Re: [bolger] Re: Fiberglass butt joints
> Also, you can double the strength of the joint by using bias glass, or
> cutting strips from cloth at a 45 degree angle to the weave. (all glass
> fibers will then cross the joint)
You can buy bi-axial (bias) tape from RAKA. It comes in a variety of widths
and weights, and saves a lot of cutting and ending up with little scraps.
To: <bolger@egroups.com>
Sent: Thursday, June 29, 2000 8:24 PM
Subject: [bolger] Re: Light Dory Evaluation
> Thanks Jake,
> I have seen pictures of butting with fiberglass and epoxy only but
> have been very skeptical of it. Heck I'm game to try it out. I really
> want to use marine ply on that one and if I don'r butcher the wood,
> brightside most of it. How would the glass butt look unpainted?
They are invisible. The test joints I made always broke in the plywood away
from the glass, and I was putting the pressure on the joint. This is with
3/8 superply and one layer of 6oz glass on each side, cut with the weave.
I have heard from one guy who said his would break in the glass, I would bet
that it all depends on the strength of the wood, he was using pine, CDX.
Make test joints, and break them.
