Re: AS29 photos
Col,
That Gecko looks a really sweet boat, thanks for the pics. Where is it?
NSW?
http://ph.groups.yahoo.com/group/bolger/photos/browse/282e
--- Inbolger@yahoogroups.com, "Col" <colmooney@...> wrote:
> I've uploaded some pictures of a very well made AS29 (I think) into
> the photos section under Gecko. I couldn't find any reference to
> this boat on a search of the group.
> Cheers,
> Col
Should have done more research.Frank Carr in his book on sailing barges says that 'bridge sails' were a species of small square headed lugsail, although the normal mizzen and,possibly,a small foresail might also be used.There is a picture of a pair of barges further downriver,almost identical to the ones in the ebay photo,on p118 in the 1989 edition of his book.In which case both will be barges,rather than narrowboats,and the nearer one will be one of the old 'swimheads'.Thames barges were built in great numbers and all lengths from about 40ft upwards,originally as swimheads(think lighter or very large Tortoise)then,after about 1850, increasingly with the pointed bow and straight stem of the modern barge. The Thames barge races demonstrated that the new style was faster and must have helped to popularise it,but the old swimheads were still competing in the 1890's and the last one was still trading into the 1930's carrying 'gas water' up round the coast
of East Anglia.(Gas water or coal tar is the liquid distillate from the old gas coking plants).The others had probably finished up as lighters.The Port of London Authority comissioned a series of photos of the Thames in 1937 and the swimhead lighters shown in those have some shape to them,as if they had been sailing craft at one time,rather than the more angular form of the modern steel swimheads.The depression of the 1930's probably eliminated most of the smaller barges.
cheers
andy airey
Send instant messages to your online friendshttp://uk.messenger.yahoo.com
It's very hard to say from the photo's size but I think they're
standing lugs (can't see if there's a boom or not) since typically
dipping lugs did not bring the tack to the base of the mast. Appear
to be brailed standing lugs aft, my eyes ain't good enough to say if
they are on the rudder to aid tacking or not.
These may be canalboats as opposed to the Thames barges that did
coastal work? They are very much smaller.
On Jul 6, 2008, at 12:40 PM, ANDREW AIREY wrote:
> Hi Graeme
> Having had my say about the various rigs I turned up an old photo
> on ebay this morning (320268722719) showing a couple of barges at
> Putney both apparently fitted with dipping lugsails.Since getting
> upstream to Putney would involve shooting several bridges this may
> be what was known as bridge rig and was probably easier to drop
> than the spritsails normally used,although these were arranged so
> that the mast could be lowered if necessary.I think that the usual
> procedure later on for those was to drop the mast and then get a
> tow upriver,although if they were only going as far as the pool of
> london,just beyond Tower bridge,then that would be opened for them
> - I was stuck in traffic on the southern approach to the bridge a
> few months back waiting for a sailing barge to clear the bridge.
> Usual procedure with narrowboats seems to be to build them from the
> bottom up using 10mm flat plate cut about 1cm oversize so that all
> the welding is downwards - similar to Lions Paw.A friend who used
> to build them said that he could knock out a shell in about 3 weeks
> with a bit of labouring assistance,and WM is probably a simpler
> proposition once you've sorted out how to put the rocker in the
> base.The expense of fitting out a hull is going to be proportionate
> to the size though so a cheap hull,although a welcome
> saving,doesn't necessarily mean that the rest of the boat will be
> cheap.It sounds as if a lot of people who were building ferrocement
> boats a few years back hadn't quite grasped that.
> I think that if the dipping lug wasn't too suitable for river work
> I'd be inclined to rerig simply with a squaresail as in the Humber
> Keels.It all depends how the boat would be used.They can be fairly
> closewinded - see the sites dealing with the preserved example -
> and if you are not in a particular hurry to get anywhere then you
> can wait for a wind anyway.Thames barges mounted a small spritsail
> on the rudder to help with the steering after the barges started
> increasing in size and length a couple of hundred years ago
> cheers
> andy airey
> PS I have a legal set of plans for the AS39 that I'm not sure that
> I'm going to use but might be interested in doing a swop for a set
> of 'Colonel Hasler' plans
> Send instant messages to your online friends http://
=== craig o'donnell
dadadata@...
Box 232 Betterton Md 21610
Hi Graeme
Having had my say about the various rigs I turned up an old photo on ebay this morning (320268722719) showing a couple of barges at Putney both apparently fitted with dipping lugsails.Since getting upstream to Putney would involve shooting several bridges this may be what was known as bridge rig and was probably easier to drop than the spritsails normally used,although these were arranged so that the mast could be lowered if necessary.I think that the usual procedure later on for those was to drop the mast and then get a tow upriver,although if they were only going as far as the pool of london,just beyond Tower bridge,then that would be opened for them - I was stuck in traffic on the southern approach to the bridge a few months back waiting for a sailing barge to clear the bridge.
Usual procedure with narrowboats seems to be to build them from the bottom up using 10mm flat plate cut about 1cm oversize so that all the welding is downwards - similar to Lions Paw.A friend who used to build them said that he could knock out a shell in about 3 weeks with a bit of labouring assistance,and WM is probably a simpler proposition once you've sorted out how to put the rocker in the base.The expense of fitting out a hull is going to be proportionate to the size though so a cheap hull,although a welcome saving,doesn't necessarily mean that the rest of the boat will be cheap.It sounds as if a lot of people who were building ferrocement boats a few years back hadn't quite grasped that.
I think that if the dipping lug wasn't too suitable for river work I'd be inclined to rerig simply with a squaresail as in the Humber Keels.It all depends how the boat would be used.They can be fairly closewinded - see the sites dealing with the preserved example - and if you are not in a particular hurry to get anywhere then you can wait for a wind anyway.Thames barges mounted a small spritsail on the rudder to help with the steering after the barges started increasing in size and length a couple of hundred years ago
cheers
andy airey
PS I have a legal set of plans for the AS39 that I'm not sure that I'm going to use but might be interested in doing a swop for a set of 'Colonel Hasler' plans
I suppose it could be either.The Humber has a lot of mudbanks and shoals and the Trent has a small tidal bore - the Aegir - which,although smaller than the better known Severn bore,could still make life interesting.I went down the Trent from Keadby on a 70ft narrowboat that my friend Neil was moving to Rotherham a few years ago.You can't get a 70ft boat from Keadby to Rotherham on the canal because when they upgraded the Sheffield and South Yorkshire system a few years ago to take 750ton Euroships they concentrated on The New Junction cut down to Goole docks and left one of the locks at Thorne on the original line to Keadby at the old length of about 60ft.Neil booked a pilot and we dropped down to Trent Falls on the ebb with the engine on tickover,motored across the Humber and tied up at a wharf to wait for the tide to turn and then went up to Goole on the flood. Interesting day
cheers
andy airey
Col
--- Inbolger@yahoogroups.com, Frank Bales <frank_bales@...> wrote:
> Hi all, I'm coming out from under my rock to ask a question.  Is
anyone building any of the larger Bolger designs like the AS39, or
the State named boats (Tennessee, etc.), or even the Tahiti?
There's very little to be found on the Internet about any of the
bigger bolger designs.  Why is that?  Wasn't there someone in Quebec
building a steel AS39?  And what about the guy in Florida who was
building the Tahiti?  It seems strange that someone like Phil Bolger
is not found more on the Internet.  I'd sure like to know more about
those boats from those that have built them.
> Frank
> Montgomery AL
Speaking of Larger Bolger boats, I have talked about Wolftrap in my
blog. She was featured in Bolgers book different boats back in the
1980's. My blog goes through building, dealing with Bolger, the
decision to build and sailing Wolftrap to the Bahamas. If you are
interested go to my blog Sailboats Fair and Fine and read . Start of the
bottom of the blog archive on the left side at the bottom click on
2006(9) and that will start you at the beginning of the story. The
story is not finshed and I will start writing to it again in the fall. I
am also making a video of the whole trip. The first week of the video is
finshed so there is a long way to go to cover a year of cruising
aboard Wolftrap.
Doug
http://dundalkfarms.blogspot.com/
Sam Glasscock wrote:
> Frank, I have built the Topaz, which is a small 31 footer, and will be
> building a Tennessee this winter. These are long boats but not large
> displacement, require small effort, unlike some of Bolgers
> large-dispacement designs. Sam
> --- On Thu, 7/3/08, Frank Bales <frank_bales@...
> <mailto:frank_bales%40yahoo.com>> wrote:
> From: Frank Bales <frank_bales@...<mailto:frank_bales%40yahoo.com>>
> Subject: [bolger] Large Bolger Designs?
> To:bolger@yahoogroups.com<mailto:bolger%40yahoogroups.com>
> Date: Thursday, July 3, 2008, 11:39 PM
> anyone building any of the larger Bolger designs like the AS39, or the
> State named boats (Tennessee, etc.), or even the Tahiti? There's very
> little to be found on the Internet about any of the bigger bolger
> designs. Why is that? Wasn't there someone in Quebec building a
> steel AS39? And what about the guy in Florida who was building the
> Tahiti? It seems strange that someone like Phil Bolger is not found
> more on the Internet. I'd sure like to know more about those boats
> Frank
> Montgomery AL
Frank, I have built the Topaz, which is a small 31 footer, and will be building a Tennessee this winter.  These are long boats but not large displacement, require small effort, unlike some of Bolgers large-dispacement designs.  Sam
Hi all, I'm coming out from under my rock to ask a question.  Is anyone building any of the larger Bolger designs like the AS39, or the State named boats (Tennessee, etc.), or even the Tahiti?  There's very little to be found on the Internet about any of the bigger bolger designs.  Why is that?  Wasn't there someone in Quebec building a steel AS39?  And what about the guy in Florida who was building the Tahiti?  It seems strange that someone like Phil Bolger is not found more on the Internet.  I'd sure like to know more about those boats from those that have built them.
Frank
Montgomery AL
--- Inbolger@yahoogroups.com, ANDREW AIREY <andyairey@...> wrote:
> The point about using steel for WM ...
Yep, steel is tough, and as the saying goes: "nothing seals like
steel." Easy to repair - and supplies and know-how almost anywhere.
The maintenance must be attended to, as with anything else I suppose.
Yes, I wondered about the heating: on how the internal cabin volume
is not large, and in temperate waters it would seem a small heater
would do. Then again I believe in winter Bolger always had a heater
going in his Resolution clad from higher R value material.
Where it's warm and sunny a thin walled steel tank is going to get
quite hot inside. Definately white topsides/deck (awning too?), but
also maybe insulation under the deck. More attention to ventilation
than shown in the article could help too, with a large cowl rigged to
catch any breeze when moored and direct it below decks etc. Still,
there are plenty of professional and owner built steel yachts about
so they can be habitable. I think PB&F wished to avoid the
complication, and expense, of the various methods of
protecting/insulating the steel.
Do you think the Weston Martyr building procedure is designed
similarly, or adaptable to that of the 2nd stage of the Jesse Cooper
build? If the mostly erected hull is upright on the ground with large
openings in the sides for easy access, then the internal fit out
would be less of a chore. There's plenty of incomplete hulls about,
and it seems the slowness (& expense) of fitting out could be a major
reason why projects are abandoned.
I reckon this dipping lug would be mostly tacked with help from the
motor. I also think it would mostly be shortened too. On small
expanses of water I wonder if the two sharpie sails alone might not
provide sufficient propulsion in a breeze? They certainly should tack
easily enough, and help manouvere the boat.
Could the mainsail have a boom fitted for sailing more confined
waters; maybe turn it into an optional loose-footed balanced lug?
I think a steel AS39 would be a goer. And maybe not too long now
before plywood runs out anyway - forest clearance, climate change,
and bio-fuels etc.. - peak ply?
> One other form of rolling,potentially unpleasant,is when you're
grounded out on a shoal or mudbank,and the tide comes up the estuary
and rolls you over.
How's that happen Andy?
Is that due to a tidal bore knocking you over, or due to being grounded
on a bank at too large an angle of heel?
There are quite a few pictures of large projects in the files and photos
of the seven Bolger groups. No order rhyme or reason, you just have to
look.
Peter Lenihan posted pictures on Le Cabotin an AS 39.
http://groups.yahoo.com/group/bolger7/files/Le%20Cabotin%20%28%20AS-39%29/
There are pics of his Windermere, nearing completion in the files
somewhere also. These are big boats requiring years of commitment, not
too many have the dedication to complete such projects.
Building the Double Eagle "Great Land"
http://thegreatsea.homestead.com/
> Frank
> Montgomery AL
> Frank
> Montgomery AL
Frank,
Cannot speak for the other designs but here are some pictures of the
AS-39 built in Quebec:
39%29/
in the files section of Bolger group7 under Le Cabotin.The owners
are planning to sail down the St.Lawrence this summer and winter
over in Newfoundland before crossing the Atlantic.
Frank
Montgomery AL
One other form of rolling,potentially unpleasant,is when you're grounded out on a shoal or mudbank,and the tide comes up the estuary and rolls you over.This was a known hazard on the Humber where it was common practise in barging days to go hell for leather down the Trent on the ebb,and then sit out on a convenient shoal down by Trent Falls,where the Trent joins the Ouse to make the Humber,and wait for the tide to turn.
cheers
andy airey
The point about using steel for WM is that it was intended to be used in circumstances where it might expect to get a lot of inadvertent hammering - locks and shoals for example and to be reasonably indestructible in those situations.If I was not constrained by the 7ft lock limitation I might be tempted to go the other way and see how a metal AS39 would work out.
Something mentioned in the original article which I think is incorrect is the temperature effects.Narrowboat experience in the UK is that you can keep them tolerably warm in winter with a pot stove,or,if you want to be posh,a diesel heater of some sort,but that they can get a bit warm in the summer.Since OZ is reputed to be a bit warmer than the UK this might be something you would need to look at.
One thing PCB did not make clear in the article was how much INLAND sailing WM would be expected to do.I think that you can probably discount sailing on the narrow canals but it ought to be capable of sailing wherever sailing barges used to operate,ie Thames,Humber,Severn,Norfolk Broads and Holland.Now the Channel and North Sea coasts might be the home of the Dipping Lug but in practise it seems to have been mainly used in fishing boats,to which it is ideally suited.(Fast out and home,gear stows out of the way when working the nets,AND,the extra bodies needed to work the nets can also manage the sail and yard when tacking).Everybody else used about half the number of bodies(typically 2,or 2 + a lad if it was a very big barge)and a different rig,mostly Gaff.(Humber Keels used square rig and Thames barges used spritsails).So it will depend on how many people you want as crew,although,as PCB remarked somewhere else,you can always use the engine to tack
with.
cheers
andy airey
Yep I think you've been around. What I was trying to say was that yours
mine or anybody's boat may prove different in different waters or they
may not. Which of course, I guess goes without saying. I had a Bolger
boat that had a small amount of dead rise and she set pretty flat most
of the time but she had a quick short motion as do most catamarans that
I have been on but only in just the right chop.
Doug
loosemoosefilmworks wrote:
> I suspect you
> > used your boat in the right conditions for her shape. Someone half
> > way around the world may find her a disaster in his seas.
> > Doug
> Well I might have strayed a bit from home waters with Loose Moose 2...
> Bob
>http://boatbits.blogspot.com/<http://boatbits.blogspot.com/>
I suspect you
> Doug
Bob
I experienced a very simular kind of thing an a Fantaisia 35 she had a v
bottom with a very large turn in the bulge and a large radius at what
would be the chine, if she had one. Hers was a different condition
though in that she had a heavy rig that created a very slow roll. In
most conditions she rolled so slow with such a long roll that most wave
conditions including powerboat wakes could not roll her at all. AS you
have mentioned she bobbed slowly up and down. I never experienced a
wave length that would roll her to any extent but I believe one exists
. In that situation I think she may have rolled violently and I
suspect that your narrow flat bottomed hull would do the same. If the
waves are right most any boat will roll and under the right
circumstance she may roll your guts out. I guess the right boat is one
that does not roll badly in the conditions you will use her in. I think
everyone has his boat and it used in his own conditions. I suspect you
Doug
Fred Schumacher wrote:
> On Wed, Jul 2, 2008 at 10:18 AM, loosemoosefilmworks <
>loosemoosefilmworks@...
> <mailto:loosemoosefilmworks%40yahoo.com>> wrote:
> > The other misconception is being narrow that rolling is more while our
> > experience is that narrow to a point translates into up and down
> > motion with the swell rather than side to side motion against..
> Some years ago when my son and I motored June Bug across Lake Vermilion (a
> large lake in northern Minnesota) through a windy 1 to 2 foot chop, while
> all the speedboats hugged the south shore, the feeling I got was that of a
> duck riding on the water. The boat's motion was up and down, even
> though the
> waves were on our beam, and we only shipped a cup of water on a 5 mile
> ride
> straight across the middle of the lake.
> Fred Schumacher
duck riding on the water. The boat's motion was up and down, even though the
waves were on our beam, and we only shipped a cup of water on a 5 mile ride
Fred Schumacher
> I think that it is
> important to point out that the various square Bolger cruising boats
> (As 29,LM2 and suchlike)roll much less than their more shapely brethren...
Ditto for the Micro. Much less 'rolly' than similar sized round bottom boats.
Having spent a thousand nights or so aboard Loose Moose 2 at anchor (
and another thousand or so on our Jessie Cooper) I think that it is
It was often a great surprise to our round bilge friends that when
they were visiting LM2 that the boat rolled so little and that our
comfort level in rolly anchorages was much better.
Of course if you use the example of a cracker box on a table being
less rolly than a coke bottle on its side it might give you a bit of
insight as to the why of it.
For sure there were more than a few nights that we were in anchorages
that were uncomfortable but that is simply part of the whole sailing
living on a boat gig...If there was no downside everyone would be
doing it!
Bob
> If I were to build a boat like this, I would
> want to use pressure-treated plywood ...
Hi Fred,
Another option would be to use regular marine plywood or MDO
that's been manually treated with Copper Naphthenate.
Apparently the CN doesn't corrode fasteners like the
pressure treating chemicals do.
Ken Grome
Bagacay Boatworks
www.bagacayboatworks.com
Go for it.I've just been watching a couple of videos of narrowboats being taken to sea round the coast of the UK,admittedly in very good conditions. I think that PCB was concerned about the comfort angle on what would have been a long sea trip from New Zealand.She would roll a bit at anchor,but having the mast up and the bilgeboard down would help a lot.My thoughts were that the accomodation on WM were a bit cramped,particularly the headroom,but at 6'8" I'm always going to have problems with that.I may have another look at WM but my thoughts are more on the lines of sailing barges.I've got a share in a narrowboat so I'm not so restricted over widths
cheers
andy airey
I played around with using Weston Martyr as a starting point for designing a
motorsailer to fit inside a 40 foot shipping container. I widened it to 7.4
feet and shortened to 39.5 with a 7.4 foot height over all so it would go
inside a standard, not hicube, container. Put a bow transom on it, a box
keel underneath, and moved the center cockpit aft six feet. With the box
keel there's standing headroom throughout. The main mast is in a trunked
tabernacle, tilting forward, and drains through the single offset
centerboard to one side of the box keel. Two 200 gallon tanks are at
midship, with berths above. Engine would be a small, light industrial diesel
like a Hatz 3W35. I'm no Phil Bolger, but I like using his concepts as
mental exercises. If I were to build a boat like this, I would want to use
pressure-treated plywood, with the hull skin as a torsion-box, that is,
treated plywood outside, one inch of foam, and 3/8" baltic birch on the
inside, all glued and screwed. It would be tough, insulated and unsinkable.
I thought about Lion's Paw; and about how the builder found that so
easy to build, just like Bolger said. I wonder if rolling at anchor
might not be worse than heeling for either boat?
Lion's Paw is only a foot wider on the bottom, but as it's 3 inches
deeper in draft and much shorter it would likely heel to an even
greater angle than Weston Martyr, and that is without considering the
greater sail area of Lion's Paw. I don't see heeling as such a
problem for a cruiser as time is mostly spent not at sea, nor even
under sail. (I think I recall stats to the effect that most live-
aboard cruisers spend 90% or more of their time moored.) It's a given
too that when sailing the performance of these sharpie boats is in
large part due to their heel angle allowing them to slice through the
water. My feeling is that in Weston Martyr, for not much expense in
the extra 6 feet of LOA, larger and better set out accommodations are
gained, 2000lbs extra displacement, along with a nice and seaworthy
centre cockpit, and THAT lug rig. The Weston Martyr bilgeboard could
easily be replaced by stowable leeboards, I guess. It's interesting
that there is only one bilgeboard drawn like for the AS39, and not
two like there is for the AS29.
Andy, I don't know about cruising the UK canals either, or any others
though that's all a nice possibility, but the narrowness (and strong
bottom) could be handy to get far inland up any river or creek, or in
gaining restricted entry to a protected coral lagoon. Along with a
couple of Tortoises there's space on deck for an outboard powered
skiff, say a Diablo or Fast Brick, that could share the motor of the
mother ship. If the Weston Martyr had two outboards fitted, and I
think there may be room enough as drawn, then once accustomed to the
heeling under full sail this boat might engender a state of mind not
unlike ataraxia.
Houston,you may have a problem.The hull itself should give you very little trouble and any half decent fab shop should be able to knock you one up,the thing to look at is the basic concept behind the design.Although the Kiwi who commissioned it had thoughts of building one and sailing it from New Zealand (PCB thought that this would be possible but very uncomfortable)the boat was intended to explore the English narrow canal system,hence the 7ft beam and be capable of crossing the North Sea and exploring the systems on the continent.The problem is if you want to build it over here because we have a little nasty called the Recreational Craft Directive(RCD).I'm in process of checking this out for my own purposes as well as for another yahoo group.No problem if you are building it for yourself - except that you can't sell it in the EEC for 5 years - but I don't think that you would get a narrowboat builder to touch it because of the one off certification
costs if it is said to be made for it's intended purpose.If you are intending to use it in Oz and aren't restricted by the 7ft beam I should look at 'Lions Paw'
cheers
andy airey
One big drawback to my mind is the bilgeboard,which takes up a lot of space inside the cabin.The only narrowboats that I know of that were ever sailed were the Chesterfield Canal 'Cuckoos' (72ftx7ft)and then only very occasionally on the River Trent and,allegedly by one family only,at sea to cross the Wash.They used detacheable leeboards for the purpose,which were kept at West Stockwith,where the canal meets the Trent,and probably at Boston.
45ft long, by 6ft 6in wide, by 5 ft high, steel box tube; narrowed
towards ends. Bottom plated half inch.
That's it. Not a lot else in rigging or internal fit-out by usual ocean
cruising yacht standards.
So how much to buy, erect, and protect the hull steelwork?
