Re: [bolger] Re: Building Update - Stretched Windsprint
Jon,
Did you consider bending the halyard on closer to the forward end of its
spar?
V/R
Chris
spar?
V/R
Chris
> The plan is to use the same sail as the original and be a little
> more relaxed in the gusty winds where we sail. On paper, the center
> of sail area moves a couple of inches forward of the center of
> lateral resistance in my scale-up, so I increased the rake of the
> mast and the rudder size a bit to hopefully compensate.
Hi Susan,
SHS, which is a good thing, I believe, since she's only decked on
the ends, and below the rail at that. There is a chunk of lead, but
only about 20 lbs. to keep the daggerboard down where it belongs. I
have considered making a heavier board if necessary after some
trials.
mast and the rudder size a bit to hopefully compensate. It is still
tempting, especially from a cost perspective, to fit one of the two
103 sq.ft. gaff sails from our Light (Cat) Schooner into this boat,
but I've always wanted to sail a lug.
Jon Kolb
> She sounds (and looks) a lot like an SHS hull with a differentThat's a good comparison. She's also got more freeboard than the
> interior arrangement and no big chunk of lead. Do you also plan to
> scale up the rig? Will she still be a single balanced lug?
trials.
Jon Kolb
> I scaled up the side panels of the original by 25%She sounds (and looks) a lot like an SHS hull with a different
> and left everything else the same. This results in a length of about
> 20'-4", due to the greater depth of the side panels (20" vs 16"), and
> illustrates the difference between scaling and simply changing the
> station spacing.
Susan Davis <futabachan@...>
Thanks for including all of the pictures, they are always a help
when building your own boat and wondering how something should be fit in
properly. Plus you did a very nice job and the finished product is well
worth showing off.
worth showing off.
<jon@...> wrote:
> I've posted four new photos of my stretched Windsprint project. Recall
> that on this boat I scaled up the side panels of the original by 25%
> station spacing.
>http://www.kolbsadventures.com/windsprint_1.htm
> I was unable to reach my shop during February and March due to heavy
> drifted snow, and the lost time means she might not get launched until
> July or August, assuming all my other plans for this summer don't
> intefere still more. She's due for floorboards and appendage work this
> weekend. Further ahead are spars and rigging.
> Jon Kolb
station spacing.
Jon Kolb
station spacing.
Jon Kolb
