Re: [bolger] Re: Lawn Mower Engines?
In a message dated 7/18/00 9:58:47 AM Central Daylight Time,
pvanderw@...writes:
<< It also seems
to me that in the Small Boat Journal article about Thomas Firth
Jones' Pilot Cutter, there was a mention that the engine was air-
cooled, but no further description. >>
Thomas Firth Jones' '"Low-Resistance Boats", pp. 133 - 153, shows two boats
he built - a Wm. Garden "June Bug" and his own "Dr. Buzzhead". Both are
equiped with a 5 hp. horizontal shaft Honda air-cooled 4-stroke with 2:1
reduction gearing and a centrifugal clutch. He gives the weight as 33 lbs.
The built-in reduction gearing and clutch seem to have been the big
attractions. The propellor shaft was connected directly to the engine output
shaft (these are inboard installations). One or the other had to be machined
to mate the metric-dimensioned engine to the anglo-saxon dimensioned
propellor shaft. No details are given.
My Boatbuilder collection only goes back to 1984. I would be
interested in buying somebody's collection back to the beginning
if any body is looking to get rid of an old set.
Any chance of your scanning the article into the files?
andy farquhar wrote:
> The 1976 Winter - Fall edition of Boat Builder Magazine contained an
> article about a small, home-built hydroplane called El Cid. This was
> an 8 ft. hydro powered by a 4 h.p. Briggs and Stratton engine. You
> may be able to recreate the motor from the plans in the article.
> Good luck.
> Andy Farquhar
> Old school buds here:
>http://click.egroups.com/1/7081/13/_/3457/_/963938225/
> - no cursing
> - stay on topic
> - use punctuation
_ _ _ _ _
% Harrywelshman@...
Dick-
You can't buy a new lawnmower engine separately as cheaply as you can get
one with the lawnmower attached! Buy one of the "big wheel" mowers and you
can use the back wheels to make a boat dolly. <g>
I've thought quite a bit about how to easily use a vertical shaft lawnmower
engine in a boat, but I never would have thought of this guy's solution:
http://www.boat-links.com/DepoeBay/00/BoatFest-1.html
And this fellow has ben very happy running his boat with an ancient
1.5 hp horizontal shaft engine. He says he rarely runs the engine much over
idle:
http://www.boat-links.com/DepoeBay/98/BoatFest-1.html
http://www.boat-links.com/DepoeBay/99/BoatFest-3.html
The main objections to lawnmower engines in boats are noise and vibration.
The old cast iron engines are quieter and smoother, but I have to admit
that the new Briggs & Stratton engines are pretty darn good (at least for
mowing my lawn). They've got electronic ignitions and real carburettors and
starte easily and run pretty smooth. A BIG muffler and an insulated engine
box would probably help the noise problem, and soft mounts would tame at
least some of the vibration. In a hull like the skiffs in the pictures
above you wouldn't be running the engine full speed much anyway. One of
these days...
On Tue, 18 Jul 2000 14:23:18 -0000, Dick wrote:
> Outboards are expensive and as some say, short-lived. Fraser finds
> them fleeting. Why not use a lawn mower engine as an inexpensive,
> reliable, bolted-down alternative? Sure they'd need to be designed
> in (on the transom?, midship?) with a shaft and transmission. There
> must be reasons why this is not done but I'm not familiar with the
> rationalizations. Can anyone explain why US$125 (my 5 hp. mower cost
> about $170 and has wheels too)for a new lawn mower engine isn't
> better than US$1000 for a new o/b? Don't they like waves? Isn't the
> air as cooling over the water as over the lawn? If the grass catcher
> offends commodores, couldn't it be left off?
John <jkohnen@...>
"Necessity is the mother of invention" is a silly proverb.
"Necessity is the mother of futile dodges" is much nearer the truth.
<Alfred North Whitehead>
> reliable, bolted-down alternative? . . .
Good luck.
Andy Farquhar
In what book?
To: <bolger@egroups.com>
Sent: Tuesday, July 18, 2000 10:24 AM
Subject: [bolger] Re: Lawn Mower Engines?
> Reuel Parker has some worthwhile (on paper at least) ideas about this.
>Air-cooled engines are indeed cheaper, and parts are readily
>available. However, they are also noisier and not necessarily long-
>lived or vibration-free.
>If you are thinking of putting one in the bilge of a cabin boat, you
>need to look into the proper marine carburetors, etc, so you don't
>blow yourself to Kingdom Come. I think B&S used to offer these
>things, and maybe they still do.
>If you have a library with 30 or 40 years of back issues of Popular
>Mechanics and/or Popular Science, (not to mention other hobby
>magazines) you can probably come up with project articles. I remember
>one that used a vertical shaft engine mated to the lower unit of a
>defunct outboard, a sort of saildrive before its time. It also seems
>Peter
>@Backup- Protect and Access your data any time, any where on the net.
>Try @Backup FREE and receive 300 points from mypoints.com Install now:
>http://click.egroups.com/1/6346/13/_/3457/_/963932274/
>- no cursing
>- stay on topic
>- use punctuation
CRUMBLING EMPIRE PRODUCTIONS
134 W.26th St. 12th Floor
New York, NY 10001
(212) 247-0296
Dick
