Re: Birdwatcher - centreboard question
Thank you Bob - Yes it is BW 1 that I was reading about regards
rudder, -will have to get hold of updated arrangement. Sounds like
best to go with CB. Am also considering trying out tacking crabclaw
first off (about 14m2 ) - could mount stubb mast on forward bulkhead,
this would enable a canting arrangement and the COE is maintained when
the boom is laid back a little, as in reaching setup. However, with
boom raised close to mast (as for w'ward work) it looks like the COE
moves forward and is raised a little higher than on the designed
setup. Any ideas on possible probs with this and would the canting
have any effect in this instance.
Thanks - Darrell
Thanks - Darrell
--- Inbolger@yahoogroups.com, "Bob Larkin" <boblark@...> wrote:
> Hello Darrell,
> I don't feel qualified to comment on your proposed design changes.
> But, a couple of comments, based on sailing the BW2 for the last year+.
> The weight of the centerboard (about 150 lb) provides about the same
> static moment as the mast. The bottom, even as designed with 1-1/4
> thickness does not provide a big righting moment, as it is only a few
> inches below the CG. The dynamic ballast of people sitting low is
> very effective, as the windward side is the place to put the ballast
> with a flat bottom. This is most obvious, when sailing.
> Form stability of the sharpie is limited by the narrow beam. On, the
> other hand, getting the boat up on the chine log reduces the wetted
> area, which is desirable.
> Are you looking at the BW or BW2? The BW2 has more sail area than the
> original BW. At 213 sq-ft (full main and jib) it ends up with SA/D
> around 30, which makes for a spirited sailboat. The centerboard, as
> drawn, makes for the windward performance you would want. I would be
> careful about giving that up.
> Relative to tacking, I am trying to remember if I have gotten into
> irons at all. Certainly not while tending to business. The thing to
> remember is that the boat is light, and as soon as you start to tack,
> it becomes upright, and rotates very fast. I might add that the fast
> tacking makes for a busy time for the crew!
> On the BW2, there is plenty of tiller range. One has plenty of range
> for tacking, and to stall it, for that matter. I am not with the
> plans or boat now, so I can't get you a number. If the Honda motor is
> up, it limits the rudder travel, by a few degrees in one direction.
> The tiller mechanism changed between BW versions.
> Bob
> --- Inbolger@yahoogroups.com, "hobyarr" <knic0014@> wrote:
> > questions, wondering about centre board
> > whether it would be possible to do away with and use chine runners as
> > Matt Layden designs on Paradox and particularly Enigma as it is
> > designed a little closer to the BW build than Paradox is. What do you
> > reckon BW's draught would be heeled over - would it be enough to allow
> > chine runners to do there job - would adding weight to bottom overcome
> > loss of c.b weight Although I have read somewhere that BW can be a
> > little difficult to tack at times and perhaps the c'board is necessary
> > to assist Also thinking about rudder/tiller mods as it seems you can
> > only get about 20 degrees on rudder. Does anyone have any ideas or
> > knowledge on this.
> > Thank you - Darrell
Hello Darrell,
Bob
Bob
> knowledge on this.
> Thank you - Darrell
knowledge on this.
Thank you - Darrell
knowledge on this.
Thank you - Darrell
