Re: [bolger] Re: MICRO plans
You might want to double check the accuracy of this as most camera
lenses produce barrel or pincushion effects. That is, straight lines
are not really straight all the time. The are best in the center and
worst near the edges and can vary considerably as you zoom in or out.
It might not appear too great, but It would be troublesome if the panels
did not meet by something as small as 1/4".
Calm Seas & A Prosperous Voyage
Malcolm
Malcolm
mark hamill wrote:
>[Non-text portions of this message have been removed]
> I read an article on laying out lines that suggested taking slide
> photos of plans and then projecting the image onto a flat wall to take
> dimensions and lines for frames directly from the image to paper or ply.
> I tried it using a simple SLR camera mounted on a simple stand that
> holds the camera exactly flat to the plan and then mounted the slide
> projector so it was exactly flat to the wall and moved it in and out
> til the image was the correct size. If nothing else one can see the
> project in full size and perhaps wrap ones head around it better. I did
> this with several canoes but it is supposed to work with much larger
> boats. This was over 25 years ago and perhaps our digital age has made
> these cameras and slide projectors inexpensive.
> Mark
> Checked by AVG -http://www.avg.com
> Version: 8.0.169 / Virus Database: 270.7.1/1688 - Release Date: 9/24/2008 6:29 AM
That is a neat idea, and maybe worth a try on some other designs. I
am thinking that if you were doing one of the plans out of Payson's
books it might work well.
I found that Micro was simple enough with plans and scale rule in
hand. Birdwatcher (I hope to get to this someday) is done in metric
measurements as well, this should make this project even easier as
most errors in my building comes from misinterpreting the conversions
with feet - eigths - and sixteenths as the math is tougher.
Happy Building.
two side of the work skiff await pairing the their transom
Happy Building.
I find measuring on the lines works best. Also, look at all the
sheets that cover the piece you are working on, making sure all the
dimensions come out right.
Paul H.
Paul H.
--- Inbolger@yahoogroups.com, "samang251" <samang251@...> wrote:
> Got the plans blown up to 100%, got a "Metric Readings from Foot
> Inch Drawings" architects scale (cant find an imperial scale in
> Australia) and it measures out nearly perfect, just have to work
out
> if I measure between the lines, on the lines or just outside the
> lines.
> Sam
> --- Inbolger@yahoogroups.com, "Paul Hardy" <p_hardy@> wrote:
> > Yes, if you don't then you won't be able to use an architectural
> rule to
> > make measurements and Bolger plans really require this.
> > Paul H
> > _____
> > From:bolger@yahoogroups.com[mailto:bolger@yahoogroups.com] On
> Behalf Of
> > samang251
> > Sent: Monday, September 22, 2008 3:29 AM
> > To:bolger@yahoogroups.com
> > Subject: [bolger] MICRO plans
> > When the plans open in pdf format, do I need to print them off to
> 100%
> > scale so as to get an accurate measurement with the architects
> scale?
> > Version: 8.0.169 / Virus Database: 270.7.0/1684 - Release Date:
> 9/22/2008
> > 6:39 AM
Got the plans blown up to 100%, got a "Metric Readings from Foot and
Australia) and it measures out nearly perfect, just have to work out
lines.
Sam
lines.
Sam
rule to
> Paul H
> _____
Behalf Of
> samang251
100%
scale?
9/22/2008
> 6:39 AM
Yes, if you don't then you won't be able to use an architectural rule to
Paul H
_____
samang251
When the plans open in pdf format, do I need to print them off to 100%
scale so as to get an accurate measurement with the architects scale?
Version: 8.0.169 / Virus Database: 270.7.0/1684 - Release Date: 9/22/2008
6:39 AM
Paul H
_____
samang251
6:39 AM
PB&F's plans aren't in PDF format. They're only on paper - and a scale
rule will work fine. They're up to date, and anyway they don't cost a
whole lot more last time anyone checked. Watch out for CSD "plans"!!
100%
