Re: boats with plumb sides.
Thanks, Michael Walther. But alas, it's too late for me.
My boat is kaput, and in a landfill by now. But 9 seasons was enough,
and more than I'd hoped. On the next couple of boats.
-Chris
-Chris
Hi Chris, Something went wrong with Yahoo. The final line is: Good luck and wishing you success with the cover, Mike
--- On Sun, 4/13/08, Michael Walther <michawalth3@...> wrote:
> From: Michael Walther <michawalth3@...>
> Subject: Re: [bolger] Re: boats with plumb sides.
> To:bolger@yahoogroups.com
> Date: Sunday, April 13, 2008, 11:08 PM
> Hi Chris, At this point I think your best bet would be to
> try this suggestion from Douglas Pollard, "I built a
> cover for her using A frames and a ridge pole covered with
> canvas with both ends open It covered the whole boat in
> the winter. The mast was removed in the fall and stored in
> a shed.
> During the summer, a short section of the canvas was
> used to cover
> the cockpit and there again a short section of the A frame
> held it up.
> Worked good. I would row out to her in a dingy remove the
> cover and put
> it in the dingy along with the frame and leave the dingy
> tied to the
> mooring while I went sailing for a day or two. A little
> trouble but
> worked great".
> I have seen this in illustrations and photos of boats in
> winter on land and in water. It must work I've seen it
> in boat yards personally. As for your towel worry, wet
> towels will not rot the wood any faster than sitting water.
> After driving miles out of your way the simple difference is
> a lot less time and work wiping up. Leaving you time to
> properly cover your boat.
> --- On Sun, 4/13/08, Chris Crandall <crandall@...>
> wrote:
> > From: Chris Crandall <crandall@...>
> > Subject: [bolger] Re: boats with plumb sides.
> > Date: Sunday, April 13, 2008, 7:32 PM
> > > Hi Group, From everything that I've read here
> it
> > sounds more like the
> > > problem is not rain but condensation. If
> that's
> > the case then you
> > > need to figure some way of getting air
> circulation in
> > there and maybe
> > > also tilt boat & leave towels at low point
> in the
> > boat to absorb the
> > > water so it doesn't sit (must change them
> > daily:).
> > My problem is the lack of air circulation *underneath*
> the
> > standing
> > water that comes from precipitation. Leaving a towel
> in a
> > boat is an
> > invitation to rot--it holds water. Sure, "change
> them
> > daily" but then
> > why not just wipe things out daily? The problem is in
> not
> > being able to
> > check on my boat every day, being miles out of my way,
> and
> > with access
> > rendered impossible when snow or ice is on the ground.
> > Sure, the problem is condensation, if you mean the
> > condensation that
> > comes down from clouds.
> > - no cursing, flaming, trolling, spamming, respamming,
> or
> > flogging dead horses
> > - stay on topic, stay on thread, punctuate, no
> 'Ed,
> > thanks, Fred' posts
> > - Pls add your comments at the TOP, SIGN your posts,
> and
> > snip away
> > - Plans: Mr. Philip C. Bolger, P.O. Box 1209,
> Gloucester,
> > MA, 01930, Fax: (978) 282-1349
> > - Open discussion:
> >bolger_coffee_lounge-subscribe@yahoogroups.comYahoo!
> > Groups Links
> Do You Yahoo!?
> Tired of spam? Yahoo! Mail has the best spam protection
> around
>http://mail.yahoo.com
> - no cursing, flaming, trolling, spamming, respamming, or
> - stay on topic, stay on thread, punctuate, no 'Ed,
> thanks, Fred' posts
> - Pls add your comments at the TOP, SIGN your posts, and
> snip away
> - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester,
> - Open discussion:
> Groups Links
Do You Yahoo!?
Hi Chris, At this point I think your best bet would be to try this suggestion from Douglas Pollard, "I built a cover for her using A frames and a ridge pole covered with canvas with both ends open It covered the whole boat in the winter. The mast was removed in the fall and stored in a shed.
During the summer, a short section of the canvas was used to cover
the cockpit and there again a short section of the A frame held it up.
Worked good. I would row out to her in a dingy remove the cover and put
it in the dingy along with the frame and leave the dingy tied to the
mooring while I went sailing for a day or two. A little trouble but
worked great".
I have seen this in illustrations and photos of boats in winter on land and in water. It must work I've seen it in boat yards personally. As for your towel worry, wet towels will not rot the wood any faster than sitting water. After driving miles out of your way the simple difference is a lot less time and work wiping up. Leaving you time to properly cover your boat.
worked great".
> > Hi Group, From everything that I've read here it
> > problem is not rain but condensation. If that's
> the case then you
> > need to figure some way of getting air circulation in
> there and maybe
> > also tilt boat & leave towels at low point in the
> boat to absorb the
> daily:).
> My problem is the lack of air circulation *underneath* the
> standing
> water that comes from precipitation. Leaving a towel in a
> boat is an
> invitation to rot--it holds water. Sure, "change them
> daily" but then
> why not just wipe things out daily? The problem is in not
> being able to
> check on my boat every day, being miles out of my way, and
> with access
> condensation that
> thanks, Fred' posts
> snip away
> - Open discussion:
> Groups Links
Do You Yahoo!?
In the group of people that are into model railroad and live steam they have a saying "Be one, teach one." I see the same thing in radio controlled aircraft and in the EAA the whole thing is getting people into building and flying light aircraft. On any given weekend there are people teaching or getting people involved with aircraft.
The sad part is a lot of people that are into boat building don't look at it the way, the EAA does when it comes to aircraft and flight. Some of the best things I remember are the times I was helping Dad work on the boats or the airplanes that he had at the time.
I know a lot of us are past having little ones around but there may be one of the kids next door that would like to watch and see things happen. You never know you may just light the fire under a new skipper!
Blessings Krissie
rick barnes <barnesrickw@...> wrote: That's the way it should be, handing down tricks of the trade. That's why I'm disappointed in the two old timers who build boats in my area who think it's best to keep a secret. Maybe they are afraid of giving away something valuable, who knows. I live in Muskegon on the shores of Lake Michigan, and I drive 25 miles inland to find a guy to teach me how to build a boat. The irony kills me. But you can bet as soon as I have learned what I think I have needed to learn, I'll pass it along to those who come looking. I can't wait to be an old timer.... In a way.
----- Original Message ----
Sent: Saturday, April 12, 2008 11:20:39 PM
Hi Kristine, And God bless those old timers for doing it, you too if you thank them for doing it. Mike
Blessings Krissie
--- On Sat, 4/12/08, Kristine Bennett <femmpaws@yahoo. com> wrote:
> From: Kristine Bennett <femmpaws@yahoo. com>
> To: bolger@yahoogroups. com
> Date: Saturday, April 12, 2008, 8:53 PM
> Doug I remember the same thing only I grew up around the
> fishing boats and work boats here in the Northwest.
> I remember watching one of the old timers using a calking
> iron doing the seams on a couple of planks that were just
> replaced on one of the Alaska fish boats.
> Yep an art in it's self.
> When I got a little older I helped Dad replace a few planks
> on one boat he was working on getting it ready for the
> fishing season. Then the next years Dad started building
> his own 40 foot troller for Alaskan water. I was right in
> there after school and weekends. As far as I know the
> Shinaku is still fishing in Alaska.
> Yep the old days are going away but every now and then you
> happen into a boat yard and the old timers are still there
> handing down their tricks to the trade to any one that
> wants to learn!
> Blessings Krissie
> From: Douglas Pollard <Dougpol1@comcast. net>
> That is not really true that boats were not intended to
> last long.. I
> came from the wooden boat era and boats were expected to
> last a
> lifetime and to some degree so were automobiles. After all
> 1930's
> automobiles well maintained would still be in use today
> had we not been
> convinced to throw everything away. They both took
> maintenance though.
> The boat I had in my early twenties was 54 years old when
> I got her.
> Many work boats were over a hundred years old.
> To start with boats were build out of very old trees,
> only. If a
> builder ordered lumber he went to look at it and if the
> grain was not
> tight enough it would not be bought. Many builders cut
> their own timber
> cut it up and air dried it. But there was more, they
> poisoned it by
> every means available with. lead. tin oxide, copper and
> arsenic. Pine
> tare, pitch and naphtha were used as well.
> In the 1950's when the first glass boats came out they
> were poo,
> pooed by boat people because they were only expected to
> last thirty
> years. A fact that was covered up by builders as soon as
> possible. It
> was the educated upper middle class that bought glass
> sailboats. Fiber
> glass did not catch on bating people for a while. It was
> the none
> boating boaters that bought them, Doctors, lawyers and
> business men.
> I remember the Captain of a big working skipjack saying he
> hit the
> newly built Chesapeake bay bridge and broke the mast off
> his boat. He
> was amazed that they cut a piece and spliced the mast and
> in his words,
> "There weren't narrey a screw nore a nail
> in"er no place. Just like I
> thought I had to replace it in less than 25 years. I new
> it weren't
> no good!
> If you kept a sail boat in a boat yard ( no marinas then)
> you kept
> it on a mooring covered so the wind could blow through
> her. You kept
> an A frame and canvas on her with both ends open during
> the winter. The
> mast and rigging was removed and stored in a shed. Spring
> was a big
> deal we worked on boats through April and May and it
> usually took
> that long to replace rot caulking and paint. If you had a
> finely
> built sailboat with steam bent frames and maybe white
> cedar or juniper
> planking and the frames and stem went bad. You planned
> ahead and
> replaced the stem one year and took half the frames the
> next and the
> rest of them the third year. Canvas covered decks were
> good for at
> least 20 years. The transom when bad along with the plank
> ends so I cut
> a foot off the boat length and replace the transom.
> I was young and didn't have the know how but the
> boatyard was full
> of older men that did. We all got together in the evenings
> at the boat
> yard and A kid like me got the advice of all and usually
> some real
> physical help. There was a wealth of knowledge available
> to all who
> needed it. In the yard where I kept my boat the owner of
> the yard was a
> Naval Architect and a boat builder and he was always
> available to help.
> These older men were grateful to us younger men for
> carrying on a
> tradition that they loved so their advice was freely
> given.
> This spring time comradely is the thing I miss most in
> boating
> today. It was hard work but the evenings by a fire where
> we all set
> around talking boats every Saturday night in April and May
> were
> wonderful. There was usually someone with a Harpsichord or
> banjo and
> even the yard owner and family would come out and join in.
> As the place became a marina and it filled with glass
> throw away
> boats all this began to change. Even the conversations
> changed to
> things other than boats.
> By the way I think glass boats are the handiest thing
> since breasts
> on a young girl. They allowed people to have and afford
> boats they wold
> never otherwise have. Back in the days of Sam Crocker,
> Hershoff, and
> other historical designers only very determined upper
> middle class
> people could have a fine sleek sailboat built. Us poor
> folks as
> tradesmen where known to be built our own slightly crude
> Chesapeake
> style boats or bought used work boats. Even these were a
> huge
> investment in money an labor and they were intended to be
> handed down
> to children and grand children. No one intended a boat to
> only last 30
> years. That would have been a supreme foolishness and a
> very poor use
> of money and time. Back when I was a child these bay boats
> were fishing
> boats. We used them to crab, oyster, fish and even shoot
> squires and
> ducks from. They were expected to pay their way and then
> some. They
> were sailboats or row boats because engines were hard to
> come by, not
> because people loved to sail but that was the way to get
> out in the bay.
> The only truck we had with yacht clubs was to set in our
> boat
> fishing and listening to the music wafting across the
> water. If close
> enough you could see people dressed in tux and evening
> gown walking and
> talking on the vast front porch of the old one time house
> of illrepute.
> Their voices traveled across the water at night and we
> could her talk of
> investments, the stock market and high finance all a
> foreign language to
> us. I know how it must have felt to be a peasant listening
> to the good
> time being had in a royal castle. It was enough just to
> listen.
> We did not keep boats in a boat yards we kept them at home
> when I
> was a child but in my twenties sailing and boating became
> a hobby. We
> were more prosperous than our fathers and as a machinist
> in Bethlehem
> Steel company I was really surprised and maybe even a
> little resentful
> to hear that I was middle class. I was more interested in
> following in
> my family tradition of being better off than most other
> poor folks. Now
> I found myself at the bottom of the middle class and that
> seemed somehow
> a step down. I had to go into the Machine shop business
> with my eyes
> set on being at least upper middle class. Never wanted to
> be rich as I
> would again feel at the bottom.
> Sorry I have wondered from my subject. A habit!
> Doug
Do You Yahoo!?
To: bolger@yahoogroups.com
> wants to learn!
> Blessings Krissie
> last long.. I
> last a
> 1930's
> had we not been
> maintenance though.
> I got her.
> only. If a
> grain was not
> their own timber
> poisoned it by
> arsenic. Pine
> were poo,
> last thirty
> possible. It
> sailboats. Fiber
> the none
> business men.
> hit the
> his boat. He
> in his words,
> it weren't
> no good!
> you kept
> her. You kept
> the winter. The
> was a big
> usually took
> finely
> cedar or juniper
> ahead and
> next and the
> good for at
> ends so I cut
> boatyard was full
> at the boat
> some real
> to all who
> the yard was a
> available to help.
> carrying on a
> given.
> boating
> we all set
> were
> banjo and
> throw away
> changed to
> since breasts
> boats they wold
> Hershoff, and
> middle class
> folks as
> Chesapeake
> huge
> handed down
> only last 30
> very poor use
> were fishing
> squires and
> some. They
> come by, not
> out in the bay.
> boat
> water. If close
> gown walking and
> of illrepute.
> could her talk of
> foreign language to
> to the good
> listen.
> when I
> a hobby. We
> in Bethlehem
> little resentful
> following in
> poor folks. Now
> seemed somehow
> with my eyes
> be rich as I
> Doug
> ____________ _________ _________ _________ _________ __
> Do You Yahoo!?
> around
> http://mail. yahoo.com
> thanks, Fred' posts
> snip away
> - Unsubscribe: bolger-unsubscribe@ yahoogroups. com
> - Open discussion:
> bolger_coffee_ lounge-subscribe @yahoogroups. com Yahoo!
> Groups Links
Do You Yahoo!?
Do You Yahoo!?
> Hi Group, From everything that I've read here it sounds more like theMy problem is the lack of air circulation *underneath* the standing
> problem is not rain but condensation. If that's the case then you
> need to figure some way of getting air circulation in there and maybe
> also tilt boat & leave towels at low point in the boat to absorb the
> water so it doesn't sit (must change them daily:).
water that comes from precipitation. Leaving a towel in a boat is an
invitation to rot--it holds water. Sure, "change them daily" but then
why not just wipe things out daily? The problem is in not being able to
check on my boat every day, being miles out of my way, and with access
Sure, the problem is condensation, if you mean the condensation that
Kristine as a boat builder your father was a craftsman and in
another sense he was a craftsmen as a fisherman though we hardly ever
think of a boat captain and fisherman as a craftsman it's never the less
true. There is craft in those professions. The craftsman wants the
best tools he can get. Your father built his boat to be a tool, but
even more it needed to be a well looked after friend. It had to get his
catch to market and him home, under the worst conditions. I have heard
watermen say a hundred times, referring to their boats, I take care of
her and she takes care of me.
I worked some in later years as a dock master in a marina. You never
ask a waterman ,can I check your oil, when fueling up ? It's not that
you don't want to sell him oil you just know that no one is going to
check the oil, on his engine, but him.
The boat shop boat builder is today the last of a breed. It's about
the only trade left where you can build someone something from start to
finish and watch him sail or motor out of the harbor. The house builder
is kind of the same but he is being replaced by manufactured homes
though there will always be some builders around.i The boat builder can
go out on the water and say look over there she is one of mine. He
better do a good job because he has to live with his product being all
around him for a long time.
Having lived in a small waterfront community a lot of years I know
this. As a machinist I was treated at the morning coffee spot with some
respect by the boat builders because I supplied a needed machine shop
service to them. But they were treated with respect that bordered on
awe by the whole community. These guys were believe to be people of
character.
People helping people back in years past, I think had as much to do
with asking questions as anything else. I have seen people struggle and
sweat trying to do something to a boat when it's pretty clear they had
no idea what they were about. In todays world it seems people are
afraid to ask, like they might annoy someone or show a little
ignorance. We on these lists for the most part are playing with boats
and playing with building them, Whoa! Of course we are ignorant. Our
expertise lies in our full time jobs, we hope.
Watermen have the time and will take the time to tell you how to do
something on a boat. They are usually flattered by the idea of giving
you advice. He or nowdays she will usually yell to his mate come back
here and finish knocking this pin out I'm going over here for a minute.
He will come over and often help as well as advise. If you aren't
careful you will have six other water men hanging around giving advice.
If You live near Ginny her on the bay in Virgina and they are all
Ginnymen, they will all be talking in their semi old English and so
fast, so as, you won't understand a word they say.
One thing they will never, ever do is walk over and give you the
benefit of there know how unless you ask for it. That would be
considered sticking their nose in where it don't belong.
Passing on know how is not dead, have to ask for it. It would be
considered impolite to give advice without and invitation.
The advise is still there though.
Doug
character.
Doug
> Doug I remember the same thing only I grew up around the fishing boats
> I remember watching one of the old timers using a calking iron doing
> the seams on a couple of planks that were just replaced on one of the
> Alaska fish boats.
> When I got a little older I helped Dad replace a few planks on one
> boat he was working on getting it ready for the fishing season. Then
> the next years Dad started building his own 40 foot troller for
> Alaskan water. I was right in there after school and weekends. As far
> as I know the Shinaku is still fishing in Alaska.
> Yep the old days are going away but every now and then you happen into
> a boat yard and the old timers are still there handing down their
> tricks to the trade to any one that wants to learn!
> Blessings Krissie
> From: Douglas Pollard <Dougpol1@...
> <mailto:Dougpol1%40comcast.net>>
> That is not really true that boats were not intended to last long.. I
> came from the wooden boat era and boats were expected to last a
> lifetime and to some degree so were automobiles. After all 1930's
> automobiles well maintained would still be in use today had we not been
> convinced to throw everything away. They both took maintenance though.
> The boat I had in my early twenties was 54 years old when I got her.
> To start with boats were build out of very old trees, only. If a
> builder ordered lumber he went to look at it and if the grain was not
> tight enough it would not be bought. Many builders cut their own timber
> cut it up and air dried it. But there was more, they poisoned it by
> every means available with. lead. tin oxide, copper and arsenic. Pine
> In the 1950's when the first glass boats came out they were poo,
> pooed by boat people because they were only expected to last thirty
> years. A fact that was covered up by builders as soon as possible. It
> was the educated upper middle class that bought glass sailboats. Fiber
> glass did not catch on bating people for a while. It was the none
> boating boaters that bought them, Doctors, lawyers and business men.
> I remember the Captain of a big working skipjack saying he hit the
> newly built Chesapeake bay bridge and broke the mast off his boat. He
> was amazed that they cut a piece and spliced the mast and in his words,
> "There weren't narrey a screw nore a nail in"er no place. Just like I
> thought I had to replace it in less than 25 years. I new it weren't
> no good!
> If you kept a sail boat in a boat yard ( no marinas then) you kept
> it on a mooring covered so the wind could blow through her. You kept
> an A frame and canvas on her with both ends open during the winter. The
> mast and rigging was removed and stored in a shed. Spring was a big
> deal we worked on boats through April and May and it usually took
> that long to replace rot caulking and paint. If you had a finely
> built sailboat with steam bent frames and maybe white cedar or juniper
> planking and the frames and stem went bad. You planned ahead and
> replaced the stem one year and took half the frames the next and the
> rest of them the third year. Canvas covered decks were good for at
> least 20 years. The transom when bad along with the plank ends so I cut
> I was young and didn't have the know how but the boatyard was full
> of older men that did. We all got together in the evenings at the boat
> yard and A kid like me got the advice of all and usually some real
> physical help. There was a wealth of knowledge available to all who
> needed it. In the yard where I kept my boat the owner of the yard was a
> Naval Architect and a boat builder and he was always available to help.
> These older men were grateful to us younger men for carrying on a
> tradition that they loved so their advice was freely given.
> This spring time comradely is the thing I miss most in boating
> today. It was hard work but the evenings by a fire where we all set
> around talking boats every Saturday night in April and May were
> wonderful. There was usually someone with a Harpsichord or banjo and
> As the place became a marina and it filled with glass throw away
> boats all this began to change. Even the conversations changed to
> By the way I think glass boats are the handiest thing since breasts
> on a young girl. They allowed people to have and afford boats they wold
> never otherwise have. Back in the days of Sam Crocker, Hershoff, and
> other historical designers only very determined upper middle class
> people could have a fine sleek sailboat built. Us poor folks as
> tradesmen where known to be built our own slightly crude Chesapeake
> style boats or bought used work boats. Even these were a huge
> investment in money an labor and they were intended to be handed down
> to children and grand children. No one intended a boat to only last 30
> years. That would have been a supreme foolishness and a very poor use
> of money and time. Back when I was a child these bay boats were fishing
> boats. We used them to crab, oyster, fish and even shoot squires and
> ducks from. They were expected to pay their way and then some. They
> were sailboats or row boats because engines were hard to come by, not
> because people loved to sail but that was the way to get out in the bay.
> The only truck we had with yacht clubs was to set in our boat
> fishing and listening to the music wafting across the water. If close
> enough you could see people dressed in tux and evening gown walking and
> talking on the vast front porch of the old one time house of illrepute.
> Their voices traveled across the water at night and we could her talk of
> investments, the stock market and high finance all a foreign language to
> us. I know how it must have felt to be a peasant listening to the good
> time being had in a royal castle. It was enough just to listen.
> We did not keep boats in a boat yards we kept them at home when I
> was a child but in my twenties sailing and boating became a hobby. We
> were more prosperous than our fathers and as a machinist in Bethlehem
> Steel company I was really surprised and maybe even a little resentful
> to hear that I was middle class. I was more interested in following in
> my family tradition of being better off than most other poor folks. Now
> I found myself at the bottom of the middle class and that seemed somehow
> a step down. I had to go into the Machine shop business with my eyes
> set on being at least upper middle class. Never wanted to be rich as I
> Doug
> Do You Yahoo!?
>http://mail.yahoo.com<http://mail.yahoo.com>
--- On Sat, 4/12/08, Kristine Bennett <femmpaws@...> wrote:
> From: Kristine Bennett <femmpaws@...>
> wants to learn!
> Blessings Krissie
> From: Douglas Pollard <Dougpol1@...>
> last long.. I
> last a
> 1930's
> had we not been
> maintenance though.
> I got her.
> only. If a
> grain was not
> their own timber
> poisoned it by
> arsenic. Pine
> were poo,
> last thirty
> possible. It
> sailboats. Fiber
> the none
> business men.
> hit the
> his boat. He
> in his words,
> it weren't
> no good!
> you kept
> her. You kept
> the winter. The
> was a big
> usually took
> finely
> cedar or juniper
> ahead and
> next and the
> good for at
> ends so I cut
> boatyard was full
> at the boat
> some real
> to all who
> the yard was a
> available to help.
> carrying on a
> given.
> boating
> we all set
> were
> banjo and
> throw away
> changed to
> since breasts
> boats they wold
> Hershoff, and
> middle class
> folks as
> Chesapeake
> huge
> handed down
> only last 30
> very poor use
> were fishing
> squires and
> some. They
> come by, not
> out in the bay.
> boat
> water. If close
> gown walking and
> of illrepute.
> could her talk of
> foreign language to
> to the good
> listen.
> when I
> a hobby. We
> in Bethlehem
> little resentful
> following in
> poor folks. Now
> seemed somehow
> with my eyes
> be rich as I
> Doug
> Do You Yahoo!?
> around
> thanks, Fred' posts
> snip away
> - Open discussion:
> Groups Links
Do You Yahoo!?
I finally cut a big (8" diameter) hole in my Windsprint because it is
otherwise impossible to self-rescue when swamped (except by swimming it
to shore). Haven't tried it yet -- waiting for warm water.
Patrick
Patrick
> This is an interesting consideration. Phil frequently comments in his
> writings about keeping thru hulls to a minimum. I have eliminated all that
> were in the EstherMae, including the one (sink) above the water line. Of
> course I am now planning to create scuppers for the forward (pending
> modification) and aft cockpits.
> Caloosarat
Doug I remember the same thing only I grew up around the fishing boats and work boats here in the Northwest.
I remember watching one of the old timers using a calking iron doing the seams on a couple of planks that were just replaced on one of the Alaska fish boats.
When I got a little older I helped Dad replace a few planks on one boat he was working on getting it ready for the fishing season. Then the next years Dad started building his own 40 foot troller for Alaskan water. I was right in there after school and weekends. As far as I know the Shinaku is still fishing in Alaska.
Yep the old days are going away but every now and then you happen into a boat yard and the old timers are still there handing down their tricks to the trade to any one that wants to learn!
Blessings Krissie
no good!
Doug
Do You Yahoo!?
Blessings Krissie
no good!
Doug
Do You Yahoo!?
Fantastic e-mail. Full of nostalgia. I know several old timers that build wooden boats, but for some reason, they wish to keep this skill a secret. It's a shame more people don't pass things along, boats, knowledge, etc like they once did. It was great to hear stories about a time when passing along was the norm. Oh, and my favorite part was my new favorite phrase; "handier than breasts on a young girl". Thanks for passing that along.
Rick
Sent: Saturday, April 12, 2008 9:44:05 AM
no good!
Doug
graeme19121984 wrote:
Do You Yahoo!?
Rick
no good!
Doug
> --- In bolger@yahoogroups. com <mailto:bolger% 40yahoogroups. com>,
> "David C." <d.cassidy@. ..> wrote:
> I wonder what they did before the days of plastic boats?
> They got new boats frequently!
Do You Yahoo!?
no good!
Doug
no good!
Doug
> --- Inbolger@yahoogroups.com<mailto:bolger%40yahoogroups.com>,
Fortunately (I guess) time out of the water is not a problem for boats in Michigan. Air circulation is the key for all of them, I agree with that 100%
Sent: Saturday, April 12, 2008 4:08:01 AM
Hi Group, I Have more info on this. Water must not be allowed to sit on top of tarp, it suffers from a process of osmosis allowing water to seep through, without enough air circulation keeping the moisture stirred up in the air it will settle on the interior surfaces of boat & underside of tarp. The more humidity the more condensation, the amount can be quite shocking. Getting air exchange, fresh air in, stale air out is even better. As for fiberglass boats the latest info (WB mag) is, it must spend 3 months of year out of water to completely dry out. The plastic they are made of also suffers from osmosis causing the layers of glass to de-laminate from each other "blister" or from wood. Epoxy & fabric (glass or more abrasion resistant synthetic) is more water proof. I hope this is helpful, Mike
--- On Sat, 4/12/08, Michael Walther <michawalth3@ yahoo.com> wrote:
> From: Michael Walther <michawalth3@ yahoo.com>
> Date: Saturday, April 12, 2008, 6:57 AM
> more like the problem is not rain but condensation. If
> that's the case then you need to figure some way of
> getting air circulation in there and maybe also tilt boat
> WoodenBoat mag Jan-"Feb 2009" #200 had a great
> article on this subject "Temperature, Humidity, and
> Wood Moisture Content" very good. It stressed air
> circulation in a big way. I highly recommend all should
> subscribe, full of great info on all issues & subjects.
> For those outside Canada, UK & US check your public
> library. If they don't carry it, along with friends,
> very nicely pressure them to get it, I think it's that
> good & that helpful (I'm not paid to say that,
> maybe should be;). Thanks and good luck, Mike
> --- On Fri, 4/11/08, Chris Crandall <crandall@ku. edu>
> wrote:
> > From: Chris Crandall <crandall@ku. edu>
> > To: "No Reply"
> <notify-dg-bolger@ yahoogroups. com>
> > Cc: bolger@yahoogroups. com
> > Date: Friday, April 11, 2008, 6:01 PM
> > > I suspect far more boats have died from being
> left full
> > of water in
> > > the backyard, than sank due to failure of a
> drain
> > plug.
> > This is my case. Two of my outdoor kept boats (the
> only two
> > I've owned)
> > both had significant problems with rainwater. My
> Michalak
> > Harmonica
> > shantyboat died from it.
> > http://www.ace. net.au/schooner/ occam.htm
> > I kept it well tarped and tied down carefully, but as
> I
> > said in an
> > earlier post, I couldn't keep up with weather.
> Kansas
> > weather is not for
> > the faint-at-heart, and I kept the boat a fair piece
> from
> > my home, and
> > during snow, had no access at all to it. Closer winter
> > storage would
> > have added $200 to season costs, more than I had in
> the
> > budget. The boat
> > lasted through nine seasons, which was more than I had
> > guessed during
> > construction, so I'm not unhappy. But if it had
> had a
> > covered storage
> > spot, it would last twice as long, or more.
> > My other boat afflicted with rainwater was a Catalina
> 22.
> > The drain
> > holes in a C-22 work well enough, until leaves cover
> the
> > two drains. The
> > cockpit filled (and it's considerable) , and the
> boat
> > tipped bow up. It
> > was holding A LOT of water. Drained it, cleaned her
> up,
> > sold her for a
> > reasonable price the next season, got a new chair for
> the
> > living room in
> > exchange.
> > I've taken on a little water here and there from
> drain
> > plugs, etc., but
> > it's a minor thing, and a simple maintenance item,
> and
> > water inside the
> > boat while aboard gets noticed fairly quickly,
> I've
> > found.
> or
> 'Ed,
> > thanks, Fred' posts
> and
> > snip away
> Gloucester,
> > - Open discussion:
> > Groups Links
> Do You Yahoo!?
> around
> thanks, Fred' posts
> snip away
> - Open discussion:
> Groups Links
Do You Yahoo!?
Do You Yahoo!?
> --- On Fri, 4/11/08, Chris Crandall <crandall@...>
> > To: "No Reply"
> <notify-dg-bolger@yahoogroups.com>
> > Cc:bolger@yahoogroups.com
> left full
> > of water in
> drain
> > plug.
> only two
> > I've owned)
> Michalak
> > Harmonica
> >http://www.ace.net.au/schooner/occam.htm
> I
> > said in an
> Kansas
> > weather is not for
> from
> > my home, and
> > storage would
> the
> > budget. The boat
> > guessed during
> had a
> > covered storage
> 22.
> > The drain
> the
> > two drains. The
> > cockpit filled (and it's considerable), and the
> boat
> > tipped bow up. It
> up,
> > sold her for a
> the
> > living room in
> > exchange.
> drain
> > plugs, etc., but
> and
> > water inside the
> I've
> > found.
> or
> 'Ed,
> > thanks, Fred' posts
> and
> > snip away
> Gloucester,
> > - Open discussion:
> > Groups Links
> Do You Yahoo!?
> around
> thanks, Fred' posts
> snip away
> - Open discussion:
> Groups Links
Do You Yahoo!?
Hi Group, From everything that I've read here it sounds more like the problem is not rain but condensation. If that's the case then you need to figure some way of getting air circulation in there and maybe also tilt boat & leave towels at low point in the boat to absorb the water so it doesn't sit (must change them daily:).
WoodenBoat mag Jan-"Feb 2009" #200 had a great article on this subject "Temperature, Humidity, and Wood Moisture Content" very good. It stressed air circulation in a big way. I highly recommend all should subscribe, full of great info on all issues & subjects. For those outside Canada, UK & US check your public library. If they don't carry it, along with friends, very nicely pressure them to get it, I think it's that good & that helpful (I'm not paid to say that, maybe should be;). Thanks and good luck, Mike
> To: "No Reply" <notify-dg-bolger@yahoogroups.com>
> > I suspect far more boats have died from being left full
> of water in
> > the backyard, than sank due to failure of a drain
> plug.
> This is my case. Two of my outdoor kept boats (the only two
> I've owned)
> both had significant problems with rainwater. My Michalak
> Harmonica
> I kept it well tarped and tied down carefully, but as I
> said in an
> earlier post, I couldn't keep up with weather. Kansas
> weather is not for
> the faint-at-heart, and I kept the boat a fair piece from
> my home, and
> storage would
> have added $200 to season costs, more than I had in the
> budget. The boat
> guessed during
> construction, so I'm not unhappy. But if it had had a
> covered storage
> My other boat afflicted with rainwater was a Catalina 22.
> The drain
> holes in a C-22 work well enough, until leaves cover the
> two drains. The
> cockpit filled (and it's considerable), and the boat
> tipped bow up. It
> was holding A LOT of water. Drained it, cleaned her up,
> sold her for a
> reasonable price the next season, got a new chair for the
> living room in
> exchange.
> I've taken on a little water here and there from drain
> plugs, etc., but
> it's a minor thing, and a simple maintenance item, and
> water inside the
> boat while aboard gets noticed fairly quickly, I've
> found.
> thanks, Fred' posts
> snip away
> - Open discussion:
> Groups Links
Do You Yahoo!?
That is one of the reasons plastic boats were so popular so fast. Cheaper, and less maintenance. Certainly wasn't because they were more beautiful. In the storage yard where my boat is kept, there are many 1960's plastic boats still around. There are about 3 old wooden ones. One is in the water. None are made of plywood.
Sent: Friday, April 11, 2008 12:10:03 PM
expected to last forever. The common attitude was that a wooden boat
should last a reasonable amount of time (10+ years), and then be
replaced with another wooden boat. Sort of like our present day
attitude about modern automobiles.
Do You Yahoo!?
> I wonder what they did before the days of plastic boats? They must have hadI recall that PCB wrote that in the old days, wooden boats were not
> a way to be able to use the boats outside without them falling apart due to
> the elements.
Do You Yahoo!?
> I suspect far more boats have died from being left full of water inThis is my case. Two of my outdoor kept boats (the only two I've owned)
> the backyard, than sank due to failure of a drain plug.
both had significant problems with rainwater. My Michalak Harmonica
shantyboat died from it.http://www.ace.net.au/schooner/occam.htm
I kept it well tarped and tied down carefully, but as I said in an
earlier post, I couldn't keep up with weather. Kansas weather is not for
the faint-at-heart, and I kept the boat a fair piece from my home, and
during snow, had no access at all to it. Closer winter storage would
have added $200 to season costs, more than I had in the budget. The boat
lasted through nine seasons, which was more than I had guessed during
construction, so I'm not unhappy. But if it had had a covered storage
My other boat afflicted with rainwater was a Catalina 22. The drain
holes in a C-22 work well enough, until leaves cover the two drains. The
cockpit filled (and it's considerable), and the boat tipped bow up. It
was holding A LOT of water. Drained it, cleaned her up, sold her for a
reasonable price the next season, got a new chair for the living room in
exchange.
I've taken on a little water here and there from drain plugs, etc., but
it's a minor thing, and a simple maintenance item, and water inside the
boat while aboard gets noticed fairly quickly, I've found.
Hi Bruce, What they really did in the old days was replace the rotten wood, put back in the water &go on about their business. Thanks, Mike
--- On Fri, 4/11/08, Bruce Hallman <bruce@...> wrote:
> From: Bruce Hallman <bruce@...>
> Date: Friday, April 11, 2008, 4:10 PM
> > the elements.
> were not
> wooden boat
> then be
> present day
> thanks, Fred' posts
> snip away
> - Open discussion:
> Groups Links
Do You Yahoo!?
> the elements.
The problem does not seem to be while the boat is in use. It get plenty of attention then. I think it's the off season that allows neglect and rot to eat away at the boat.
Sent: Friday, April 11, 2008 10:51:37 AM
---- rick barnes <barnesrickw@ yahoo.com> wrote:
if only there was a way to build a wooden boat that could be used outside.
I wonder what they did before the days of plastic boats? They must have had a way to be able to use the boats outside without them falling apart due to the elements.
I guess that knowledge is lost to the ages.
Do You Yahoo!?
> I would have to agree, the only place to store a wooden boat is in a structure of some kind. <Yea, I thought of that, but it's very expensive to build a structure large enough to sail around in, and even if you made it really big, it would probably get boring after a while.
Do You Yahoo!?
When I was 20 years old I was given a Hershoff 34 sloop for sailing my
teen years with the old man that owned her. The boat when I got her 54
years old. I kept her moored out and she did not have a self bailing
cocpit. I wnet to check on her every morning befor work. I wound up in
the hospital for a monthe and paid a fellow to check on her every
couple days. He took my money but didn't do his job. When I got so I
could I went to check on her an found here almost sunk, I could not step
aboard and had to bail most of the water out from a skiff.
The water had sloshed back and forth in her from passing boats and
it ripped aprt the cockpit and bunks in the cabin. So there is a case
of a boat almost being lost mostly fro rainwater. Most likely when she
got enough rainwater to put her way down in the water her side leaked at
least until the swelled.
worked great.
Doug
worked great.
Doug
> I used the clear stuff, six mil. on my bow shed here in Virginia and the
> sun killed it in nine months. I guess a lot depends on how far north
> or south you are. I then bought the shrink wrap that they wrap boats
> in and put it on and so far it has been on the shed for two years and is
> still flexible and strong. It cost almost 2 1/2 times as much as the
> Home Depot clear stuff. I live in a small town and I promised my
> neighbors the shed would be temporary not more than three years. This
> summer is three years and so I have to be good as my word and take it
> down. Boy I am going to miss it. I may build a garage in it's place
> which is kind of expensive word keeping.
> Doug
> > > Peter you can also get the plastic they use on greenhouses and it
> > holds up better to the sunlight. I know a couple of people that have
> > used it on a Bow Shed with good luck.
> > > Krissie
> > True regarding the greenhouse membrane but it is more expensive and
> > not available as readily as the clear poly film which can be had in
> > any hardware/big box store usually selling around $70CAN for a roll
> > 100' X 40'.
> > The curious thing is on the package it reads in nice big easy to
> > read words: "Protect From Direct Exposure To Sunlight" My Bowshed
> > has been up,day and night, for several years now and just as the
> > stuff is coming to the end of its useful life so is the construction
> > phase for the boat:-)
> > Peter
Doug
Doug
> > Krissie
> 100' X 40'.
> Peter
I store my plastic boat outside for economic reasons, and have yet to not have some springtime water in the bilge. So in spite of my sarcasm, I would have to agree, the only place to store a wooden boat is in a structure of some kind. I spent a lot of time restoring a Bluejay. Had no place to store it. I gave it to what I thought was a good home, but I'm sure it's a rotted shell at this point. I kept the sails and mast, so maybe I'll rebuild someday when I have indoor storage. Until then, it's punts and prams for me for wooden boats.
Sent: Friday, April 11, 2008 2:32:07 AM
> died from being left full of water in the backyard, than sank due to
I'm sure you're correct there.
It can be sneaky too. I have a racing dinghy I have to burn when I can
bring myself to do so. Kept it under plastic tarps that were renewed
when only slightly worn. Religiously bailed and sponged out the cockpit
as required soon after any rainfall. The beckson type plastic
inspection hatch openings in the verticle faces of the front and side
bouyancy chambers were about six inches off the cockpit floor, and the
water level never rose that high. The hatch covers were left off for
air to circulate, so of course it would be dry in there. Turned out
though that the water could wick its way through the bottom seams here
and there into the tanks, and, unlooked for, had a chance to have the
rot set in.
Do You Yahoo!?
100' X 40'.
> Krissie
100' X 40'.
Mark,
thankyou very much for this effort. Also thankyou very much for
providing the material Thomas.
Well, David wrote he "elaborated" on it. Sail rig, step fins, the
board not in the correct location (ok a building error first up, but
the fix when done was an elaboration too)...
What's this? In the scan "Sandy_4.pdf" of some building stages, a
large drawer in under the cockpit seat making use of the cabin
ventilation ducts - is this how it flooded so bad?
--- Inbolger@yahoogroups.com, Mark Albanese <marka@...> wrote:
> Thomas, Graeme, Anhinga fans
> Finally got the MAIB article scanned, then broken up to add to
> Bolgercartoons.
>http://tinyurl.com/5br3jv
> The image quality is satisfyingly better than expected from the
xerox
> copies.
> You can see clearly in the photos the infamous step fins. I'm now
> even more convinced that these catching the water may have
> contributed to the turning turtle. Contrary to the leeboard, as
> boat heels the fins get more bite.
> Au contraire?
> Enjoy,
> Mark
Sandy_4.pdf
rot set in.
> I suspect far more boats haveI'm sure you're correct there.
rot set in.
I looked down the page a bit more and saw some of your latest photos. I can see cracks in the layers of glass in the keel (they are the white areas in the fiberglass. I would run three or four layers of epoxy and cloth over the top of what you have down as far as you can at the bottom of the keel.
The way I would do it after all the voids are filled is put three layer of 6 oz cloth over it staggering the edges and the put a layer of 3 oz cloth over that. using the 3 oz cloth stops most of not all the pin holes
It's going to be easer to do it right now then to have to redo it later.
Have fun! Kriss
Kristine Bennett <femmpaws@...> wrote: I took a look at the photos you posted and I have seen it a couple of times. you can fill it with most anything but first you need to dry it out. I would trim back the hole and then have a fan blowing in it for a few days to a week. Then check to see how dry it is inside. As for filler I would use cement and moose milk. Moose milk is a primer for concrete. Pack the void full and set the fan up again and dry it out and then a glass and epoxy over that to seal it.
You may want to look closer at the keel for damage. That may not be the only spot. As for the non wetout glass I have no clue. They may have been in a hurry to get off work and get a beer!
Kriss
sals_dad <sals_dad@...> wrote: > Phil frequently comments in his
Alberg Corinthian ready for the water - it sat for an indeterminate
number of years/decades, full, up to the toilet seat, with rainwater
(good old overboard heads!)
http://www.plasticclassicforum.com/viewtopic.php?t=3332
I agree with Phil about thru-hulls. But a drain for when the boat
is "on the hard" is a different matter. I suspect far more boats have
My brother offered a bit of advice for garboard drains - leave a length
of twisted line hanging thru, to keep it at least somewhat clear, even
if leaves or other debris threaten to clog it.
Do You Yahoo!?
Have fun! Kriss
Kriss
> writings about keeping thru hulls to a minimum.I am on a bit of a tear about drains just now - getting a 40+ year-old
Do You Yahoo!?
Peter you can also get the plastic they use on greenhouses and it holds up better to the sunlight. I know a couple of people that have used it on a Bow Shed with good luck.
Krissie
Peter Lenihan <peterlenihan@...> wrote
What I have found through experience over the past 6 years is that
6mm clear poly plastic,the stuff they use in the construction trade
as a vapour barrier for homes,is fantastic as a covering material.I
used this on my bow shed and it is still going strong but will be
due for replacement before going through another winter.
Although it does not come with grommets or a neat sewn hem, simple
furing strips(say 1X2's) rolled around a couple of times along an
edge and stapled to the plastic will allow hard points for tugging
the sheet firmly over and down the ridge pole.
_Peter lenihan
Do You Yahoo!?
Krissie
_Peter lenihan
Do You Yahoo!?
Kriss
Do You Yahoo!?
Kriss
Do You Yahoo!?
_Peter lenihan
>relatively
> Make jokes all you like about sticks and tarps, but they are
> ineffective under most circumstances. Plastic tarps fade in thesun and
> shred in the wind. They wear down wood, paint, and varnish. Theyare the
> devil to keep in place, even with careful tying down. The ringsfail,
> rust, and stain the boat. They leak.What I have found through experience over the past 6 years is that
_Peter lenihan
> Phil frequently comments in hisI am on a bit of a tear about drains just now - getting a 40+ year-old
The neat thing is they make some stuff call string! You can take some and tie one end to the plug and the other to the boat... And hey you have you a plug on a string.
I have seen small flip over plugs at West Marine and at Ace Hardware. I've seen them down to 1/2 or 7/16. So if you glue a fairing block on the outside of the hull you can bore it the right size and then coat the hole with epoxy. I've also seen some small PVC pipe that was 1/2 ID you could bush the hole with that. Or use a nylon barbed hose fitting that has been roughed up and epoxy it into the hold as well... If there is a will there is a way!!!
Blessings all
Krissie
Douglas Pollard <Dougpol1@...> wrote: Funny thing about them hole remedies. I bought two of them and put them
in a storage shed along with the box for my handheld VHF, some flares
and a couple life jackets. Can't find'em. So what did you call them
things you did with the bit? Holes I believe! One inch in dia.? If I'm
going to do the finger in the dike trick my fingers are going to have
to grow some. Wish I had used a 5/8 drill.
Doug
sals_dad wrote:
Do You Yahoo!?
Blessings all
Krissie
Doug
> > sticks and tarps, ... are relatively
> Somewhere, near (or perhaps in) that flat bottom, perhaps at the
> transom, there will be a section which, when the boat is in its
> normal "dry" storage position (on a trailer, pulled up on the beach, or
> sitting in your yard), will be near the lowest point of the hull.
> Locate the general area, and identify a point within it that is heavily
> built, out of the way, and not prone to damage, particularly on the
> outside. Mark with an X. If you do not have one already, purchase a
> 1" bit, attach it to your electric drill, and proceed to bore through
> the hull structure, centering on the X. In the future, you will find
> that water which finds its way into the hull will exit through this ne
> aperture.
> Call this aperture a "Hole".
> Should the hole prove inconvenient after the boat is launched, a
> specialty device is manufactured to remedy this. See
>http://www.duckworksbbs.com/hardware/plumbing/sd520075/index.htm
> <http://www.duckworksbbs.com/hardware/plumbing/sd520075/index.htm>
> Good luck!
> Sal's Dad
Do You Yahoo!?
When I drilled the holes in the cockpit of my Elver I made fairing
bocks to fit on the bottom of my 3/4 in bottom. The tubes that go in th
holes are about 1 !/2 in. long so they stick down below the external
bottom about 3/4 inch. Adds a little drag. I didn't want the block on
top because I would wind up with 3/4 inch of water in the cockpit that
wouldn't drain.
You can buy bronze drains but the are expensive and the topside
flange is still about a 1/4 in thick thus 1/4 in of water. So they are
not perfect either. Some of the old boats used to use a tapered hole
and a tapered plug with a cross handle near the top of the plug. You
just insert the plug and push it in with your foot. To pull out twist
and pull. Works great and I have never heard of one popping out. If the
two tapers fit you'll know why when you pull it out. Grunt! The problem
is you need a tapered reamer to ream a tapered hole. And the plug has
to have the same taper. If they are not perfect just insert the plug
and twist a few times and they will be perfect.
We used to build skiffs and punts and the only pine we had was
knotty. We knocked the knot out and shaved down a tapered plug and
drove it in the knot hole with no glue. We then sawed off the pug on the
inside and the outside. The small piece from the outside was driven
into a smaller hole and so on. None of them ever came out as long as
the boat stayed in the water. So it was haul and paint the same day and
splash before it looked like a sieve.
Doug
wouldn't drain.
Doug
> Great idea! My Oldshoe cockpit is huge and not self draining, the
> forward and aft sections are self-draining. I have been concerned
> about outside storage and possiblity of the cover leaking and the
> cockpit filling with water. This is a great solution and thanks for
> that.
> Fairwinds,
> Dennis
> Bellingham, WA.
> beach, or
> heavily
> purchase a
> through
> find
> ne
> > aperture.
> > Good luck!
> > Sal's Dad
I was once about 6 miles offshore with a friend in his boat. We anchored at an artificial reef and were tying on hooks when we noticed a lttle bit of water under foot. Yup, we hadn't put the plugs in. Happily, the engine started and we finally got the boat up on a plane to drain it. It was interesting.
I've had fair luck with a canvas cover and using the mast as a ridge pole. The trick is to make a fairly tall pair of crutches and make the pitch on the tarp fairly steep. Even then, rain will sometimes pool. I haven't come up with a perfect solutio, but this works pretty well most of the time.
JohnT
JohnT
Sent: Thursday, April 10, 2008 8:02 PM
that.
Fairwinds,
Dennis
Bellingham, WA.
beach, or
heavily
purchase a
through
find
ne
> aperture.
> Good luck!
> Sal's Dad
Checked by AVG.
Version: 7.5.519 / Virus Database: 269.22.11/1371 - Release Date: 4/10/2008 12:23 PM
that.
Fairwinds,
Dennis
Bellingham, WA.
that.
Fairwinds,
Dennis
Bellingham, WA.
>beach, or
> sitting in your yard), will be near the lowest point of the hull.heavily
> built, out of the way, and not prone to damage, particularly on thepurchase a
> 1" bit, attach it to your electric drill, and proceed to borethrough
> the hull structure, centering on the X. In the future, you willfind
> that water which finds its way into the hull will exit through thisne
> aperture.
> Good luck!
> Sal's Dad
Doug
Doug
> aperture.
> Good luck!
> Sal's Dad
Caloosarat
_____
sals_dad
Sent: Thursday, April 10, 2008 6:18 PM
aperture.
http://www.duckwork
Good luck!
Sal's Dad
Caloosarat
_____
sals_dad
> sticks and tarps, ... are relativelySomewhere, near (or perhaps in) that flat bottom, perhaps at the
aperture.
http://www.duckwork
Good luck!
Sal's Dad
aperture.
Good luck!
Sal's Dad
Amen
Caloosarat
_____
Chris Crandall
It's boats thats precious, mates.
Caloosarat
_____
Chris Crandall
Make jokes all you like about sticks and tarps, but they are relatively
ineffective under most circumstances. Plastic tarps fade in the sun and
shred in the wind. They wear down wood, paint, and varnish. They are the
devil to keep in place, even with careful tying down. The rings fail,
Personally, I recommend a nice warm garage, if you've got one.
Lawnmowers don't rot, and cars can take the sun these days. It's boats
No, I'm sorry. ( If only... ) Thomas sent me the xerox out of MAIB;
just B&W. The only one in color is in the Anhinga folder, the one
from WoodenBoat Launchings, Sandy_Bottoms.jpg.
On Apr 10, 2008, at 6:47 AM, Bruce Hallman wrote:
> Thanks for posting the article, but especially for those Polaroid
> photos. Those are new to me, do you have the originals of those
> photos? If yes, and not too much trouble is it possible to do a color
> scan in a 'jpg' format?
Tarp? Stick? Just to complicated, turn it upside down when your done playin' with it:) Mike
--- On Thu, 4/10/08,BllFs6@...<BllFs6@...> wrote:
> From:BllFs6@...<BllFs6@...>
> Subject: Re: [bolger] boats with plumb sides.
> Date: Thursday, April 10, 2008, 1:58 PM
> In a message dated 4/10/2008 8:18:10 AM Central Daylight
> Time,
>d.cassidy@...writes:
> I would call that a "stick."
> This is clearly too complicated.
> It took millions of years for our ancestors to invent the
> stick....and in my
> opinion it was all downhill after that !
> Blll
> **************Planning your summer road trip? Check out AOL
> Travel Guides.
> (http://travel.aol.com/travel-guide/united-states?ncid=aoltrv00030000000016)
> thanks, Fred' posts
> snip away
> - Open discussion:
> Groups Links
Do You Yahoo!?
In a message dated 4/10/2008 8:18:10 AM Central Daylight Time,
It took millions of years for our ancestors to invent the stick....and in my
Blll
**************Planning your summer road trip? Check out AOL Travel Guides.
Blll
Nah . . . then you would need someone to invent something to prop up the "tarp" (is that what you called it?) in the center, so that the rain would run off and not collect.
> If only somebody would invent a big plastic sheet to cover the boat so water would not get it. If I invented such a thing, I would call it a tarp, or something.
> From: captjbturtle <captjbturtle@...>
> Sent: Wednesday, April 9, 2008 8:29:31 PM
> Subject: [bolger] boats with plumb sides.
> fellow builders, i,ve finally figured out a big advantage of boats with
> plumb sides versus flare.They catch less rainwater inside while being
> built.Once moreI,ve spent a miserable half hour bailing my mystery boat
> with a towel and this is in Florida's supposed dry season. Yes it has
> flared sides and catches every drop of rain which falls, The tarp
> system seems to funnel it all aboard.Fortunately the iside is coated so
> rot hasn't set in before the boat is finished. You have figured by now
> its too big to tip and roll the water out of and yes, flat bottomed so
> the rain spreads out in a nice thin sheet making bailing with anything
> but a towel or sponge impossible. Bought more Raka epoxcy yesterday,
> now $59 a gallon, ouch seems to have gone up about $20 overnight and
> they distrubute it her in Fort Pierce. Stretch Bantam, "Pelican" had
> another long voyage without mishap to the Keys, up as far as Sarasota
> on the other coast then back across the Okeechobee waterway, one night
> at a dock and about $150 in fuel over 5 weeks gone, regards john
Bolgercartoons.
The image quality is satisfyingly better than expected from the xerox
copies.
contributed to the turning turtle. Contrary to the leeboard, as the
Au contraire?
Enjoy,
Bolgercartoons.
copies.
Au contraire?
Enjoy,
Do You Yahoo!?
Do You Yahoo!?
