Re: [bolger] Re: Phil Bolger's Plywood 12 1/2 sea trials
Had to go to Google for the Morrisey Shinn, not very often that I see a
totally unknown A/C. Good luck, those are huge time sinks.
hobie_ind wrote:
> About 3 years restoring a 1961 Morrisey-Shinn Model 2150A (only about
> 40 of them built in the early '60's), then spent a bunch of time this
> last year recovering the bottom wings on an Acrosport II biplane and
> fixing miscellaneous engine issues. Currently building a Christen
> Eagle biplane which should tie up most of my project time for the next
> couple of years. Then we'll be back into building boats.
> --- Inbolger@yahoogroups.com, Harry James <welshman@...> wrote:
>> Gotta ask, what airplane?
>> HJ
Thanks for the info. I'll have to send away to PB&F to get an updated
set of drawings.
set of drawings.
> > an update on the latest drawings from Bolger or your own
modification?
> A couple years back, PB&F updated the Plywood 12 1/2 design. If my
> memory serves me, the major part of the change was adding about six
> inches to the sheer strake (or combing?) to increase the freeboard.
> HJ
> an update on the latest drawings from Bolger or your own modification?A couple years back, PB&F updated the Plywood 12 1/2 design. If my
hobie_ind wrote:
hobie_ind wrote:
> Outstanding photos and great to see someone get a full size Plywood 12-1/2 onto the
> water! It looks like you did a spectacular job on the construction and the details such as
> the castings.
> I've got to dig up my drawings, but the keel design seems to have changed considerably
> from what I remember (both the ballast attachment design and the ballast weight). Is that
> an update on the latest drawings from Bolger or your own modification? Either way, I think
> it's a great improvement as that was the only area of the design that concerned me.
> The drawings I have also show a Solent lug rig as an alternative to the rig you have. I still
> haven't decided which I will go with. Unfortunately I'm still a few years away from building
> one as it will probably wait until we move to eastern Canada, but your pictures sure do
> whet the appetite again.
> Since I built the model (I can't believe it's been almost 7 years!), I moved from Indonesia
> back to Canada, and have been sidetracked with a few other projects (restoring an old
> military jeep, an airplane and am now in the middle of building another plane), but the
> Plywood 12-1/2 has always stayed in the back of my mind and on the master project list.
> But the problem with living where there's not a lot of water is that it's a bit more difficult
> to get engaged in building a sailboat you'll only use a couple weeks a year! I still think it'll
> be a great boat to keep at our cabin on the Gatineau River near Ottawa eventually, but for
> now the plastic boat out there will have to suffice during the summers.
> Again, great job and thanks for sharing the pictures - I'm definitely jealous!
> Mark Oliver
> PS> How many hours do you think you have in the construction??
the castings.
Mark Oliver
the castings.
Mark Oliver
--- In bolger@yahoogroups.com, "schwabgerard" <schwabgerard@...> wrote:
> Hi Everone, just wanted to give an update to everone on outcome of sea
> trials for the Plywood 12 1/2. Sails great, needs 15-18 knots of wind
> to get rail down. Very stiff and comfortable to sail, feels like a
> boat twice her size. I'am very pleased with her sailing ability. I have
> been out in 30+ knots of wind with only one reef in main and had no
> problems sailing or handling the boat solo. Take a look at the link
> below and enjoy the slidshow or view pictures close up for more detail.
> http://s269.photobucket.com/albums/jj41/gmschwab/Plywood125-sea%
> 20trials/
> Make sure you get 2nd line to complete link to Photo-Bucket.
> PS -- Not a Bolger design,That is a neat bridge too.. elegant, extremely user friendly, probably
relatively cheap ( compare to the Brisbane pedestrian "Goodwill" bridge
for instance), rethought and simplified in a Bolger kind'a way -
compare to the coathanger in the background (and it's extremely long,
user unfriendly on-ramps from far beyond the main thoroughfares along
the river banks).
cheers
I don't remember. I am sure that concrete ballast could work, but the
complexity of building a curvy keel box would take time $$$. The fin
keel with a lead casting is such an elegant solution, like with Micro.
I think the 'electric spartina' is comparable, where PCB designed a
box keel, ballasted with lead acid batteries powering an electric
motor.
motor.
On Fri, Dec 12, 2008 at 5:04 PM, Harry James <welshman@...> wrote:
> Bruce
> Your concrete ballast solution wouldn't change anything would it? Just
> less free flooding area and a small probably unmeasurable increase in
> pitching moment? Seems like a really good idea in the current lead market.
> HJ
Bruce
> On Fri, Dec 12, 2008 at 4:13 PM, Myles J. Swift
> <mswift@...> wrote:
>> Is there a link to details or study plans on this design?
> I made an isometric rendering too,
>http://flickr.com/photos/hallman/1372236965/
>http://flickr.com/photos/hallman/tags/plywood125/
<mswift@...> wrote:
> Is there a link to details or study plans on this design?I made an isometric rendering too,
It's # 29 in the "Book Boats With an Open Mind" which is still in print
and widely available plus the original SBJ Cartoon
http://councill.home.mindspring.com/sbjournal/bolger/bolger1.html
How do you like your Tortoise?
> MylesJ
> Micro
> June Bug
> Tortoise
MylesJ
Micro
June Bug
Tortoise
MylesJ
Micro
June Bug
Tortoise
For those of you having problems with photos
of the Bolger Plywood 12-1/2, try this URL:
http://tinyurl.com/5tht4r
-=Grant=-
PS -- Not a Bolger design, but an interesting boat,
nevertheless:
http://www.grantmaclaren.com/turbinia
-=Grant=-
nevertheless:
I agree with David G. -- those are great photos. Thanks, Gerard!
For future reference, if one wraps a URL inside those chevron
thingies, the URL is supposed to stay unbroken. For example, this one
would be:
<http://s269.photobucket.com/albums/jj41/gmschwab/Plywood125-sea%20trials/
Eric
would be:
>Best,
Eric
On 11-Dec-08, at 9:41 AM, Bruce Hallman wrote:
> There is a 'wrapping problem' with the URL. Use cut and paste to get
> the whole long url, on my PC the "20trials/" is chopped off the end of
> the URL and needed to be pasted back on...
> On Thu, Dec 11, 2008 at 9:23 AM, titanicslim <titanicslim@...>
> wrote:
> > How are you finding that page? I just keep getting "not a valid url"
> > or something.
> of sea
> wind
> I have
> detail.
> >> 20trials/
She's a beauty. I've long wondered how she would sail, and I'm very
glad to hear your glowing report. A very neat job indeed!
Dave
Dave
> > or something.
of sea
I have
detail.
> >> 20trials/
> or something.
>> 20trials/
or something.
or something.
> 20trials/
Great fotos. Thanks for sharing.
David G
Harbor Woodworks
"Like as the waves make toward the pebbled shore, so do our minutes
hasten to their end" -- W. Shakespeare
David G
Harbor Woodworks
> 20trials/
20trials/
20trials/
