Re: soggy epoxy
Dave,
An 'old hand' like you ADMITTING to such an error?!!?
Anyhow, remember your epoxy chemistry. The 'hardener' doesn't just initiate
the reaction {'catalyst'} it is an integral component of the final {active}
solution.
Typically, once the reaction starts it will go on till completely cured . .
. eventually !!! An elevated ambient temperature should pump energy into the
'system'. A readily available 'curing oven' obviously not at hand, here's
what I do {presuming that the hull is upside down} -
a} Get maybe 6 Porcelain light bulb bases - maybe $2 each, and 6
100w light bulbs.
b} an 8-ft length of '2x4' {or longer -depending on the hull}. I use
Pressure Treated
c} wire the bases -in parallel- evenly spaced along the '2x { put an
insulated layer or two of 'tin foil' under each base is you are
the 'nervous type}
d} leave as much wire as you are comfortable with - and install a
plug.
To use, simply place it UNDER the hull {the hull being elevated on
low 'horses, etc} and plug in the 'Heat Strip'. You can 'adjust' {or
'localize'} the heat out-put by simply slightly unscrewing individual bulbs.
Of course you can add a lot of 'bells & whistles', but this is about as
'dead simple basic' as you can get. I find it very effective, in the winter,
in an unheated shop.
Regards & Good Luck,
Ron Magen
Backyard Boatshop
4a. soggy epoxy
Posted by: "dnjost"davidjost@...dnjost
Date: Fri Jul 17, 2009 3:19 pm ((PDT))
I must have mixed up a batch of System 3 incorrectly. 2:1 eyeballed...
Now I have a soft gummy mix that is ever so slowly starting to set off 48
hours later and still slightly gummy (I can sand, but not smooth). Has
anyone else done this, and should I get out the scraper? Funny thing is
that it was on the bottom, the sides came out perfect with the squeegee.
_______________________________________
No viruses found in this outgoing message
Scanned by iolo AntiVirus 1.5.7.1
http://www.iolo.com
