[bolger] Re: Drain Plugs
i used a bronze half-inch garboard plug with a socket attached from the
outside. she still floats. but if she sinks, i'd consider a diablo
grande. the plans weren't yet available when i built mine. don't know
of anyone who's built the bigger boat, but the extra freeboard might be
nice. on the other hand, that long skinny shape is awfully good in a
quartering sea....
> From: Richard Barnes <oakbowerybarnes@...>
> To:bolger@egroups.com<bolger@egroups.com>
> Date: 01 November 1999 23:42
> Subject: [bolger] Re: Drain Plugs
> >> yup, i put a transom drain in my diablo last season, and it's
changed my
> >> life.
> >Ummmmm,......
> >As in now your boat is much better.... ;or now your boat is on the
> >bottom?????
> >As a potential Diablo builder I am curious about the boat and your
> >impressions, plus more specifics about the transom plug.
> >I am currently building the Glen-L design "Sweet Caroline" as a
stitch and
> >glue boat ( intending to include transom plugs )and may build a
Diablo or
> >Diablo Grande to accompany it. Did you consider the Diablo Grande?
> >Thanks,
> >Richard
monic-@...wrote:
original article:http://www.egroups.com/group/bolger/?start=611
> Does anyone else use drain plugs on their boats?
> After the first week my Galley was actually outside I was shocked to
> realize rain would actually collect inside it. So I got a brace and a
1
> inch bit and made a hole at the lowest rocker point. After it dried I
> took a PVC threaded end and epoxied that in place, first stuffing
paper
> towells into it to keep the threads clean. After it cured I faired it
> on the botom with a belt sander. The cap screws in from the inside.
> Cost me 2-3 bucks for the PVC fittings. Has worked for years now.
> Anyone else do something like this?
> Good idea on drain plugs, did the same on a much larger vessel. You
can make the scoops out of a larger PVC pipe. Cut it at an angle, then
epoxy tape it over the drain and paint to match. Brad
FYI - Picture of Tim Smith's stretched Diablo is to be found in Chebacco
News #28.
--bill.samson@...
Chebacco News can be viewed on:
http://members.xoom.com/billsamson
>> yup, i put a transom drain in my diablo last season, and it's changed my
>> life.
>Ummmmm,......
>bottom?????
>I am currently building the Glen-L design "Sweet Caroline" as a stitch and
>glue boat ( intending to include transom plugs )and may build a Diablo or
>Thanks,
>Richard
>-- 20 megs of disk space in your eGroup's Document Vault
>--http://www.egroups.com/docvault/bolger/?m=1
> life.
Ummmmm,......
bottom?????
Richard
life.
>From:bolger@egroups.com
>Date: Sat, Oct 30, 1999, 4:05 PM
> This sound sounds like a GREAT idea!
> If you put a little "scoop" with the opening facing aft, you'd have a
> great self-bailing device!
>>realize rain would actually collect inside it. So I got a brace and a 1
>>took a PVC threaded end and epoxied that in place, first stuffing paper
>>Looking for the hottest sports memorabilia or sporting goods
>>specials? eBay has thousands of trading cards, sports autographs
>>and collectibles.You never know what you might find at eBay!
>>http://clickhere.egroups.com/click/1143
>>eGroups.com home:http://www.egroups.com/group/bolger
>>http://www.egroups.com- Simplifying group communications
> David Ryan
> Minister of Information and Culture
> Crumbling Empire Productions
> (212) 247-0296
Hi,
Drain plugs are fine, but are no substitute for checking regularly under the
tarp. I had a skiff a few years ago that I put under a tarp for the winter
with drain plug open. I neglected to look at it for a month or so, and when
I did eventually look, it had 6" of water in the bottom! Reason was that
leaves had blown under the tarp and blocked the plug hole.
Bill
--bill.samson@...
Date: 31 October 1999 03:03
>No, but thank you for answering one of my questions. I've been trying to
>figure out how to fit a tradional brass hole/pluf through the chine of
>Windsprint right at the point of greatest rocker. Even though I'm going to
>put a tarp over the boat, this is florida, and it often rains sideways.
>some water will collect. would love to hear other solutions to this
>difficulty.
>Robert Lundy
>St. Petersburg, Fla.
>> From:monica@...[mailto:monica@...]
>> Sent: 30 October, 1999 3:55 PM
>> Subject: [bolger] Drain Plugs
difficulty.
Robert Lundy
David Ryan
(212) 247-0296
