Re: Pirate racer
Hi Clyde,
> It"s also available from Phil Bolger and Friends. Jon, I was
thinking of
> asking PCB if a lateen would work on your "perfect Skiff 08" as
opposed
> to the lug(since I can't have a nymph cubed).
It's funny you should mention that. When I sent my comments on the
original version of the skiff back to PCB, I suggested that the boat
might be a good platform for trying multiple sails when the mood or
purpose were right. The balanced lug for everyday use, a dipping
lug for a relatively long trip (say, to some interesting looking
island several miles away from the cruiser), and a lateen or settee
for "showing off" around an anchorage. My thought was that at the
scale of the skiff, the extra sails wouldn't be prohibitively
expensive compared to the potential fun they might provide.
The MAIB article is the first evidence we've seen that they received
the comments.
Jon Kolb
Generations of canoe sails and sunfish used small lateen sails. These had no reefs, you were expected to hike out further if necessary or swim (not a bad option in warm lake water). I learned to sail a tiny rowing skiff with an old canoe sail. The short mast had a screw sticking in the top, over which you hooked a metal ring attached to the yard. There was a lanyard on the boom that went from the boom around the mast and back to the boom.  The boom and yard were attached at the one end with two screw eyes. To furl I simply gathered the boom, yard and mast together and lashed it with the sheet.
----- Original Message ----
Sent: Monday, May 5, 2008 3:25:09 PM
Subject: [bolger] Re: Pirate racer
Hi Mike,
...snip...
> 1. How do you change tack? Do you have to rotate the sail around
> the mast, or does it make a difference?
Lateens are not normally moved to the lee side of the mast when
tacking. The relatively small effect on the "bad" tack is not
considered enough to warrant the hassle doing so. However, it has
been done in some older working craft.
> 2. If it gets a bit windy, how do you reef a lanteen sail?
Normally a line of reef points will run from the tack of the sail to
a spot on the leech a short ways up from the clew. This triangular
section from by the reef points, leech, and foot is then bundled up
and the angle of the yard to the mast is increased to lower the
center of sail area.
Having said all that, I've never actually sailed a lateen myself!
> If you haven't guessed, I'm relatively new to sailing. I've been
> looking for some description of how to handle a lanteen sail, and
> really haven't found anything. Any help anyone could give would
> be greatly appreciated.
Phil Bolger's book "103 Small Boat Rigs" is also available from
Payson or WoodenBoat Magazine's store and contains an excellent,
succinct description of the history and handling of the lateen and
102 other rigs. I consider it a must-have book.
Jon Kolb
www.kolbsadventures .com/boatbuildin g_index.htm
__________________________________________________________________
Be smarter than spam. See how smart SpamGuard is at giving junk email the boot with the All-new Yahoo! Mail. Click on Options in Mail and switch to New Mail today or register for free athttp://mail.yahoo.ca
It"s also available from Phil Bolger and Friends. Jon, I was thinking of
asking PCB if a lateen would work on your "perfect Skiff 08" as opposed
to the lug(since I can't have a nymph cubed). Clyde
adventures_in_astrophotography wrote:
> Hi Mike,
> ...snip...
> Jon Kolb
On Mon, May 5, 2008 at 12:25 PM, adventures_in_astrophotography
> tacking.
My Tortoise has a boomed lateen, and no there is no need to rotate the
yards from one side of the mast to the other. The Pirate Racer has a
boomless lateen, which is likely similar.
The Tortoise has no reefing points. But in my Tortoise, I deal with
strong gusts of wind by quickly easing the mainsheet which feathers
the sail. If running from a strong wind, you can let the yards swing
180 (and extending forward of the boat). If it gets really windy, I
drop the sail and use the oars.
The Pirate Racer has six reef ties, which you can bundle up a 'pie
slice' of sail along the foot.
Hi Mike,
...snip...
Jon Kolb
A friend of mine and I decided it might be fun to play around with the
Pirate Racers described in Boats with an Open Mind. So, I ordered the
plans from Payson.
However, I've never used a lanteen sail before, and I have a couple of
questions:
1. How do you change tack? Do you have to rotate the sail around the
really haven't found anything. Any help anyone could give would be
Mike S.
