Re: [bolger] Fldg Schnr Mast Adventures
looking for and being worn done by the consensus for laminating, I started
looking for suitable 16 ft 2x4 material. Oddly
with reasonable edges. I contemplated the rope trick which I know can
deliver very significant clamping, it is what guitar
to press out as much crown as I could. I found a good deal on clamps at
the local Woodworkers Warehouse, big 6 in C Clamps
both surfaces and then made up some glue with silica for filler and used a
squeege to cover one 2x4 completely. I had a little over
the ends together as even as we could and I put a big wooden cabinet vise
in the middle. We just had a delivery of
out tightened the clamp, not too tight but with a little run out. We then
repeated the process halving the distance with
foot. Tricky to bring the twisty, crowny sticks together without squeezing
all the glue out. I think we will get
run of wall nail some doubled scrap 2 x 4's to the wall and use wedges for
some or all the clamping pressure.
If you can't find good enough stock in 16 foot lengths consider scarfing
some togeather out of
shorter lengths. You can even use 1 X 4 lumber. epoxy will cost more. If I
was using short lenghts I would feel safer with 1 X 4 lumber.
Good luck
Gordon
Gordon Cougergcouger@...
405 624-2855 GMT -6:00
> After being told by several lumber salesmen that they had 16 Ft D Fir4x4 only to be greeted by guffawing yardmen when I told them what I was
> enought the best stuff I found was at the local Home Depot. Though itwas not too good but I found 4 sticks that were reasonably straight and
> makers use. I decided to pull together all my clamps and buy a few moreso that I could use the relatively flat floor as an edge to work against
> for $5. I put a big roll of wax paper on the flatest part of thebasement floor and laid the 2x4's out crown up. I painted mixed resin on
> and put it down the middle of the other side and put them together crownup with the 2' side facing up. With the help of my youngest son we brought
> softener salt in 30 lb plastic bags which I hope won't stick to epoxyand we put one bag either side of the cabinet vise and when the crown came
> good 6" clamps and more bags of salt and filling in with smaller clamps,monkey wrenches etc. There is something pushing it together at least every
> something straighter than we started with. Let you know.Have you considered using vacuum to clamp the mast? If you have a 16 foot
Good luck
Gordon
