Re: [bolger] Re: Bolger Zephyr
Bill,
Check here:
http://groups.yahoo.com/group/Bolger2/photos/album/1375767279/pic/list
Found by searching through message archive with keyword zephyr.
V/R
Chris
Bill Kreamer wrote:
Check here:
V/R
Chris
Bill Kreamer wrote:
> Any Zephyr image links? Thanks - Bill[Non-text portions of this message have been removed]
> _____
I did an isometric study of Zephyr
http://flickr.com/photos/hallman/2473379197/
A car topper!
http://flickr.com/photos/qsi_is_40/347087866/in/set-72157594461850848/
afloat
http://flickr.com/photos/qsi_is_40/347101604/in/set-72157594461850848/
A car topper!
afloat
Try Google Images. It found this page (and several others):
http://bolger.wikidot.com/bolger:mediumsailboats
Howard
Howard
_____
gbship
Sent: 2009-01-27 21:50
Subject: [bolger] Re: Bolger Zephyr
It's easy to build; Payson estimates something line 24 or 48 hours and
that's about correct -- not counting painting and finishing, which will
take about as long as the building. Mine was built to plans. If I were
redoing it, I might fiberglass the bottom under the skids and the
sides, trading the extra weight for reduced maintenance and better
protection. I might also omit the foam in the watertight compartments
in the ends and put deck plates on instead, some waterproof storage.
I made a shorter leeboard 'cause there's lots of shallow water around
here, I think it was 3.5 instead of the designed five feet. It sailed
well even with the short board. It pounds a bit in the short chop that
builds up in 12-15 mph of wind, but nothing terrible. It will be wet
going to windward in those conditions.
It's an adequate rower, not great, but you will get by. I built mine
with a 2x4 projecting through the port side and bolted to the back side
of the aft bulkhead as a motor mount. It actually worked (it has to be
kept short because the board will drag if the boat heels enough) but it
was eventually cut off because a motor was rarely used.
A sailmaker who primarily did awnings and was not familiar with lateens
made the sail. I think it may have been cut too flat which hurt it's
light wind performance, but she could fly in stronger winds, even with
the reef in.
Despite it's narrow beam, I never flipped mine, which also suprised me
a bit!
Gary
--- In bolger@yahoogroups. <mailto:bolger%40yahoogroups.com> com, "Laura
&Craig Every" <theeverys@...>
_____
gbship
the reef in.
a bit!
Gary
>would
> I am planning on building a bolger zephyr, has anyone built one? own
> one? what do you think? how do they sail? any oppions or comments
> be welcome.[Non-text portions of this message have been removed]
> thanks, Craig
the reef in.
a bit!
Gary
--- Inbolger@yahoogroups.com, "Laura &Craig Every" <theeverys@...>
the reef in.
a bit!
Gary
>would
> be welcome.
> thanks, Craig
--- Inbolger@yahoogroups.com, "Laura &Craig Every" <theeverys@...> wrote:
well and the rig is fun to experiment with. Being longer, she was much
faster than my Surf. You'll like Zephyr.
>I once sailed the prototype Dynamite Payson built. She sailed very
> one? what do you think? how do they sail? any oppions or comments would
> be welcome.
> thanks, Craig
be welcome.
thanks, Craig
be welcome.
thanks, Craig
