Re: [bolger] Sticking centerboard on Bobcat
That is a little tough to diagnose via email. It seems your board is
too thick for your slot or it is warped. Building a new
thinner/flatter board is what I would try. Re-melting the lead is not
a big deal, just use an old pot on a camp stove outdoors, gloves and
eye protection. Another possibility is to use a piece of metal
instead of wood, steel or aluminum. Steel might be a tad bit heavy
and aluminum a bit too expensive. Making your existing board thinner,
(with the right tools), could be a simple solution. I would go at it
with a 4 1/2" angle grinder with 36 grit disks, making it thinner by
1/4" and then add back a layer of 6 ounce fiberglass cloth with epoxy.
On Sat, Jan 24, 2009 at 3:58 PM, Jay Bazuzi <jay@...> wrote:
> Last summer I bought a second-hand Bobcat, 20 years old, but in pretty good
> shape. It's my first boat.
> One of the significant issues that I'd like to fix is that the centerboard
> sticks badly. To get it all the way down I have to really put my weight on
> it, and I have to haul pretty hard to get it to come up. I'm worried that
> it will spring a leak in the hull, not to mention being inconvenient.
> I don't know much about boat repair, and I'm looking for advice on how to
> fix it. Here are some options I've considered:
> - Grease the CB and trunk. Bad for the sea life.
> - Take out CB, sand high spots, epoxy, paint, reinstall. Can you sand the
> flat face of plywood?
> - Take out CB, soak it in water, weight against the warp, let dry. Does
> that work?
> - Build a new CB, hopefully it'll be flat. Lots of unknowns here for me,
> but I can figure them out - except I'm lost when it comes to casting a lead
> weight.
> Any advice?
> -Jay
that work?
weight.
Any advice?
-Jay
that work?
weight.
Any advice?
-Jay
