed far
> guessed. I certainly loved the rig and if there was one mistake wemade in the design of
> Loose Moose 2 was adopting the Gaff rig in favor of the lug.
> Bob Wise
>http://boatbits.blogspot.com/
Thanks Bruce;
Those were my thoughts also and I'm thinking of two or three layers of
10oz. glass - but I may also decide do a narrower design such as
Skillygallee or WDJ - my Wish II is okay for short trips but not
capacious enough for more extended cruising (and I want build another
boat QED!!).
jim
boat QED!!).
jim
> On Tue, Feb 26, 2008 at 6:54 PM, james caldwell
> <jcaldwell29@...> wrote:
> > Bruce,
> > Have you heard of anyone taking a Jessie Cooper on
> > longer - 'offshore' - trips?
> Well, Bob and Sheila (of Loose Moose fame) built a Jessie Cooper and
> sailed it extensively up and down the English Channel and had only
> good things to say about her. Personally, my reply to the bottom
> fastening question would be to but a large fillet inside and triple
> tape the outsides of that chine with fiberglass and epoxy. Jessie
> Cooper has massive reserve buoyancy, and would bob like a cork.
one thing to consider is that marinas charge a 30ft minimum so the
as29 may be a better choice
mike
mike
We built Loose Moose (our Jessie Cooper) using a plywood bottom ( three layers of 12MM)
with two layers of 10 OZ glass over all and overkill on the chine having tape plus both bottom
coures overlap the chine as well as the side panel glass...which held up very well and last we
It was certainly a great boat... quite liveable and it sailed far better than anyone would have
guessed. I certainly loved the rig and if there was one mistake we made in the design of
Bob Wise
Bob Wise
> Bruce,
Bruce,
longer - 'offshore' - trips? Phil said in his book that
he didn't trust the cross planking fastenings for
such a large (wide) bottom, but I'm figuring they could
be made strong enough (by a couple of methods).
Jim
Jim
