Re: [bolger] rectangular spritsail with a forestay and jib??
bill shamblin wrote:
> Builders,
> Before, i built a "double brick" sort of cabin boat ( MUD TURTLE )
> 16'x4' and powered her with a 10'x12' rectangular loosefooted
> spritsail ( on a 2"x6" x16' mast )which was good on all points of
> sail except hard to windward. The mast was unstayed. I very much
> like the loose footed spritsail as the easyness of operation doesnt
> require much of me.
> Now im thinking of something bigger in the 8'x 24' range with 2 such
> spritsails and am wondering about adding a forestay ( and sidestays )
> for a jib and better windward performance on the forward mast ?? the
> problem im posing is how to have sidestays that attach slightly
> behind the mast that wont get in the way of the sprit?? sidestays
> that go up the mast only 1/2 way?
> Does anyone know about using a loosefooted spritsail with a forestay
> jib rig?
> Bill in NC
> Checked by AVG -http://www.avg.com
> Version: 8.0.173 / Virus Database: 270.8.1/1731 - Release Date: 10/17/2008 7:01 PM
I sometimes use a jib with a spritsail on my dory. I do not have a fore
stay; just haul it up taut & there you go. The only time I use it is
for long closewinded legs as I generally find it a pain in the neck.
The spritsail alone will sail very close to the wind, but provides no
power - you just sit there admiring the bubbles standing in the water
alongside. The jib makes all the difference by powering the main. I
suspect that it is a matter of making a slot effect rather than just
increasing sail area.
If you have a sturdy mast I question the need for stays or shrouds if
you didn't need them before. For given sail area, a sprit sail uses a
short mast. A tall mast & triangular sail of equal area would be a
different proposition.
Calm Seas & A Prosperous Voyage
Malcolm
thanks!
bs
--- Inbolger@yahoogroups.com, "John and Kathy Trussell"
<jtrussell2@...> wrote:
> Bill,
> 1) Several of John Wellsfords dinghies combine a standing
lug rig with
> a jib on a stayed mast. You can check these out by going to
> www.duckworksmagazine.com <http://www.duckworksmagazine.com/> and
clicking
> on 'plans' on the right side of the screen
> 2) John Gardner/Mystic Seaport have plans for a 14 ft
Whitehall with a
> sprit main and a jib on an unstayed, but fairly large mast. See if
your
> library has Building Classic Small Craft.
> 3) Also check your library for Philip Bolger's 100 Small
Boat Rigs,
> which has several descriptions of variations on sprit rigs.
> 4) Finally, there was an indigenous North Carolina boat
(maybe a
> 'Currituck Sound Boat'?) that used a sprit main with a jib. You
might want
> to contact the N C Maritime Museum in Beaufort (which shows one of
these as
> its logo.
> Good luck.
> JohnT
> _____
> From:bolger@yahoogroups.com[mailto:bolger@yahoogroups.com] On
Behalf Of
> bill shamblin
> Sent: Saturday, October 18, 2008 7:18 AM
> To:bolger@yahoogroups.com
> Subject: [bolger] rectangular spritsail with a forestay and jib??
> Builders,
doesnt
> require much of me.
such
sidestays )
forestay
> jib rig?
> Bill in NC
Bill,
1) Several of John Wellsfords dinghies combine a standing lug rig with
www.duckworksmagazine.com <http://www.duckworksmagazine.com/> and clicking
2) John Gardner/Mystic Seaport have plans for a 14 ft Whitehall with a
sprit main and a jib on an unstayed, but fairly large mast. See if your
3) Also check your library for Philip Bolger's 100 Small Boat Rigs,
4) Finally, there was an indigenous North Carolina boat (maybe a
'Currituck Sound Boat'?) that used a sprit main with a jib. You might want
to contact the N C Maritime Museum in Beaufort (which shows one of these as
its logo.
Good luck.
JohnT
_____
bill shamblin
Builders,
require much of me.
jib rig?
Bill in NC
Builders,
require much of me.
jib rig?
Bill in NC
