Re: NJ Sneakeasy...
I keep wondering when someone was going to bring up Steve Bosquette's Baby Sneakeasy but alas. Here's the duckworks link
http://www.duckworksmagazine.com/06/projects/sneakeasy/index.htm
This is the same boat Steve brought to the 2005 Kingston Messabout
http://www.duckworksmagazine.com/06/gatherings/kingston/index.htm
Bryant
--- Inbolger@yahoogroups.com, "Brian Anderson" <bawrytr@...> wrote:
> I was looking for something else, but noticed that the article I mentioned in the Oct. 2007 Woodenboat, about the jet-ski powered lobsteryacht is online (with the rest of the issue and several other issues to boot...) if anybody is intersted.
>http://woodenboat.com/wbmag/digital_issue.html
> Cheers, Brian
> --- Inbolger@yahoogroups.com, "Brian Anderson" <bawrytr@> wrote:
> > There was a WoodenBoat Magazine cover story Oct. 2007 where a guy had built a 26 foot strip-built "lobster" boat (it wasn't a working boat) and then after pricing various power options decide to buy a big jet ski and mounted that on the back of the boat. They were pretty pleased with the results. Apparently they paid $9,000 for the three-man jet ski, and figured powering the boat would normally have run about $30,000. It certainly looked like a nice job.
> > They said the boat weighed just 2,000 pounds and it burned 3-4 gallons an hour at 18-20 knots.
> > Cheers, Brian
> > --- Inbolger@yahoogroups.com, "daschultz2000" <daschultz8275@> wrote:
> > > I've looked pretty hard at this. The Duckworks site has a link to an old do it yourself site about cutting up a jet ski and grafting it into the bottom of a flat-bottom boat. The pics are thorough.
> > > No discussion I recall of slow speed handling, but there is a tendency to take advantage of the very shallow draft and this exposes the powerplant to picking up rocks, mud, etc from the bottom, so you need to install a protective grate. This vulnerability really offsets the 'gain' of a great looking inboard powerplant installation with no exposed propeller to maintain.
> > > Also, efficiency stinks, the result is a gas hog when compared to the same boat with a modest outboard.
> > > So I concluded that a really fun project would result in a not so fun boat. Now, that's MY analysis of the tradeoffs. Your conclusion may vary from mine that's just fine.
> > > Don
> > > --- Inbolger@yahoogroups.com, "highoveryou" <highoveryou@> wrote:
> > > > Even had another idea, but probably just that. How about the running gear from a jet ski? Sure would reduce the draft even further, and make a cleaner transom for a traditional look. Although that'd probably kill any slow speed handling!
> > > > Jeff
Cheers, Brian
> Cheers, Brian
> > Don
> > > Jeff
> You can find used jetskis pretty cheap. I see a bunch of sub $1000
> jetskis on Seattle Craigslist right now, for instance.
> -p
I agree you can. It is a personal preference sort of thing.
Personally, with an retro-look kind of boat like Sneakeasy, I think it
makes sense to use an old fashion style drive shaft with propeller.
As to the engine, if you are really on a budget, those $300 horizontal
shaft gasoline engines are really cheap. Though, as long as we are
dreaming, the ideal 'old school' engine to drive a boat like this
might be a one-banger low RPM 'Listeroids' diesels. These have that
great, hypnotic, low frequency "sound" that would make cruising a
pleasure. Both the gasoline engine, and the jet ski engine, would
drive me nuts with their high frequency drone.
http://www.kk.org/cooltools/archives/001011.php
http://www.utterpower.com/listeroi.htm
I think Listeroid engines can be bought for as cheap as $600.
Plus, you can burn recycled french fry oil.
On Tue, Apr 14, 2009 at 10:58 AM, Bruce Hallman <bruce@...> wrote:
>>back of the boat. They were pretty pleased with the results. Apparently they paid $9,000 for the three-man jet ski, and >figured powering the boat would normally have run about $30,000. It certainly looked like a nice job.
> $9,000 is still a lot.  There is an inboard powered flat skiff the
> size of Sneakeasy in Bolger's design list, the name escapes me at the
> moment.
-p
moment.
For 'cheapo' power, I favor the concept of "Bonefish" which takes one
of those horizontal shaft gasoline engines selling for $300 and
connects it to an old fashion drive shaft, stuffing box and propeller
using a rubber belt. You could power a Sneakeasy with perhaps $500 of
hardware this way.
http://www.google.com/products?q=Horizontal+Shaft+Gas+Engine&hl=en
Cheers, Brian
> Don
> > Jeff
Don
> Jeff
IMO, Add another 1/2" layer of ply to the bottom with a couple of 2x4 'keels' and it will be ready for choppy conditions, and will handle better. RE swinging the 25hp Merc., just have to take some measurements. The trouble I would see with widening the opening is that you'd also be giving up buoyancy at the same time adding a somewhat heavier motor. Tradeoffs, Sigh!
Yeah the 25 may be a bit big, but it's only a problem it you use all the hp and try to turn. ;-D. And, my idea to thicken the bottom a bit would add strength and weight to handle the hp a bit better.
BTW one "solution" would be to build an Idaho as an open runabout. It's a 31' version of pretty much the same boat, and 25hp makes good sense.
Either would be an ez build, have great classic looks, and be a blast to cruise about in on a pleasant afternoon.
Don Schultz
> ......I came across the Sneakeasy, and love the look. Not very practical, but who cares! She looks a little flimsy, though. Not much in the way of a keel. Most of my boating in on the Delaware river. Not to rough, but boat traffic can be a bear. How well does this design take wake? Any idea on draft, and how she handles in tight areas?
> I have a 25hsp Merc that could use a good home!
> Thanks,
> Jeff
There is a variant with a Box Keel/Sponson configuration. This would be
more stable, sturdy, and maneuverable. It would also be harder to build.
highoveryou wrote:
> Thanks Harry,
> I was thinking about that too... how much room is between the tails? Might not be enough for an '85 Merc 25 to swing.
> Jeff
> --- Inbolger@yahoogroups.com, Harry James <welshman@...> wrote:
>> Fritz Funk cruised his on the upper Mississippi, 200 miles on a tank of
>> gas with a 15 hp. I have ridden with him in a light chop here in Juneau
>> and it was a total non issue. The ducktails act like a tunnel when he
>> tilts the motor up between them. In the Wisconsin lakes and slough's he
>> has literally pulled up next to grounded jon boat to pull people off. At
>> slow speeds it does not turn well. 25 hp is a little high. Might be room
>> issues.
>> HJ
>> highoveryou wrote:
>>> Hi,
>>> New here, and to building boats. I started looking at all the plans, and will make a pram of somekind as a tender for a larger boat I have.
>>> Thanks,
>>> Jeff
>>> Bolger rules!!!
>>> - NO "GO AWAY SPAMMER!" posts!!! Please!
>>> - no cursing, flaming, trolling, spamming, respamming, or flogging dead horses
>>> - stay on topic, stay on thread, punctuate, no 'Ed, thanks, Fred' posts
>>> - Pls add your comments at the TOP, SIGN your posts, and snip away
>>> - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930, Fax: (978) 282-1349
>>> - Unsubscribe:bolger-unsubscribe@yahoogroups.com
>>> - Open discussion:bolger_coffee_lounge-subscribe@yahoogroups.comYahoo! Groups Links
Thanks Harry,
> issues.
> HJ
> highoveryou wrote:
> > Hi,
> > Thanks,
> > Jeff
issues.
highoveryou wrote:
> Hi,
> Thanks,
> Jeff
Hi,
