Re: micro reefing (was long micro)
Goodboat,
Yes, I use the jiffy line for the outhaul as well.
MylesJ
----- Original Message -----From:Myles J. SwiftSent:Monday, October 26, 2009 1:59 PMSubject:[bolger] micro reefing (was long micro)I agree that the recommended reefing procedure is a pain. Plus, you end up with a boom that is banging against the mast after fastening the rear of the boom to the rear reef grommet and sticking several feet of boom ahead of the mast.
I have followed my own variation. I ran a light line that loops under the sail and through the reef grommets. I lower the main enough to pull the line and do slab/jiffy reef of the sail. I then take the excess line just created and tie the rearmost grommet of the reefing set to the boom. It is fast and easy, and gives another reason to like the mizzen.
MylesJ
MylesJ
