Re: [bolger] Re: Tender for classic yacht
On Wed, Nov 4, 2009 at 10:54 AM, adventures_in_astrophotography<jon@...>wrote:Hi Harry,
> I hadn't thought about the Diablo, how stable is for boarding by creaky
> old guys. It would be over a boarding step across the transom
The deadrise of Diablo's bilge panels makes it best to step onto the center of a thwart when boarding, in my experience. I like mine, but it's not the best boat for fishing. She's tippy once you start fighting or landing a fish, and anything left on the seats quickly winds up on the bottom of the boat. The deadrise and high freeboard could also make it awkward to reboard from a beach, although I've never tried it.
Like someone else said, it tends to blow around, and this is especially true when I'm trolling at low speed with little weight forward. The 9.9 Honda I use is not enough to plane the boat, but I can get 11 mph or so at full throttle. My problem is the high elevation where I use the boat (8600').
Diablo is a fine boat, but I think the work skiffs, with their heavy flat bottoms, would be better for boarding, fishing, and hauling pots aboard. They're also likely to pound more and be wetter. I'd like to try one sometime.
Jon
> I hadn't thought about the Diablo, how stable is for boarding by creakyThe deadrise of Diablo's bilge panels makes it best to step onto the center of a thwart when boarding, in my experience. I like mine, but it's not the best boat for fishing. She's tippy once you start fighting or landing a fish, and anything left on the seats quickly winds up on the bottom of the boat. The deadrise and high freeboard could also make it awkward to reboard from a beach, although I've never tried it.
Jon
I think the real question is to see if the pot hoist ( I interpreted the original post to be referring to lifting something like a lobster pot) will cause problems. It may be necessary to have a pad to absorb the impact of the pot on the side.
Bear in mind also that the true effect of the weight of the boat is to raise the center of gravity of the host and increse the severity of any tendency to roll.
I think also that the best approach may be to do a low cost build and replace it when the bottom abrades.
V/R
Chris
Harry James wrote:
I hadn't thought about the Diablo, how stable is for boarding by creaky old guys. It would be over a boarding step across the transom HJ Walter wrote:--- Inbolger@yahoogroups.com, Harry James<welshman@...>wrote:Anybody got any recommendations for a tender out of the Bolger repertoire for a classic 65 footer. I crew on it and may be skippering it soon. The current hard bottom zodiac with 15 hp just doesn't look right. It needs to go ashore over crappy beaches, be easy to get in and out of for old creaky folks. Having the ability to pack a pot puller and downriggers would be a plus. It goes on and off the aft cabin with a boom lift powered by hydraulics weight isn't to big an issue. It should look good. It would operate under power. My son thinks the boys launch would be the ticket, but he has wanted to build one since before being a teenager. Here is a couple of links to the host boat "Princeton Hall"http://www.dv.com/dv/magazine/2005/0105/DV0501whalesFig06.jpghttp://www.intersea.org/images/prhall.jpgI suggest Bolger's Diablo- it will run with a 15 HP motor, has a lot of reserve stability for pulling pots, fishing, etc, and you could easily reinforce the bottom for landing on rough beaches. ------------------------------------ Bolger rules!!! - NO "GO AWAY SPAMMER!" posts!!! Please! - no cursing, flaming, trolling, spamming, respamming, or flogging dead horses - stay on topic, stay on thread, punctuate, no 'Ed, thanks, Fred' posts - Pls add your comments at the TOP, SIGN your posts, and snip away - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930, Fax: (978) 282-1349 - Unsubscribe:bolger-unsubscribe@yahoogroups.com- Open discussion:bolger_coffee_lounge-subscribe@yahoogroups.comYahoo! Groups Links------------------------------------ Bolger rules!!! - NO "GO AWAY SPAMMER!" posts!!! Please! - no cursing, flaming, trolling, spamming, respamming, or flogging dead horses - stay on topic, stay on thread, punctuate, no 'Ed, thanks, Fred' posts - Pls add your comments at the TOP, SIGN your posts, and snip away - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930, Fax: (978) 282-1349 - Unsubscribe:bolger-unsubscribe@yahoogroups.com- Open discussion:bolger_coffee_lounge-subscribe@yahoogroups.comYahoo! Groups Links <*> To visit your group on the web, go to:http://groups.yahoo.com/group/bolger/<*> Your email settings: Individual Email | Traditional <*> To change settings online go to:http://groups.yahoo.com/group/bolger/join(Yahoo! ID required) <*> To change settings via email:mailto:bolger-digest@yahoogroups.commailto:bolger-fullfeatured@yahoogroups.com<*> To unsubscribe from this group, send an email to:bolger-unsubscribe@yahoogroups.com<*> Your use of Yahoo! Groups is subject to:http://docs.yahoo.com/info/terms/
We used to swim right off the transom or bow platform and I used it for flyfishing regularly. If I used better quality ply I would still be using it.
It is a light boat and has a tendency to blow around when going slow, and if alone will do some scary stuff heading into the chop if the bow is not weighted down (put the battery up front).
It is a cheap build and put good cloth with epoxy on the bottom. Perhaps 10 oz and you should be set. The 18' work skiff is much more boat in every way. Perhaps too much for the use you suggest.
--> 'You have a power boat, i suggest sweat pea, she rows nice, will
hull a load, sails sweet and will go forever with a 2 hp motor."
I have plans for a Bolger Sweet Pea but have been dragging my heels on
beginning the project because I haven't been able to figure out the
optimum way to mount my 2hp Honda.
I had been attempting to think of ways That I might modify the stern end
of the slipping keel, through hull area, to drop in the outboard as well.
Any thoughts out there on the matter?
Any one with a motor on or in a sweet pea interested in sharing their
experiences???
I may go to an alternate Bolger skiff design.
Best to all.
Mark Mirskianshin@...
To: bolger@yahoogroups.com
Sent: Mon, Nov 2, 2009 7:01 pm
Subject: Re: [bolger] Re: Tender for classic yacht
a fishermans skiff but it is only a 12 footer nice little boat though I have 2 freinds that built them use them to fish the lakes around here . I shortened a short clam skiff ( 14 feet I took it off the back end ) recently just have to get her in the water and see what she does . just a few random thoughts :)
On Mon, Nov 2, 2009 at 2:19 PM, Harry James<welshman@ptialaska. net>wrote:Shivaree has the looks but I think it is to much boat. If I remember
correctly Phil's had a 50 HP on it when I saw it at the memorial. Hope
definitely has the looks also and is much smaller.
HJ> ------------ --------- --------- ------
Peter wrote:
> Shivaree, hands down. Check with SA to see if it has enough stability for the pot puller.
> PCB designed a small fleet of powerboats in the 12 to 20 foot range. Shivaree is the last in a line of development that began in the 1950's.
> PCB had Shivaree at his dock for some years at the end of his life, and didn't see a clear way to improve it. Some of the earlier ones might be of interest. IIRC, one is Hope, which is in the book Small Boats.
> I take it for granted that you want a planning boat. A displacement boat that will fit in the designed area would be limited to 5Kts or so.
>> - Open discussion:bolger_coffee_ lounge-subscribe @yahoogroups. comYahoo! Groups Links
> - Unsubscribe:bolger-unsubscribe@ yahoogroups. com
On Mon, Nov 2, 2009 at 2:19 PM, Harry James<welshman@...>wrote:Shivaree has the looks but I think it is to much boat. If I remember
HJ> ------------------------------------
one but it is too long. Think I will order up the plans from Payson.
Good call
PAUL MCLELLAN wrote:
> You could look at the small clam skiff. It is in boats with an open
> mind and also Dynamite Paysons new book. It is a great geriatric boat
> and beaches well. The ample storage means you are always ready to go
> with you safety and fishing gear well stowed. The 15 will push it
> very well. It is an easy build and really tough to take what you can
> give it. The flat bottom is a dream to get in and out at dock, beside
> the mother craft or on the beach. With an imaginative paint job it
> could be very attractive. The lines in the drawings do not do it
> justice. regards Paul
sirdarnell wrote:
How long can it be and fit in the space available? --- Inbolger@yahoogroups.com, Harry James<welshman@...>wrote:Anybody got any recommendations for a tender out of the Bolger repertoire for a classic 65 footer. I crew on it and may be skippering it soon. The current hard bottom zodiac with 15 hp just doesn't look right. It needs to go ashore over crappy beaches, be easy to get in and out of for old creaky folks. Having the ability to pack a pot puller and downriggers would be a plus. It goes on and off the aft cabin with a boom lift powered by hydraulics weight isn't to big an issue. It should look good. It would operate under power. My son thinks the boys launch would be the ticket, but he has wanted to build one since before being a teenager. Here is a couple of links to the host boat "Princeton Hall"http://www.dv.com/dv/magazine/2005/0105/DV0501whalesFig06.jpghttp://www.intersea.org/images/prhall.jpg------------------------------------ Bolger rules!!! - NO "GO AWAY SPAMMER!" posts!!! Please! - no cursing, flaming, trolling, spamming, respamming, or flogging dead horses - stay on topic, stay on thread, punctuate, no 'Ed, thanks, Fred' posts - Pls add your comments at the TOP, SIGN your posts, and snip away - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930, Fax: (978) 282-1349 - Unsubscribe:bolger-unsubscribe@yahoogroups.com- Open discussion:bolger_coffee_lounge-subscribe@yahoogroups.comYahoo! Groups Links <*> To visit your group on the web, go to:http://groups.yahoo.com/group/bolger/<*> Your email settings: Individual Email | Traditional <*> To change settings online go to:http://groups.yahoo.com/group/bolger/join(Yahoo! ID required) <*> To change settings via email:mailto:bolger-digest@yahoogroups.commailto:bolger-fullfeatured@yahoogroups.com<*> To unsubscribe from this group, send an email to:bolger-unsubscribe@yahoogroups.com<*> Your use of Yahoo! Groups is subject to:http://docs.yahoo.com/info/terms/
