Re: query on RUBENS NYMPH side panel measurement
Thank you all for your answers.
Does anyone have similar problem with front part of side panel as
Rock did?
Rds
Luis
> --- Inbolger@yahoogroups.com, "Maximo" <grupos@> wrote:
> > If the side panel of both "Nymph" and "Rubens Nymph" are the
same, >
> as I believe they are,
> I pulled out my big white envelope. Well one of 'em. The one that
has
> the rubber stamped lobsters on it, and contains the study plan set
from
> Payson...
> Remarkably, the dimensions that are shown on the study plan for
Reubens
> Nymph, and there are four shown for the side panel, match those for
> Nymph on p62 of BTNIB!
> Graeme
That was a misprint and poor proof reading on my part, you are right
station 3 is 1' 1 13/16". Nothing like giving incorrect corrected answers.
graeme19121984 wrote:
> --- Inbolger@yahoogroups.com, Harry James <welshman@...> wrote:
>> for the side panel bottom curve, the measurement taken from the
>> baseline which is the plywood edge. Measurement at the 4' station
>> 1' 3 3/16", 3' station 1'1 3/16", 2' station 11 1/4".
> Sorry, but I have to agree with Maximo on the dimensions as shown on
> p62 of BuildTNIB. The 3' station is 1' 1 & 13/16" (one foot, one and
> thirteen sixteenth inches; or expressed amazingly clearly to a
> metricalphile like me by another older feet-inches-eigths-plus-or-
> minus-a-sixteenth way: 1-1-6+). Otherwise ok.
>> why was I reading SBJ #44? Because somebody mentioned the rowing
> Bateau
>> in #49 and I was reading the Bolger questions and answers at the
> end of
>> that article and that lead me back to the scow schooner in #44
> where I
>> discovered an article by Payson on building the Nymph and another
>> totally separate article by a guy who built a Garvey Schooner. This
>> always happens whenever pick up the old SBJ's.
>> You can't read just one.
> Aint it great :-)
> Graeme
--- Inbolger@yahoogroups.com, "Maximo" <grupos@...> wrote:
> If the side panel of both "Nymph" and "Rubens Nymph" are the same, >
I pulled out my big white envelope. Well one of 'em. The one that has
the rubber stamped lobsters on it, and contains the study plan set from
Payson...
Remarkably, the dimensions that are shown on the study plan for Reubens
Bateau
end of
where I
Aint it great :-)
My problem came at the front of the side panel.  The forward end seems to bee raked too steeply.  I am not sure if the problem is me or the drawing.
----- Original Message ----
Sent: Tuesday, April 29, 2008 7:38:52 PM
Subject: RE: [bolger] query on RUBENS NYMPH side panel measurement
If the side panel of both "Nymph" and "Rubens Nymph" are the same, as I
believe they are, I think there is an error on Payson´s last book "Instant
Boatbuilding" on page 99 (Ruben´s Nymph sheet 2) you could read 1´ 3 and
3/16" on two different stations, but on "Build the new Instant Boats" on
page 62 (Nymph, Sheet 1) you could read on one of this station says 1´ 1 and
13/16"
I think Nymph is the correct one, please correct me if I´m wrong.
Máximo.
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now.http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
13/16"
Máximo.
I do not have the plans, the following comment is from "Build the New
Instant Boats" and from an article in Small Boat Journal #44 both which
have the same measurements.
for the side panel bottom curve, the measurement taken from the baseline
which is the plywood edge. Measurement at the 4' station 1' 3 3/16", 3'
why was I reading SBJ #44? Because somebody mentioned the rowing Bateau
in #49 and I was reading the Bolger questions and answers at the end of
that article and that lead me back to the scow schooner in #44 where I
luis_nin_estevez wrote:
> Hi,
> I'm currently drawing on the sheets the parts of Rubens Nymph design.
> I found what seems to be a mistake in the figure of a measurment of the
> side panel.
> By the middle of the panel, and towards the fore part, the figure 1' 3
> 3/16" is repeated twice. When I draw the lower line of the side panel
> in that part, it clearly shows that something's wrong, as the line goes
> up when it seems that it should go right forward or slightly forward
> and aft.
> According to my "eye", the fore measurment of both should be 1' 2 1/4"
> instead of 1' 3 3/16"
> Does anyone know exactly which the correct figure is?
> Thank you.
> Rds.
> Luis
I don't have the Reuben's Nymph drawing, but I have modeled the Nymph
in Free!Ship. I understand that Rueben's Nymph and Nymph have
identical bilge and sheer strake panels.
Here is a picture of the expanded panels from Freeship, projected onto
a 3 inch grid. This should likely be helpful in the double checking
of the dimensions. Also, be sure to read Dynamite Payson's chapter on
the use of the "Architect's Scale" for measuring scaled dimensions off
of scaled blueprint drawings!
http://flickr.com/photos/hallman/2452902510/sizes/o/
I had aproblem when drawing that boat also.  I'll double check and see if I can find it.
Rick
Sent: Tuesday, April 29, 2008 9:15:56 AM
Subject: [bolger] query on RUBENS NYMPH side panel measurement
Hi,
side panel.
and aft.
Thank you.
Rds.
Luis
sorry, where it says "it seems that it should go right forward or
slightly forward and aft",
please read as follows
"it seems that it should go right forward or slightly forward and up".
Rds
Luis
--- Inbolger@yahoogroups.com, "luis_nin_estevez" <luisnine@...>
> Hi,
design.
> side panel.
1' 3
panel
goes
forward
> and aft.
1/4"
> Thank you.
> Rds.
> Luis
Hi,
side panel.
and aft.
Thank you.
Rds.
Luis
