Re: Idaho, Clam Skiff, Tenn, Atkin ideas
I had and have seen at places like West Marine, a little rectangular (2" x 4" x 3/4" maybe) screen/crud protector for bilge pumps. The back and sides are solid and there is a flat perforated face and the thing will take a 1/2" hose from a small bilge pump. If you turn the thing face down, it will suck water down pretty far, just have to make sure it cannot form a vacuum against the hull.
Cheers, Brian
--- Inbolger@yahoogroups.com, charleswhodges@... wrote:
> Another problem that I have thought about is water in the flat bottom of the boat. You stand on the bottom. There are no floors above a bilge. No Vee bottom to create a sump. Any water in the boat and you are standing in it. Mr. Bolger made a floor in the Idaho cabin about 1.5 inches above the bottom. Plywood with one inch slats fastened underneath laid on the bottom of the boat.
> Any ideas for a bilge pump that will pump down to maybe 1/8 inch? A flat piece of plywood spaced 1/8" from the bottom with a suction hose in the middle hooked to a diaphragm pump?
> A Shop Vac with a bilge pump inside to empty it?
> Charles
If you are looking for a flooded motor, look at a submersible well pump. I can't remember the name of the company, but one company makes the guts for almost all US pump brands. You may be able to buy just the motor from them.
Myles J. Swift
Computer Assistance Inc.
auto/truck repair management
software since 1977
voice 541-895-3347
It would be a hybrid drive. One good thing about the setup is that if your battery bank is 48 volts, you can charge 48 volts. The regen feature is much cheaper as an option on a controller than buying a big 48 volt engine alternator. Use the 12 volt engine alternator to maintain the separate 12 v. starting system.
Charles
--- Inbolger@yahoogroups.com, "daschultz2000" <daschultz8275@...> wrote:
> "Regen" depends on there being kinetic energy to spin the motor which is, for the moment, connected to act as a dc generator. This works well when you have a large mass moving to provide the energy (like a string of rail cars) and is used primarily for braking. The locomotives have resistor banks on top to take the energy and convert it to heat and disapate it.
> If I understand you right, you are thinking of a hybird drive where the IC engine drives the prop through the motor shaft and the motor doubles as a generator when the IC (diesel or gasoline) is driving the prop. This would be an optimal use of installed components. A sprag clutch would be a low drag way to get the IC engine connect to the drive and MUCH better than an electro magnetic scheme.
> Might find what you need in a GM automatic transmission from the last 15-20 years or so.
> Don
> --- Inbolger@yahoogroups.com, charleswhodges@ wrote:
> >...the regen circuit can charge the batteries....
Garth is the PUBLISHER. Robb White is the author. I don't know who edited it...
Flotsam and Jetsam: The Collected Adventures, Opinions, and Wisdom from a Life Spent Messing About in Boats (Paperback)
On Wed, Sep 23, 2009 at 5:51 PM, Jay K. Jeffries<bottomgun@...>wrote:
John,
Do you have a title for the book.  Just looked up Garth Battista as author on Amazon but could find no listing for a nautical book.
R/Jay
From:bolger@yahoogroups.com[mailto:bolger@yahoogroups.com]On Behalf OfJohn Bell
Sent:Wednesday, September 23, 2009 2:18 PM
Subject:Re: [bolger] Re: Idaho, Clam Skiff, Tenn, Atkin ideas
Garth Battista (who sometimes posts here) recently published a collection of Rob White essays. Buy the book!
Charles
John,
Thanks!  I just found a review of the book this evening in the back of the latest WoodenBoat.
R/Jay
From:bolger@yahoogroups.com [mailto:bolger@yahoogroups.com]On Behalf OfJohn Bell
Sent:Saturday, September 26, 2009 8:46 PM
On Wed, Sep 23, 2009 at 5:51 PM, Jay K. Jeffries <bottomgun@...> wrote:
John,
R/Jay
Don
I wonder if you could get a drive off a wrecked Prius...
Sent: Saturday, September 26, 2009 4:36 AM
> One thing I considered is a drive like a diesel submarine. Get an electric
> vehicle controller with regen braking and an brushed motor. Connect the motor
> to the prop shaft with a belt. Size the pulleys to get the motor rpm in the
> best range. Use a dog clutch or a bidirectional sprag clutch to disconnect the
> diesel from the prop shaft when needed. With the diesel disconnected you have
> electric drive. When cruising on diesel power, the regen circuit can charge
> the batteries . I think the charge rate is fully controllable and can be
> quite high. Good EV controllers are now down to <$400, some a lot less and
> have a lot of programable features.
One thing I considered is a drive like a diesel submarine. Get an electric vehicle controller with regen braking and an brushed motor. Connect the motor to the prop shaft with a belt. Size the pulleys to get the motor rpm in the best range. Use a dog clutch or a bidirectional sprag clutch to disconnect the diesel from the prop shaft when needed. With the diesel disconnected you have electric drive. When cruising on diesel power, the regen circuit can charge the batteries . I think the charge rate is fully controllable and can be quite high. Good EV controllers are now down to <$400, some a lot less and have a lot of programable features.
Charles
On Fri, Sep 25, 2009 at 6:16 AM, daschultz2000<daschultz8275@...>wrote:
Charles nails the primary issues.
Also you can't flood the bearings with water and expect any kind of life.  Lubricity of water is way to low, and you'll never keep the water out of the bearings.
Counter-example: cutless bearings on the prop end of the shaft log of any inboard installation. They're turning about the same speed, but they aren't thrust bearings. Hydrodynamic bearings are another reasonable possibility -- low maintenance but tricky to make in the first place.
If running such a motor flooded was a good idea, the scooters for SCUBA divers would have been using them years ago.  They don't.
I don't believe any of the scooters use brushless motors, which are the only kind where flooded running is possible even as a thought experiment. This isn't all that surprising -- BLDCs have only started to get into consumer products other than hard disk drives (which, AIUI, have pretty much always been brushless) in the past few years and most of the scooter designs I've seen are much older than that.
-p
Sounds like a real working drawing.  Nothing to be ashamed of there.
~Caloosarat
From:bolger@yahoogroups.com [mailto:bolger@yahoogroups.com]On Behalf Ofcharleswhodges@...
Sent:Friday, September 25, 2009 5:01 PM
Subject:[bolger] Re: Idaho, Clam Skiff, Tenn, Atkin ideas
The 2006 Mechanical Desktop version I have came with Inventor 9. I'm sure it saves in 2004 format or can save in 2000 format. The mechanical desktop just adds a lot of built in strength of materials/beam allowable loading calc. etc. so you don't have to look it up. A lot of pre-drawn structural shapes too. The underlying cad is 2004.
I probably have 10 to 15 files where I drew Idaho, Rescue Minor, Shoals Runner and many others from various places to use the parts to cut and paste. No formal drawings with borders and specs but a lot of combinations and trials as my thoughts changed over time. Not very organized.
Charles
--- Inbolger@yahoogroups.com, "Chester Young" <chester@...> wrote:
> Charles:
> Not sure how AutoCAD Mechanical works but the standard version of CAD
> saves as 2004 up until 2008 wherein it is an option to save as 2004
> format or 2008, there is no 2006 version. Regardless I have
> subscription on all the seats in our office so we have 2010 available.
> If you save it in its native format that should be good enough. I have
> elected to stay with 2008 or earlier due to the operating overhead that
> the 2009 and later require to run. The next step will be to switch over
> to 64 bit machines, we have one in the office but there are a number of
> frequently used programs that are not yet available in 64 bit format or
> I am being too cheap to purchase updated software when the 32 bit
> version works just fine. I look forward to seeing a vector generated
> version of your hull and am even more interested in how it will perform.
Charles
> Charles:
Thanks Charles,
I'll Check his site out.
Chris
> Chris,
> Robb White's web site is still up. Check it out.
>http://www.robbwhite.com/rescue.minor.machinery.html
> Charles
> --- Inbolger@yahoogroups.com, "gaff_rigged72" <gaff_rigged72@> wrote:
> > Charles,
> > Do you recall where I could find the Rescue Minor specs that Mr. White wrote about, especially the keel cooler. I recall that the Wooden Boat article was much abrieviated (and not much detail in his WB bio), and also reading at least one article in Messing About.
> > Thanks
> > Chris Brunette
Brushless DC motors are pushing out brushed DC motors and even some AC motors in industry and hobby applications all over the place as the required control electronics rise in efficiency and fall in price. Charles had an excellent point about pumping losses if there's water in the gap between the rotor and the stator. His idea of just running a vent tube down from topsides and keeping a slight positive pressure in the motor to keep water out should work well. And needless to say, the motor I described would be a custom job.
-p
On Fri, Sep 25, 2009 at 2:45 AM, hs<hardystein2004@...>wrote:
--- Inbolger@yahoogroups.com, Pierce Nichols <rocketgeek@...> wrote:
> On Thu, Sep 24, 2009 at 6:52 PM, <charleswhodges@...> wrote:
> > Electric is better than hydraulic. Use a golf cart controller and parts.
> Speaking of electric, I've been thinking of the possibility of a flooded
> brushless DC motor for final drive. Since it doesn't have brushes and all
> the conducting bits are stationary, you can encapsulate them and obviate the
> need for moving seals of any kind. The seawater flowing through the motor
> provides the cooling. The only through-hull needed is a hermetically sealed
> electrical connector. If you use an outrunner type design (rotor on the
> outside of the stator), you might even be able to integrate it into the hub
> of the prop. Seems like, with appropriate design, it could be the lowest
> maintenance and most durable marine propulsion system. Thoughts?
> -p
That sounds BRILLIANT !
Where are  brushless motors like this used ?
I`m guessing industry , but being DC I`m curious where  you would source  such a motor .Can you expand on ths please ?
How large a motor would you need for say a 30 ft boat ?
- NO "GO AWAY SPAMMER!" posts!!!  Please!
<*> Your email settings:
(Yahoo! ID required)
mailto:bolger-digest@yahoogroups.com
mailto:bolger-fullfeatured@yahoogroups.com
Charles:
Not sure how AutoCAD Mechanical works but the standard version of CAD saves as 2004 up until 2008 wherein it is an option to save as 2004 format or 2008, there is no 2006 version.  Regardless I have subscription on all the seats in our office so we have 2010 available. If you save it in its native format that should be good enough.  I have elected to stay with 2008 or earlier due to the operating overhead that the 2009 and later require to run.  The next step will be to switch over to 64 bit machines, we have one in the office but there are a number of frequently used programs that are not yet available in 64 bit format or I am being too cheap to purchase updated software when the 32 bit version works just fine.  I look forward to seeing a vector generated version of your hull and am even more interested in how it will perform.
Caloosarat
Sent:Thursday, September 24, 2009 9:15 PM
Caloosarat,
It will take a while to get the CAD file. My computer crashed a while back and I switched to a Macbook. I have Autocad mechanical 2006 but have to run it in a windows environment. Haven't gotten all sorted out yet. When I do, I can save the file in an older version if you need it.
I think the tunnel effectively adds considerable rocker to the shape. I built the back of the trailer flat and the rear of the boat, where the anti-trip chines are, is well above the trailer bed.
Charles
> Charles:
> What is the chance of you posting your Cad dwg to the files section? I
> have drawn a considerable bit of the Tennessee in Cad (2D only) while
> reworking the EstherMae and am very interested in what others may be
> doing with the same or similar hull. I have also gotten my hands on a
> book of naval ship handling and the similarities of the Tennessee to a
> destroyer are captivating, in that respect the slight rocker that the
> Tennessee has in comparison to the Idaho's flat run seems to be of value
> when running at or above planning speeds in light chop or rougher water.
> With your modified stern you may very likely improve on the handling,
> although I would caution about a following wake with the bow being
> straight as it may hold a set direction when a larger vessel overtakes
> you. First you surf then you broach, if your wife is like mine she will
> not have any fascination with the handling characteristics that result.
> ~Caloosarat
[mailto:bolger@yahoogroups.com] On Behalf
> Of charleswhodges@...
> Sent: Tuesday, September 22, 2009 9:46 AM
> Subject: [bolger] Idaho, Clam Skiff, Tenn, Atkin ideas
> I have put some pictures in a Bolger2 photo album named Adagio.
> I wanted to build a quiet day boat/ picnic boat. The Idaho seemed about
> right but I had an inboard 33hp. diesel on hand from a Tennant parking
> lot sweeper.
> I asked Mr. Bolger about using The Clam Skiff bottom on the Idaho. He
> said that he thought it work well and the CS transom could be used too
> if desired.
> I liked the flat bottom and heavier construction of the Idaho over the
> Tennessee but I liked the 6' width of the Tennessee better than the 5'
> Idaho - especially with an engine taking up room.
> The Atkin Sand Piper is a tunnel hull design that is dead flat in the
> center. That mated easily to an Idaho front section which is also flat.
> The chines of the Sand Piper go straight back from the center with no
> rocker so the sides are below the waterline to give the stern more
> floatation. Picture a Sand Piper with the timber keel widened to a box
> keel. The flat bottom ahead of the tunnel may be a problem at planing
> speeds. A slight vee up front might shift air bubbles to the outside and
> keep them out of the tunnel and the propeller. I don't plan to travel
> that fast and want very shallow draft.
> The Atkin Shoals Runner has an inboard rudder and prop protected by a
> steel skeg. It has anti-trip chines.
> I liked Robb White's keel cooler idea. I plan to use a vertical dry
> stack. The Kubota engine has a variable displacement piston hydraulic
> pump that I will close-couple to a bent-axis piston motor. It is closed
> circuit and should be 90+% efficient. I should be able to cruise at
> maybe 7.5 knots(1.34 x sqrt 32') on about 1/2 gallon per hour. I'm using
> a 10 inch 1960-1968 Evinrude pin drive prop. It fits a straight shaft,
> no taper or splines to cut, is inexpensive, available in several pitches
> and was used for up to 90 hp at high rpm. My motor displacement is less
> than the pump displacement so my gearing is a 24% overdrive- If the
> diesel is set at 2000 rpm (3000 is max) the prop can go from 0 to 2500
> rpm in either direction.
> I used Autocad to put all the ideas together and do the weight and
> balance calculations. I used vertical sides for the box keel to make
> drawing true shape patterns easy. I used 5 ply fir MDO plywood and
> epoxy.
> Charles
Charles. You are one smart cookie. Thank you for your contributions here.
Don
> If the moving parts move water, you will have drag losses like a pump. Air is much easier to move than water and less corrosive. Maybe a sealed motor with a slight positive pressure through a vent tube to keep the water out. The wires could go in the tube. Water would still cool the stator.
> Charles
> -p
Be aware that Robb White's boat, which he unfortunately named "Rescue
Minor," was not built to the Atkin Rescue Minor plans! The cantankerous
cracker studied several Atkin tunnel-stern Seabright skiff designs,
V-bottom and round-bilge, and then designed his own boat using the Atkin
plans for inspiration. Since Robb White launched his boat, several Rescue
Minor's built more or less to the plans have been launched. If you want to
see how a Rescue Minor works, look at the newer boats, not Robb's. Not
that Robb's boat is a bad boat, it's just not a Rescue Minor and doesn't
perform the same as a boat built to the Atkin plans.
http://www.boat-links.com/Atkinco/Photos/RescueMinor/
Sand Piper isn't a tunnel-stern Seabright skiff like Rescue Minor. It's
sort of a twisted V-bottom, and I doubt that the idea is an Atkin
original. Lots of people were plying with tunnel sterns in the old days,
even on Seabright skiffs. William Atkin's innovation was the V-bottom
Seabright skiff, and the tunnel-stern variations thereof.
http://www.boat-links.com/Atkinco/Cruisers/SandPiper.html
John <jkohnen@...>
They that can give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety. <Benjamin
Franklin>
Charles
> -p
As to cost, it is only feasible because I used a complete existing hydraulic drive system and just transferred it from a sweeper to a boat. I changed the motor for one of the same type but different displacement because I need to turn the prop faster than they were turning the tires. I did not have to pay anything for the sweeper. It had a bad engine. The local Tech School rebuilt it for me in their diesel class.
Hydraulic design is best left to professionals. I used an existing design from a very large company with years of experience and thousands of units in production.
What you say about rpm is true of gear pumps and gear motors. Low rpm, low pressure, maybe 80% efficient, open circuit, lots of heat and noise. I am using a closed circuit system with piston pump and motor. Rated at over 5000 psi at up to 10,000 rpm. without the ( or as much?) noise or the heat.
I think that for a non-professional an electric system design has a better chance of success. Even that requires someone that likes to tinker with components. If you just want to go boating ( called "yachting" if women and music are present ) the old mechanical drive is still the best. I'm told that used marine engines complete with gearboxes can be quite reasonable along the coast. Most probably are not advertised and have to be hunted. They are old takeouts from when people install bigger or newer power. Some are probably in running condition. Some need a trip through the Tech School.
Charles
--- Inbolger@yahoogroups.com, Giuliano Girometta <ggboat1@...> wrote:
> There is also a considerable development of heat in an hydraulic pums and heat is also energy.
> Being a little bit familiar with remotely controlled hydraulic controls operation I did a little research about the cost for a similar installation and discovered that the total cost is way above a traditional installation with motor and gears.
> First problem, you need a higher HP motor to develop the same HP output at the prop.
> You save the money of the gearbox, but the cost of the hidraulic pump, motor, bi-directional valve, hoses, fittings and recovery tank is waaaaay high.
> You may save money by obtaining the parts from a surplus center, but the prices still high and you may end up with the problem that you can not find spare parts.
> Furthermore, most of the hydraulic pumps are rated for a maximum rpm that is about half of the RPM of a small diesel, therefore you still need a reduction gear or couple the pump to the motor with a belt and puley system.
Speaking of electric, I've been thinking of the possibility of a flooded brushless DC motor for final drive. Since it doesn't have brushes and all the conducting bits are stationary, you can encapsulate them and obviate the need for moving seals of any kind. The seawater flowing through the motor provides the cooling. The only through-hull needed is a hermetically sealed electrical connector. If you use an outrunner type design (rotor on the outside of the stator), you might even be able to integrate it into the hub of the prop. Seems like, with appropriate design, it could be the lowest maintenance and most durable marine propulsion system. Thoughts?
-p
Eric,
Replies follow questions below.
--- Inbolger@yahoogroups.com, "eric14850" <eric14850@...> wrote:
> I would like to know your resources for acquiring hydraulic pumps and motors, and about sizing motors and pumps to match. My needs are in the less than ten hp range. At one point I wanted to mount a hydraulic motor and folding prop on my rudder. Gave up for lack of info and sources. Present idea is a side or rudder mounted Torqueedo electric outboard. But this is the second reference to hydraulic drive in the past week. Maybe it is time to revisit the notion.
The Kubota was in a hydraulic powered sweeper that I got locally. It had several hydraulic motors but none the right speed. I bought a new/takeoff motor in the size and type I needed from a surplus dealer on the web.
Electric is better than hydraulic. Use a golf cart controller and parts. I'm using hydraulic because I had it on hand mostly for free. It has problems - heat and whine - especially if you do a poor job of design when matching up components. I am a retired engineer. That helps.
> You mentioned gearing. Gearing involves losses as does hydraulic drive. Proper matching of pump and motor and reversable motor should obviate any need for gears. Why did you use gears?
I did not use gears. Displacement ratio between pump and motor has the same effect on speed and torque as the ratio between a driving and a driven gear.
> Seems 33HP could drive you at considerably more than 7kn.
True but with higher fuel usage and a rougher ride. This particular Kubota is bigger and heavier than I would like but it is what I have. The engine will deliver 33hp (29 cont.) at 3000 rpm. It will deliver about 20 hp at 2000 rpm. I plan to cruise it at 2000 rpm under partial load - maybe < 10 hp. Today's efficient engines get up into the range of 18 hp-hours/ gallon so 9 hp. would use 1/2 gallon/ hour (9/18). 29 hp. would use 1.61 gallons per hour (29/18). A 50 year old engine or one in poor shape might be 12 -14 hp.-hr/gallon - not as efficient.
Charles
Chris,
Charles
--- Inbolger@yahoogroups.com, "gaff_rigged72" <gaff_rigged72@...> wrote:
> Charles,
> Thanks
> Chris Brunette
> > I wanted to build a quiet day boat/ picnic boat. The Idaho seemed about right but I had an inboard 33hp. diesel on hand from a Tennant parking lot sweeper.
> > I asked Mr. Bolger about using The Clam Skiff bottom on the Idaho. He said that he thought it work well and the CS transom could be used too if desired.
> > I liked the flat bottom and heavier construction of the Idaho over the Tennessee but I liked the 6' width of the Tennessee better than the 5' Idaho - especially with an engine taking up room.
> > The Atkin Sand Piper is a tunnel hull design that is dead flat in the center. That mated easily to an Idaho front section which is also flat. The chines of the Sand Piper go straight back from the center with no rocker so the sides are below the waterline to give the stern more floatation. Picture a Sand Piper with the timber keel widened to a box keel. The flat bottom ahead of the tunnel may be a problem at planing speeds. A slight vee up front might shift air bubbles to the outside and keep them out of the tunnel and the propeller. I don't plan to travel that fast and want very shallow draft.
> > The Atkin Shoals Runner has an inboard rudder and prop protected by a steel skeg. It has anti-trip chines.
> > I liked Robb White's keel cooler idea. I plan to use a vertical dry stack. The Kubota engine has a variable displacement piston hydraulic pump that I will close-couple to a bent-axis piston motor. It is closed circuit and should be 90+% efficient. I should be able to cruise at maybe 7.5 knots(1.34 x sqrt 32') on about 1/2 gallon per hour. I'm using a 10 inch 1960-1968 Evinrude pin drive prop. It fits a straight shaft, no taper or splines to cut, is inexpensive, available in several pitches and was used for up to 90 hp at high rpm. My motor displacement is less than the pump displacement so my gearing is a 24% overdrive- If the diesel is set at 2000 rpm (3000 is max) the prop can go from 0 to 2500 rpm in either direction.
> > I used Autocad to put all the ideas together and do the weight and balance calculations. I used vertical sides for the box keel to make drawing true shape patterns easy. I used 5 ply fir MDO plywood and epoxy.
> > Charles
Caloosarat,
Charles
> Charles:
> ~Caloosarat
> From:bolger@yahoogroups.com[mailto:bolger@yahoogroups.com] On Behalf
> lot sweeper.
> if desired.
> epoxy.
> Charles
If the boat is going at displacement speed only, i will consider a Kitchen rudder so you don't need the gears because the rudder can act also as reverse power.
At higher speeds the Kitchen rudder generate more turbolence and is not economic, but at hull speed and below you have a better steering response than a traditional rudder and you can turn the boat all around almost in the same space.
I am considering this type of rudder in one of my next projects for a 28 ft low power cruiser.
Giuliano
--- OnThu, 9/24/09, Pierce Nichols<rocketgeek@...>wrote:
Subject: Re: [bolger] Re: Idaho, Clam Skiff, Tenn, Atkin ideas
To: bolger@yahoogroups.com
Date: Thursday, September 24, 2009, 3:25 AM
Hydraulic losses are generally higher than gearing losses, because you have fluid flow losses in the hydraulic system piled on top of the friction in the shafts and the sliding seals in the pump and motor. The advantage of hydraulic drive is being able to continuously vary the effective gear ratio and much relaxed mounting constraints for all the major components. I think that you're going to have to hit the textbooks for a good overview of the subject. I'm not an expert, so I don't have any good suggestions, except that the term 'fluid power' is very common in the literature.
One serious issue with hydraulics: IME, there are three kinds of hydraulic systems -- those that leak, those that have not yet been filled, and those that have leaked out all their fluid. That implies that you will need to use environmentally safe hydraulic fluid in order to remain in good odor with your local authorities and peers... and it's really expensive.
-p
Eric
> Charles
- Unsubscribe:  bolger-unsubscribe@ yahoogroups. com
- Open discussion:bolger_coffee_ lounge-subscribe @yahoogroups. comYahoo! Groups Links
   http://groups. yahoo.com/ group/bolger/
   http://groups. yahoo.com/ group/bolger/ join
   mailto:bolger-digest@ yahoogroups. com
   mailto:bolger-fullfeatured @yahoogroups. com
   http://docs. yahoo.com/ info/terms/
Yeah I've got "Folding Schooner" and have considered building that boat, but NOT with the tunnel. I thought to build it as a kind of v-bottom Michalak AF4G, with twin outboards. Maybe a couple of 25s.
IMO Bolger's tunnel was to crude and draggy. "Utility for Homebuilders" probably wasn't going to do anything to well as drawn. The Atkin Tunnel Stern is much more sophisticated and very low drag.
Don
--- Inbolger@yahoogroups.com, "John and Kathy Trussell" <jtrussell2@...> wrote:
> ....PCB drew a tunnel stern/deep V utility (See Utility for Home Builders,
> Chapter 9 of The Folding Schooner). As far as I know, he never pursued
> tunnel hulls after this, though a tunnel stern mated with a box keel would
> seem to be a natural.......
He actually did a sort of tunnel design and I still am not sure if it was
intentional or not. Fritz Funk has been running his sneakeasy in Wisconsin for
several seasons. He has found that he can run in shallower water than Jon boats
with jet drives by tilting the motor up so that it is in between the ducktails. He
keeps promising to write all this up and I keep nagging.
>> For a long time, I've thought the tunnel stern/box keel would be an
>> excellent combination and had hoped Phil would have done some work on such a
>> concept. I've toyed around with the idea and worked up some sketches. This
>> combination solves a lot of problems. It allows for low placement of engine
>> and ballast while retaining shallow draft and provides for standing headroom
>> without a lot of top hamper.
> Fred Schumacher
-p
Eric
> Charles
Eric
> Charles
Nels,
You've got a point there -- I suppose I think of small powerboats primarily as a way to get somewhere on the water in a hurry, not as pulling boats or something like that.
-p
On Wed, Sep 23, 2009 at 6:45 PM, prairiedog2332<arvent@...>wrote:
I still see a place for a little diesel - like on the afor-mentioned
Motorsailer and after seeing a lot of them when I was in Norway. Not
sure if the project and cost is that much greater  than say an
equivalent 4-stroke outboard.
But it does depend on how fast you want to go.
> It seems to me that given the variety and quality of outboards
generally
> available on the market today, it's hard to justify an inboard for a
small
> powerboat absent special requirements restricting prop placement (such
as
> ski boats) or mandating jet drive. Inboard installation is a pretty
> significant project compared to bolting the entire drivetrain as a
single,
> self-contained unit.
> -p
> On Wed, Sep 23, 2009 at 11:16 AM, John and Kathy Trussell <
> jtrussell2@... wrote:
> >  Fred,
generally
small
as
single,
> -p
> > Fred,
It seems to me that given the variety and quality of outboards generally available on the market today, it's hard to justify an inboard for a small powerboat absent special requirements restricting prop placement (such as ski boats) or mandating jet drive. Inboard installation is a pretty significant project compared to bolting the entire drivetrain as a single, self-contained unit.
-p
On Wed, Sep 23, 2009 at 11:16 AM, John and Kathy Trussell<jtrussell2@...>wrote:
Fred,
PCB drew a tunnel stern/deep V utility (See Utility for Home Builders, Chapter 9 of The Folding Schooner). As far as I know, he never pursued tunnel hulls after this, though a tunnel stern mated with a box keel would seem to be a natural.  With the scarcity of small inboards and the ability of outboards to kick up and/or propel boats while the motor is partially raised, PCB might have felt that there was little need for the complex construction needed for a tunnel stern.
JohnT
From:bolger@yahoogroups.com[mailto:bolger@yahoogroups.com]On Behalf OfFred Schumacher
Sent:Wednesday, September 23, 2009 12:35 PM
Subject:Re: [bolger] Idaho, Clam Skiff, Tenn, Atkin ideas
For a long time, I've thought the tunnel stern/box keel would be an excellent combination and had hoped Phil would have done some work on such a concept. I've toyed around with the idea and worked up some sketches. This combination solves a lot of problems. It allows for low placement of engine and ballast while retaining shallow draft and provides for standing headroom without a lot of top hamper.
Fred Schumacher
John,
R/Jay
Right you are John ... White's and Atkin's Rescue Minors (or is it Rescues Minor) are pretty nifty boats none-the-less. I was a bit disappointed that some of RW's technical adaptations weren't described in his new book, although I'd recommend it heartily.
Chris
--- Inbolger@yahoogroups.com, John Bell <yonderman@...> wrote:
> Despit the name, Robb White's Rescue Minor is not the same boat as Atkin's
> version. Robb took a lot of inspiration from Aktin, but the boat was
> entirely his design.
On Wed, Sep 23, 2009 at 2:07 PM, John Weiss<jrweiss98155@...>wrote:
Robb White wrote a lot for Messing About in Boats, so you might call or write
Bob Hicks and ask him if he has an archive of Rescue Minor articles.
Sent: Wednesday, September 23, 2009 8:12 AM
> Charles,
> Thanks
> Chris Brunette
Fred,
JohnT
From:bolger@yahoogroups.com [mailto: bolger@yahoogroups.com ]On Behalf OfFred Schumacher
Subject:Re: [bolger] Idaho , Clam Skiff, Tenn , Atkin ideas
Fred Schumacher
> Charles,
> Thanks
> Chris Brunette
Fred Schumacher
Charles:
What is the chance of you posting your Cad dwg to the files section?  I have drawn a considerable bit of the  Tennessee in Cad (2D only) while reworking the EstherMae and am very interested in what others may be doing with the same or similar hull.  I have also gotten my hands on a book of naval ship handling and the similarities of the Tennessee to  a destroyer are captivating, in that respect the slight rocker that the Tennessee has in comparison to the Idaho’s flat run seems to be of value when running at or above planning speeds in light chop or rougher water.  With your modified stern you may very likely improve on the handling, although I would caution about a following wake with the bow being straight as it may hold a set direction when a larger vessel overtakes you.  First you surf then you broach, if your wife is like mine she will not have any fascination with the handling characteristics that result.
~Caloosarat
Sent:Tuesday, September 22, 2009 9:46 AM
Subject:[bolger] Idaho, Clam Skiff, Tenn, Atkin ideas
Charles
Despit the name, Robb White's Rescue Minor is not the same boat as Atkin's version. Robb took a lot of inspiration from Aktin, but the boat was entirely his design.
On Wed, Sep 23, 2009 at 11:12 AM, gaff_rigged72<gaff_rigged72@...>wrote:
Charles,
Thanks
Chris Brunette
> Charles
Charles,
Thanks
Chris Brunette
> Charles
If you haven't, I suggest posting on the Atkin group links to your photos here in Bolger 2.
Another interesting example of the tunnel stern in Carlson's live aboard cruiser. He is the author of the HULLS software.
http://www.carlsondesign.com/alligator.html
I found, years ago, some sketches of a WWII era high speed tanker designed by Atkin, using the tunnel stern design. He apparently believed it would work in larger craft also.
Don Schultz
> Charles,
> I find your boat fascinating. I've long admired Atkin's tunnel stern. There are some good video clips out now on the Atkin site of a version called Rescue Minor.
Charles,
I find your boat fascinating. I've long admired Atkin's tunnel stern. There are some good video clips out now on the Atkin site of a version called Rescue Minor. The long slender boat moves with no apparent effort at good speed through shallow water. I always had a difficult time 'seeing' what the stern area looked like in the drawings, but your photos make things very clear. The construction looks to be very high quality, and I look forward to additional pics as the project progresses.
I also greatly admire your power choice. My only concern will by hydraulic whine from the pump/motor combo, but the close connection may help with that. A truck muffler should moderate exhaust noise well. The propeller you have picked is ideal. As you described it, I immediately appreciated the great choice that it is. I remember someone making an adjustable pitch version that a friend had on his 60's 40hp Johnson. If you came across one of those at an antique outboard flea market, you'd be able to dial in the pitch you need. In any case, you will be able to find, at low cost, exactly the right prop for the purpose.
Anyway, wonderful design work and execution.
You might consider publishing plans. Now that the hull has been built, is it possible the developed plywood panels have been documented to make this something of an "instant" project?
Don Schultz
> I wanted to build a quiet day boat/ picnic boat. The Idaho seemed about right but I had an inboard 33hp. diesel on hand from a Tennant parking lot sweeper....
Charles
