Re: Plywood/fiberglass Sandwich
There is a book on this topics available on the net at the address
http://www.marinecomposites.com/.
Regarding amateur construction, the only designer that I know who
advocates the use of the FG/ply/FG sandwich is Jacques Mertens at
bateau.com, but I never heard of ply/FG/ply sandwiches. It sound like
a nightmare to build.
Jacques redesigned his Vagabond with the new scantlings, and the boat
is now mostly made with 6 mm plywood sandwiched in two layers of 9-oz
biaxial. Justin Pipkorn has built and now sails and races the boat
with amazing results. Jacques says that "Tensile and flexural
strength of the [6 mm sandwich] panels is much higher than the 9mm
plywood version with all the other advantages of a fiberglass hull".
Just for the record, the Vagabond is a 20 footer displacing more than
2000 pounds.
Best, Pippo
--- Inbolger@egroups.com, David Ryan <david@c...> wrote:
> FBBB --
> I was contemplating plywood planking while we drove into the city
> last night and began to wonder if adding a layer of glass between
> courses of plywood would do anything besides adding work, weight
> expense.
> What prompted this is how much stiffer the Light Scooner Margaret
> Ellen is now that she has her 6/3 oz fiberglass skin. Would the
> effect by multiplied in a 1/4"-6oz-1/4"-6oz-1/4"-6oz layup, or
merely
> cumulative? Do plywood and glass/epoxy have some sort of
> complimentary nature?
> -D
> 134 W.26th St. 12th Floor
> New York, NY 10001
> (212) 247-0296
FBBB --
courses of plywood would do anything besides adding work, weight and
expense.
effect by multiplied in a 1/4"-6oz-1/4"-6oz-1/4"-6oz layup, or merely
-D
New York, NY 10001
(212) 247-0296
