Re: [bolger] Paddlewheels
Hi Mr Butterfield
I was going through old messages on my computer and came acrost this posting
from the bolger list and thought I'd write and ask if you did the exparament
with a Bolger wheel and if so how did it work
thankyou
jeff bybee
seafox@...
or
freedem@...
thankyou
jeff bybee
seafox@...
or
freedem@...
On Mon, 24 Jul 2000 19:25:12 -0000,bolger@egroups.comwrote:
> In Boats With an Open Mind, there is an article on the Fast
> Sternwheeler. In the article, Phil mentions that he's not actually
> done a paddle wheel like this, and a "proof of concept" ought to be
> done first. He suggests using an engine from a wrecked motorcycle in
> a jon boat.
> This has been an intriguing concept to me, but of only academic
> interest. Until just recently, that is, when I received an abandoned
> motorcycle, with only 14,000 miles on it's water-cooled, 600cc engine.
> So, my intent is to build a Skimmer for the hull, doubling the bottom
> and adding an extra skid. The engine is approximately the same
> weight (100-110 lbs.) as the 10-15 hp outboard recommended. The
> sealed paddle wheel will hopefully add a bit of reserve buoyancy, if
> needed.
> Where I'm coming up empty, however, is the wheel, paddles, & rudder
> (s).
> I'm looking at a 12" wheel, for space considerations. I can
> calculate the gearing needed for that, and the transmission (integral
> to the engine) will allow me a wide range of on-the-water
> adjustability. I can only guess at the number & size of the blades,
> however. Can anyone give me some calculations to compare the blades'
> area to a propeller, and what kind of area is needed to transfer a
> given amount of power?
> Also, I'm a bit concerned about the relationship between the bottom
> of the wheel & the bottom of the boat, especially since it is
> supposed to rise up on the 1-1/2" tall skids underway. This, I think
> I'll just have to guess at, and build in an adjustment that can be
> played with on the water.
> The Fast Sternwheeler cartoon shows a multiple rudder arrangement.
> I'm a bit concerned about control with such a small immersion for the
> rudder, and the chance of tearing them off if they project down
> significantly below the hull. Also, I would like to have some kind
> of idea about the forces involved in the rudders, as they will have
> to be hanging off the end of a (relatively) long extension from the
> back of the hull.
> If anyone has any actual experience with the paddle wheel, please
> allow me to benefit from that.
> Also, if this has been done already, and been proven to not work,
> please save me from myself ;-)
> Regards,
> Ron Butterfield
Send a cool gift with your E-Card
http://www.bluemountain.com/giftcenter/
This one is better:http://www.wirefire.com/gemort/harbor/Harbor.htm
--- Inbolger@egroups.com, "Ron Butterfield" <rbutterfield@m...>
> In Boats With an Open Mind, there is an article on the Fastin
> a jon boat.abandoned
> motorcycle, with only 14,000 miles on it's water-cooled, 600ccengine.
>bottom
> and adding an extra skid. The engine is approximately the sameif
> needed.(integral
> (s).
> to the engine) will allow me a wide range of on-the-waterblades,
> however. Can anyone give me some calculations to compare theblades'
> area to a propeller, and what kind of area is needed to transfer athink
> I'll just have to guess at, and build in an adjustment that can bethe
> back of the hull.
> Regards,
> Ron Butterfield
Seehttp://www.coe.wvu.edu/~venable/asa/asa-home.htmIt's the
American Sternwheel Association. There's a link to building a
paddlewheeler.
paddlewheeler.
>bottom
> needed.(integral
> (s).
> back of the hull.
> Regards,
> Ron Butterfield
a jon boat.
needed.
(s).
back of the hull.
Ron Butterfield
a jon boat.
needed.
(s).
back of the hull.
Ron Butterfield
