Re: [bolger] SBJ cartoon, Japanese Beach Cruiser
> out how you get the detail and precision in your drawings. Would you
> entertain the possibility of doing a step-by-step tutorial on a simple hull
> like diablo or reubens nymph, but include interior bulkheads and sails?
> Thanks,
> Doug Griggs
> Maryland
Thanks. I encourage others to make Freeship models of Bolger boats
and to post them in Flickr marking them with the tags 'bolger' and
the name of the boat. This then collects the images together on the
Bolger Wikidot boat index.
http://bolger.wikidot.com/bolger:smallsailboats
http://bolger.wikidot.com/bolger:rowboats
http://bolger.wikidot.com/bolger:mediumsailboats
I could try to answer specific questions about Freeship techniques,
which I try to do over at the Freeship Yahoo group.
http://groups.yahoo.com/group/Freeship_HTandT_Group
Interior bulkheads can be done two ways, either intersecting with the
hull, or free floating. I do both, but the freefloating method is
usually less complicated. When intersecting, you must have the
'shared edge' to be creased.
With the sails, using the "File|Import|Part" menu command, I
typically insert the sail in straight and vertical to establish the
correct sail surface area, but with the Y coordinate offset a bit from
centerline. Then I add some interior non-creased edges perpendicular
to the sail surface curvatures. Then while looking at the 3D view and
the 2D views simultaneously I drag the intersection points 'by eye' to
simulate the sail filling with air.
Bruce,
Your renderings are a spectacular body of work. I downloaded the freeship
program, and can see tremendous potential, but I am having trouble figuring
Doug Griggs
Maryland
On 7/30/08 6:04 PM, "Bruce Hallman" <bruce@...> wrote:
> From the SBJ cartoon, Japanese Beach Cruiser
>http://flickr.com/photos/hallman/2718149938/
> I had to interpolate the sail plan from the writeup text, because the
> sail plan drawing was omitted from the writeup in SBJ. Was this
> design written up anywhere else?
> It seems a rough equivalent of the Oldshoe, and it looks like a great
> little boat.
It is chapter 26 in BWAOM, complete with sail plan.
Doug
> little boat.
little boat.
