Re: Ply to glass or not to glass
Ah...Chatham the fog capital of the United States.
Very familiar with homes that never really dry out, and fog coming
into the house through the open windows. Funny thing was that the
Diablo I had did well in those conditions, it was when I moved it
inland and it sat under the oak trees that the rot moved much quicker
than I did. The 18' skiff gets its coatings of glass and epoxy once
the ice is out from in front of the garage.
>      Speaking about moisture inside boat hulls, I can show you the
World's best source right here on good old Cape Cod.  One reason I
avoid Cypress in my work!
> --- On Wed, 1/28/09, Jon & Wanda(Tink) <windyjon@...> wrote:
> From: Jon & Wanda(Tink) <windyjon@...>
> Subject: [bolger] Re: Ply to glass or not to glass
> To:bolger@yahoogroups.com
> Date: Wednesday, January 28, 2009, 5:21 AM
> In Wasington upside down would trap riseing wet air and condensation.
> Right side up with a tarp the same thing. Eather way moss dose grow on
> a rolling stone here.
> Jon
> So many Jons the hookers will start comeing around soon.
> --- In bolger@yahoogroups. com, "adventures_ in_astrophotogra phy"
> <jon@> wrote:
> > Hi Jon,
> > > There is also the part where what works in Texas may not work in
> > > Washington.
> > Agreed. Only one of my boats is glassed inside and I've had no
> > problems with the others. However, none of my boats are in the water
> > more than part of a day, and most of them are stored upside down when
> > I'm done using them. Perhaps more importantly, my boats live in a
> very
> > dry climate with lots of wind. I can't see that spending the time,
> > money, and effort to glass the inside of them would be of any benefit
> > in my situation.
> > Jon
I had a 31 LOA wooden cutter, plank on frame. The previous owner had
replaced the original decks (teak strip over ply) with plywood, they
were glassed on the exterior, unfinished on the interior. I started
in on painting the interior, just primer and top coat. I did not
progress very quickly (working on my back) and got three sections
done before being distracted to other things. In less than a year it
had all checked quite badly. I sanded off all that I had done, and
started in with the sealer. It takes hours to do a section because
once it soaks in you have to do it again. This is KEY! Stop short
and it will fail. It would take a whole day just to process some 8
or 10 square feet. Basically once I got to the end of the sections I
was doing it was time to start again. I kept going until it started
to dry shiny on the surface instead of soak in and go flat. Once
that dried I sanded again to get it smooth and put a final sealer
coat on. Then primer, then top coats. I think I did three top coats,
maybe only two in some places. This held up for some 10 years so
far, never checked again (I had the boat about 16 years, gone this
last spring).
The essence of it is you're turning that surface ply to a
solid "plastic" wood-fibre-filled layer. You might be able to do as
well with epoxy if you used very thin stuff, like CPES (you know of
that brand?) but the fumes would have been intolerable in my
situation, and it would have been big time expensive. And for all
that, all that could be hoped for is it would work as well, for it
surely wouldn't work better than "never failed".
But the common "regular" epoxies are too thick to soak in enough,
and generally cure too quickly to be able to keep applying enough to
really saturate the wood.
--- Inbolger@yahoogroups.com, "David" <arbordg@...> wrote:
> I'm curious how much history you have with this product. If it'd
work
> as you say, a lot of folks would be much happier using fir marine
> plywood for boatbuilding. It'd then be a straight tradeoff between
> increased weight (compared to occoume) vs. the reduced cost.
However,
> I know of one builder who tried it for this purpose - and found it
did
> not stop the checking. I wonder if, perhaps, he wasn't generous
enough
> with the application.
> Tell us more, please.
> Cheers,
> David G
> Harbor Woodworks
> --- Inbolger@yahoogroups.com, "maicorick3" <rickf@> wrote:
> > > Yes. No question. Fir plywood will check unless glassed.
> > Not entirely true. The plywood can be sealed first. A product
like
> > Interlux Sealer works (I've used this exact stuff).
> >http://www.jamestowndistributors.com/userportal/show_product.do?
pid=883
Here the problem is mostly water that collects under a poorly set tarp. I
keep a larger boat in the water during the summer. I will mostly trailer sail
this boat to use on two week trips to Cayo costa, the Texas 200, Florida
120... Martha Jane isn't bad to tow behind my 6 cyl pickup but gas would be better
towing something weighing 600 pounds than 3000. Prior I would use my Bolger
Sweet Pea. She has served me well for a dozen years. I plan to tow Martha
Jane to Florida Friday for a 10 day cruise then store her there for a spring
break trip and maybe the summer. Thanks for the discussion, i have work to do
In a message dated 1/28/2009 5:03:59 P.M. Eastern Standard Time,
sar207@...writes:
Speaking about moisture inside boat hulls, I can show you the World's best
source right here on good old Cape Cod. One reason I avoid Cypress in my
work!
--- On Wed, 1/28/09, Jon & Wanda(Tink) <_windyjon@..._
(mailto:windyjon@...) > wrote:
From: Jon & Wanda(Tink) <_windyjon@..._ (mailto:windyjon@...) >
To:_bolger@..._ (mailto:bolger@yahoogroups.com)
Jon
<jon@...> wrote:
> Hi Jon,
> > Washington.
very
> in my situation.
> Jon
**************A Good Credit Score is 700 or Above. See yours in just 2 easy
steps!
(http://pr.atwola.com/promoclk/100000075x1215855013x1201028747/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=62%26bcd=De
cemailfooterNO62)
Speaking about moisture inside boat hulls, I can show you the World's best source right here on good old Cape Cod.  One reason I avoid Cypress in my work!
Jon
<jon@...> wrote:
> Hi Jon,
> > Washington.
very
> in my situation.
> Jon
This is obviously a huge factor. I live the the Chicago area. I have
had boats outside uncovered for over 10 years that are only suffering
from checking (cheap construction plywood). No fungus and no rot. I
think this is due to the fact that we have fairly dry summers and our
winters are very cold and long. I've left pieces of pine out in the
yard on the ground for many years with no signs of rot. Just a little
discolored from sun and water damage.
Chris Feller
> Jon,
> That's for sure. Let's be geographically accurate though. I thought
> you lived in a suburb of Portland, OR???<G>
> Seriously, moss and fungus grows on anything that doesn't move around
> here, and some things that do. We keep our boat on a trailer, outside,
> and it takes some careful tarping and venting to keep it from rotting
> away as we look out the window. Other climates... other problems.
> Cheers,
> David G
> "The cure for boredom is curiosity. There is no cure for curiosity" --
> Dorothy Parker
grow on
> > Jon
> > --- Inbolger@yahoogroups.com, "adventures_in_astrophotography"
> > <jon@> wrote:
> > > Hi Jon,
> > > > Washington.
water
when
> > very
benefit
> > > in my situation.
> > > Jon
Sounds a bit like G W B
Sorry, I just couldn't resist
Darrell
> Washington.
> Jon
Jon,
David G
Dorothy Parker
> Jon
> <jon@> wrote:
> > Hi Jon,
> > > Washington.
> very
> > in my situation.
> > Jon
Jon
<jon@...> wrote:
> Hi Jon,
> > Washington.
very
> in my situation.
> Jon
Hi Jon,
> Washington.
I'm done using them. Perhaps more importantly, my boats live in a very
in my situation.
Jon
The thing you've got to remember is that things will be fine as long
as wood is perfectly sealed. It will also be reasonably OK if it is
left perfectly open and gets lots of ventilation.
The very worst condition is, unfortunately, the most common one: that
is when the wood is ALMOST completely sealed against the elements.
That is the lethal one.
Dave
--- Inbolger@yahoogroups.com, "Chris Feller" <chrisbfeller@...> wrote:
> I think we have once again shown that there is no one correct answer
> to this question. There are pluses and minus's to each of these
> approaches. One thing that we all have in common though is that we
> are each very happy with the approach that we take. This is great
> news. That means that you can do it the way you want to and it will
> work and you'll probably be happy with the results. There are always
> trade offs. Make a choice and be happy.
> Chris Feller
> > Fir plywood will always check the glue in all plywood is not 100%
> > coverage so there is places in all plywood where water setting in the
> > bilge can soak through to the outside through all layers. The best
> > names with the longest track records in amateur boat building, sails
> > of plans and kits all recomend encapsolation. With lower grades and
> > most marine grade fir that includes glassing to prevent checking.
> > Paint alone will not prevent checking on a boat that gets water in
> > the bilge even if it is only day used with a few several day trips a
> > year. It is best to keep water out rather then try to let it dry out.
> > Good news 3 Oz. glass wraped up on to sides of frames will do as a
> > after thought and encapsolate the frames. The Interlux product will
> > not prevent as it says "help resist" with out mention of type of
> > plywood. It also has some realy nasty VOC isues. Light sand
> > thoroughly for bond and go for it with light glass. Do you realy want
> > to depend on paint in your bilge that was not made for submersion. To
> > prevent water from splash or a hole in the tarp over it from soaking
> > in at the easyest spot then maybe swelling the ply trust epoxy over
> > paint. To keep fir ply from ever checking use at least 3 Oz. glass.
> > Jon
> > It is more enviromentaly friendly to build one boat that lasts then 5
> > that don't.
> > --- Inbolger@yahoogroups.com, GBroadlick@ wrote:
> > > interesting
> > > In a message dated 1/26/2009 4:09:58 P.M. Eastern Standard Time,
> > > Don_Maurer@ writes:
> > > There are 2 reasons you may want to fiberglass the inside of a
> > boat.
> > > One is to keep fir plywood from checking as already has been
> > > discussed. The other is if the boat was designed as a monocoque
> > > structure, ie. the inner and outer fiberglass layers are in
> > tension
> > > against each other. It creates a much stronger structure than the
> > > core plywood itself. Many boats designed like this have few frames
> > to
> > > help support the structure so it is important to fiberglass both
> > > sides to get the required strength. If the boat was designed with
> > > conventional frames and fiberglass was not specified it is
> > probably
> > > redundant and you would be better off with paint only.
Washington.
Jon
always
> Chris Feller
best
sails
in
trips a
out.
will
want
submersion. To
soaking
over
glass.
> > Jon
then 5
> > that don't.
> > > interesting
Time,
> > > Don_Maurer@ writes:
> > boat.
monocoque
> > tension
frames
> > to
both
with
> > probably
Chris Feller
> Jon
> that don't.
> > interesting
> > Don_Maurer@ writes:
> boat.
> tension
> to
> probably
Jon
that don't.
--- Inbolger@yahoogroups.com, GBroadlick@... wrote:
> interesting
> Don_Maurer@... writes:
boat.
tension
probably
interesting
Don_Maurer@...writes:
There are 2 reasons you may want to fiberglass the inside of a boat.
structure, ie. the inner and outer fiberglass layers are in tension
core plywood itself. Many boats designed like this have few frames to
conventional frames and fiberglass was not specified it is probably
--- In_bolger@..._ (mailto:bolger@yahoogroups.com) , "Brian
Anderson" <bawrytr@...> wrote:
> The thing I have always wondered, in terms of to glass or not to
glass
> the insides of a boat, is how much moisture can actually escape
> through plywood, given that the glue is waterproof. I would imagine
> that it would probably form a relatively impermeable barrier to the
> migration of water through the ply, and so given that as they say,
> most boats rot from the inside out, that there would be some
advantage
> to coating the inside with epoxy or with glass/epoxy.
> Anybody really know?
> Brian
> --- In_bolger@..._ (mailto:bolger@yahoogroups.com) , Bruce
Hallman <bruce@> wrote:
> > On Mon, Jan 26, 2009 at 10:04 AM, <GBroadlick@> wrote:
> > > the boat is built so MDO is too late. the issue is the
requirement
> to again
> > > sand to the point where it is ready to paint after i apply the
> glass and
> > > epoxy.
> > Fiberglassing the inside of a boat is subject to differing
opinions.
> > I usually fiberglass the insides. Others do not.
steps!
cemailfooterNO62)
I'm curious how much history you have with this product. If it'd work
plywood for boatbuilding. It'd then be a straight tradeoff between the
increased weight (compared to occoume) vs. the reduced cost. However,
I know of one builder who tried it for this purpose - and found it did
not stop the checking. I wonder if, perhaps, he wasn't generous enough
David G
Harbor Woodworks
> Not entirely true. The plywood can be sealed first. A product like
>http://www.jamestowndistributors.com/userportal/show_product.do?pid=883
> But you have to start with the new wood. You just keep slathering this
> stuff on until it will take no more. Then let is dry, and sand, and
> then paint or varnish. When done properly the fir ply will not check.
> Unfortunately it is probably too late for the problem at hand, since
> the epoxy has sealed some of the ply and won't let this sealer through.
> If it were me, I'd try it anyway.
Brian,
I wish I could give you a definitive answer. I can't. As I said, lots
of knowledgeable people on various sides of the issue. An example: my
shop is an "official builder" for two Antipodean designers. One from
OZ and one from NZ. I hold each of them in the highest regard. One
argues vigorously and convincingly for epoxy coating all components
before painting or varnishing. The other argues for using epoxy as an
adhesive, but not as a coating... paint only. Of course, we're talking
about BS 1088 or BS 6566 grade marine plywood... occoume, sapele,
meranti, et.al.
The tendency for fir plywood to check complicates the question, and is
generally enough for me to say, "glass it". But then, I haven't
owned/built a fir plywood boat since my 8' pram when I was 10 years old.
So... my firm and unbendable opinion is - It Depends. I'd have to know
all (and I mean ALL) the particulars before I'd venture a cautious
opinion, carefully couched in caveats.
I hope that makes it all crystal clear for you <G>
David G
Harbor Woodworks
--- Inbolger@yahoogroups.com, "Brian Anderson" <bawrytr@...> wrote:
> The thing I have always wondered, in terms of to glass or not to glass
> most boats rot from the inside out, that there would be some advantage
> Brian
glass
advantage
> Brian
requirement
> to again
> glass and
> > > epoxy.
opinions.
Brian
> On Mon, Jan 26, 2009 at 10:04 AM, <GBroadlick@...> wrote:
> > the boat is built so MDO is too late. the issue is the requirement
to again
glass and
> > epoxy.
> Fiberglassing the inside of a boat is subject to differing opinions.
Yes, but it is available (often by special order) in 5/16"
David G
Harbor Woodworks
> I have to agree with you on MDO. I have used it on three boats within
> the last five years. The only bad thing about MDO is that you can't
> get it in 1/4 inch.
> Chris Feller
> --- Inbolger@yahoogroups.com, "David" <arbordg@> wrote:
> > I would add top quality MDO to the list of good boatbuilding plywood
> > panels that won't check.
> > The issue of whether its better to put epoxy/glass on a boat, and
> > where, is one that boatbuilders go around and around about. There are
> > perfectly reputable designers and builders who come down at various
> > spots in this discussion. I won't restarts the whole discussion here,
> > but will note that all the little cracks caused by checking fir
> > plywood (whether painted or not) provide lovely collectors of moisture
> > and dirt/spores. Prime conditions for rot. OTOH, Mr. Feller's argument
> > has merit as well.
> > Cheers,
> > David G
> > Harbor Woodworks
> > --- Inbolger@yahoogroups.com, "Chris Feller" <chrisbfeller@> wrote:
> > > It will eventually check if you do not however the drawback to
> > > glassing the inside is that if water gets into the plywood it won't
> > > have any way out.
> > > The way I deal with this issue is to glass the outside and paint
only
> > > the inside with acrylic paint. I do not use epoxy on the
inside. The
> > > advantage to the acrylic paint is that it is softer and expands and
> > > contracts more. This delays the checking but does not eliminate
it.
> > > The best way to avoid checking is to use high quality Ocumme or
> > > Meranti marine ply. I never do this because of cost and the
fact that
> > > I tend to build a new boat every couple of years anyway.
> > > Chris Feller
> > > --- Inbolger@yahoogroups.com, "gbroadlick" <GBroadlick@> wrote:
> > > > I am building a Parker Ohio Sharpie. The hull is fir marine ply
> with
> > > > epoxy and dynel covering the exterior, epoxy interior.
> Everything is
> > > > sanded and ready to paint inside and out.
> > > > A few years ago i purchased a Bolger Hawkeye that was built in
> 2000.
> > > > The boat is great but suffers from checking of the ply surface
> on the
> > > > panels that make up the sides of the hull. The sides are not
> covered
> > > > with glass but are epoxied. Last year i took the hull down to
bare
> > > > wood, epoxied sanded and repainted with primer and single part
> Brite
> > > > Sides paint. Soon after the boat was on the water the checking
> > > > reappeared.
> > > > Last year i purchased a Martha Jane that was built by Jochem and
> is 2
> > > > or 3 times older than the Hawkeye and there is no surface
> checking in
> > > > the ply. The boat was glassed on all external surfaces.
> > > > So i keep wondering should i go ahead and glass the inside of the
> > > > Ohio Sharpie. I doubt the epoxy is built to a sufficient
> thickness to
> > > > keep moisture out. I hate to start over with the sanding but the
> > > > decks are not on yet and if i am going to do it now is the time.
> > > > Any thoughts?
> the boat is built so MDO is too late. the issue is the requirement to again
> sand to the point where it is ready to paint after i apply the glass and
> epoxy.
epoxy.
In a message dated 1/26/2009 12:37:15 P.M. Eastern Standard Time,
chrisbfeller@...writes:
get it in 1/4 inch.
Chris Feller
--- In_bolger@..._ (mailto:bolger@yahoogroups.com) , "David"
> has merit as well.
> Cheers,
> David G
> Harbor Woodworks
> --- In_bolger@..._ (mailto:bolger@yahoogroups.com) , "Chris
> > have any way out.
> > The way I deal with this issue is to glass the outside and paint only
> > the inside with acrylic paint. I do not use epoxy on the inside. The
> > contracts more. This delays the checking but does not eliminate it.
> > Meranti marine ply. I never do this because of cost and the fact that
> > Chris Feller
with
Everything is
2000.
on the
covered
> > > with glass but are epoxied. Last year i took the hull down to bare
Brite
> > > reappeared.
is 2
checking in
thickness to
> > > Any thoughts?
steps!
cemailfooterNO62)
get it in 1/4 inch.
Chris Feller
> has merit as well.
> Cheers,
> David G
> Harbor Woodworks
> > have any way out.
> > Chris Feller
with
Everything is
2000.
on the
covered
Brite
> > > reappeared.
is 2
checking in
thickness to
> > > Any thoughts?
And, it is worth mentioning that when I asked PCB whether I could save
the work of fiberglass and epoxy by using MDO plywood on Topaz Spyder.
He said that he recommended sheathing with fiberglass cloth and
epoxy.
has merit as well.
David G
Harbor Woodworks
> have any way out.
> Chris Feller
> > I am building a Parker Ohio Sharpie. The hull is fir marine ply with
> > epoxy and dynel covering the exterior, epoxy interior. Everything is
> > A few years ago i purchased a Bolger Hawkeye that was built in 2000.
> > The boat is great but suffers from checking of the ply surface on the
> > panels that make up the sides of the hull. The sides are not covered
> > wood, epoxied sanded and repainted with primer and single part Brite
> > reappeared.
> > Last year i purchased a Martha Jane that was built by Jochem and is 2
> > or 3 times older than the Hawkeye and there is no surface checking in
> > Ohio Sharpie. I doubt the epoxy is built to a sufficient thickness to
> > Any thoughts?
have any way out.
Chris Feller
> reappeared.
> Any thoughts?
David G
Harbor Woodworks
> reappeared.
> Any thoughts?
reappeared.
Any thoughts?
