Re: Lapstrake or Steel Long Micro ?
--- Inbolger@yahoogroups.com, Giuliano Girometta <ggboat1@...> wrote:
> There are good lifeboats and bad lifeboats so we can not put all in one bundle.
> Till the 50ties all the lifeboats were very well made and some with gorgeous shapes and after the ships were scraped they made even top winner sailboats.
> Then in the early 60ties they started the construction of aluminum lifeboats that were such as floating bathtubs.
> Then with the event of the fiberglass, lifeboats started again to have more gracious shapes and being more seaworthy.Â
> I see some lifeboats being barely making two or three Knots at full power while other pushing 9 Knots with the same small Lister Diesel.
> Small lifeboats (about 30 persons) are normally of a good shape, while the large ones that were installed on the big ocean liners and capable to carry a large amount of people and that were stacked on double on the davits were normally shaped like ugly barges.Â
There are good lifeboats and bad lifeboats so we can not put all in one bundle. Till the 50ties all the lifeboats were very well made and some with gorgeous shapes and after the ships were scraped they made even top winner sailboats. Then in the early 60ties they started the construction of aluminum lifeboats that were such as floating bathtubs. Then with the event of the fiberglass, lifeboats started again to have more gracious shapes and being more seaworthy. I see some lifeboats being barely making two or three Knots at full power while other pushing 9 Knots with the same small Lister Diesel. Small lifeboats (about 30 persons) are normally of a good shape, while the large ones that were installed on the big ocean liners and capable to carry a large amount of people and that were stacked on double on the davits were normally shaped like ugly barges. --- OnSun, 11/22/09, PeterMcCorison<k2spr@...>wrote:
I remember a 14' steel semi-vee utility probably made in the 1950's in Northern Wisconsin. Looked like any semi-vee aluminum utility you could get at Sears or Montgomery Ward at the time.
--- Inbolger@yahoogroups.com, Peter McCorison <k2spr@...> wrote:
> But lifeboats are designed to float until rescue eventuates, not to go
> anywhere. There are a couple of such conversions here in the San Juan
> Islands. They are slow, take lots of power, and drag the whole ocean
> after them.
> The shapes are just not designed for travel.
> - Cheers -
> Peter McCorison
> Trying to keep from getting blown away in the San Juan Islands.
> ben_2_go wrote:
> > I have seen steel life boats.There's a guy that posts on DW that owned one and converted it into a trawler type cruiser.It was the General Brock.
> >http://www.duckworksmagazine.com/02/articles/browne/index.htm
> >http://www.duckworksmagazine.com/03/r/columns/browne/08/index.htm
> > --- Inbolger@yahoogroups.com, Wilderness Voice <thewildernessvoice@> wrote:
> >> Lifeboats are designed for one thing, that is to float. I have never seen a steel lifeboat float, but in the shipyds we would have slapped together boats for the purpose of getting around ships and working. If this is a pleasure boat and meant to perform. and be fun you will be better off with lapstrake than trying to make a small boat out of steel. There are good reasons small boats arn't made out of steel for anything but work in shipyrds
> >> ________________________________
> >> From: Christopher C. Wetherill <wetherillc@>
> >> To:bolger@yahoogroups.com
> >> Sent: Fri, November 20, 2009 6:23:12 AM
> >> Subject: Re: [bolger] Re: Lapstrake or Steel Long Micro ?
> >> There are also a myriad of steel lifeboats on
> >> ships.
> >> One serious practical limitation is that with steel or aluminum
> >> construction, one must include sealed void space for flotation. This
> >> is not available for stowage or other use. It detracts seriously from
> >> the utility of a small hull.
> >> V/R
> >> Chris
> >> Gene Tehansky wrote:
> >>> Col Hassler is made in steel. I think thats the name.
> >>> Gene T.
> >>> On 20 Nov, 2009, at 4:39 AM, robertsmme wrote:
> >>> Hi,
> >>>>>> Phil designed a steel small boat to cross the Atlantic in - I think the
> >>>> design is called the OSTAR. I can not find it on the web, but I know it
> >>>> had interesting things like a cycle to generate electricity.
> >>>>>> It had a stepped hull so you could walk the length of the boat without
> >>>> bending.
> >>>>>> Martin
> > - no cursing, flaming, trolling, spamming, respamming, or flogging dead horses
> > - Plans: Mr. Philip C. Bolger, P.O. Box 1209, Gloucester, MA, 01930, Fax: (978) 282-1349
> > - Open discussion:bolger_coffee_lounge-subscribe@yahoogroups.comYahoo! Groups Links
after them.
- Cheers -
Peter McCorison
> --- Inbolger@yahoogroups.com, Wilderness Voice <thewildernessvoice@...> wrote:
>> From: Christopher C. Wetherill <wetherillc@...>
>> ships.
>> V/R
>> Chris
>>> Gene T.
>>> Hi,
>>>> bending.
>>>>>> Martin
> ships.
> V/R
> Chris
> >Gene T.
> >Hi,
> >>bending.
> >>>>Martin
Sent:Fri, November 20, 2009 6:23:12 AM
Subject:Re: [bolger] Re: Lapstrake or Steel Long Micro ?
ships.
V/R
Chris
Col Hassler is made in steel. I think thats the name.Gene T.On 20 Nov, 2009, at 4:39 AM, robertsmme wrote:Hi,
Phil designed a steel small boat to cross the Atlantic in - I think the design is called the OSTAR. I can not find it on the web, but I know it had interesting things like a cycle to generate electricity.
It had a stepped hull so you could walk the length of the boat without bending.
Martin
One serious practical limitation is that with steel or aluminum construction, one must include sealed void space for flotation. This is not available for stowage or other use. It detracts seriously from the utility of a small hull.
V/R
Chris
Martin
>Doug - I believe you are right, plywood does limit the shapes possible in boats, especially when used in large sheets. But with the Chebacco, one of the boats under discussion, performance is virtually identical between all 3 construction methods. This fact was told to me by Phil, who seemed a little surprised by it. Different hull shapes will probably be affected more or less when built using different construction methods. All I'm saying is that in this boat, Chebacco, no real differences in performance were noted by Phil himself.
> Walter wrote:
> > --- Inbolger@yahoogroups.com<mailto:bolger%40yahoogroups.com>,
> > Douglas Pollard <dougpol1@> wrote:
> > > Chebaco is a well designed boat for plywood and the fact that it cannot
> > > be formed into compound curves. If you want to build from lapstrake
> > > there are many designes with much finer shapes that can be built that
> > > way. Bolger has some of those designs though many are in his older
> > work.
> > > His later work is no better than the older designs except that the new
> > > stuff is designed for ease of construction in plywood. That ease of
> > > construction is gone when you build from lap planking or strip planking
> > > so why not build the finer hull. Its no harder if you are strip
> > > building. If you are going to strip plank build one of the really
> > > beautiful and sea kindly designs that are available. The plywood
> > designs
> > > for easy construction and as such are compromises in shape. Build the
> > > perfect shape instead. Doug
> > Chebacco was originally designed for cold molded construction- see
> > "Boats with an Open Mind ", p.223. Then plywood, then lapstrake. Boats
> > built using all three construction methods have been sailed together,
> > with no real difference noted between them . So the "penalty" of
> > limited shape for sheet plywood construction is non-existent, at least
> > for this design. Cold molded construction is an excellent way to use
> > wood of less than prime marine quality,as it is encapsulated in epoxy.
> > If you can get the epoxy in Peru, and get the available wood sawed
> > into veneers, this might be a good way to go.
> Walter, I have to disagree. Plywood can make a really fine boat but
> unless you get into things like tortured shapes, they are not perfect. A
> boat built of molded plywood if designed to take advantage of the
> material can be a much finer shaped boat. Speed is not the only measure
> of a fine boat there is, sea kindliness ease of handling.
> Bolger designed an aluminum boat for me and he lamented the fact that we
> could bend only very limited compound curves into the hull. In his words
> she would be a faster boat if we could develop more roundness in her
> bottom astern. If we could round her bottom more in her bows she would
> have a finer entry. That is what P.Bolger thought. Maybe he changed his
> mind later???
> If the cold molded hull was made to the best that can be done with the
> material she would be a far better boat than a plywood one. IF not, it
> is only because full advantage of the material was not taken. A good
> cold molded boat is a different boat than a plywood one in shape, even
> if by the same name. After saying this I really like the look and feel
> of a hard chine boat. The softly rounded hull to my eye lacks the
> character of a gently curving chine and sheer to match of a planked hull
> and is often copied in most plywood hulls.
> In my opinion it's not the material that matters but the shape than can
> be generated in it. Doug
Walter
Hi,
Martin
Martin
Caloosarat
> I live in Iquitos, Peru a few miles from the Amazon River and I´m interested in building a Long Micro.
> The plywood available here is not suitable for boat construction. It separate easily and it is expensive.
> That leaves lapstrake or a steel hull. Wood and steel are both cheap.
> What would the increased weight do to the performance of a Micro or Long Micro?
> Does anyone know of any Micros or Long Micros that have been built with a lapstrake or steel hull?
> Thanks
> tom
> work.
> designs
mind later???
>Chebacco was originally designed for cold molded construction- see "Boats with an Open Mind ", p.223. Then plywood, then lapstrake. Boats built using all three construction methods have been sailed together, with no real difference noted between them . So the "penalty" of limited shape for sheet plywood construction is non-existent, at least for this design. Cold molded construction is an excellent way to use wood of less than prime marine quality,as it is encapsulated in epoxy. If you can get the epoxy in Peru, and get the available wood sawed into veneers, this might be a good way to go.
> way. Bolger has some of those designs though many are in his older work.
> beautiful and sea kindly designs that are available. The plywood designs
steel. I seemed to remember it had a stepped hull like the Micro Trawler.
Martin
> I would discourage you from thinking about a steel hull. By the time
> it had enough internal bracing that it stay in shape, it would be far
> too heavy. Boats less than about 50 feet can be built from steel, but
> only if the heavy construction is planned from the beginning of the
> design.
> On the other hand, lapstrake is a very good alternative, but I think
> it would work better for a boat with a round shape rather than the
> boxy shape of Long Micro. You would have to ask someone more
> experienced that me if you do build LM in lapstrake.
> Be aware that there are two categories of lapstrake. The traditional
> one uses some kind of nail or rivet to fasten the laps. The modern one
> uses epoxy glue. Since the epoxy makes a stiffer boat, the internal
> framing is reduced a little, so if the designer calls for glued laps,
> it's best to stick to it. If the designer calls for rivets or clench
> nails, you can glue if you want to.
> You might look into strip construction, too.
> Mr. Bolger designed the Chebacco and the 26' big Chebacco for
> lapstrake construction. The bigger boat has accommodations similar to
> Long Micro. They both use a cat-yawl rig. These boats both use plywood
> for frames, seats, etc. I don't know if they would work for you or not.
> In fact, all most all modern designs use some plywood. I'm sure there
> are ways for you to work around that, but it may be frustrating.
> Peter
> That leaves lapstrake or a steel hull.I would discourage you from thinking about a steel hull. By the time it had enough internal bracing that it stay in shape, it would be far too heavy. Boats less than about 50 feet can be built from steel, but only if the heavy construction is planned from the beginning of the design.
On the other hand, lapstrake is a very good alternative, but I think it would work better for a boat with a round shape rather than the boxy shape of Long Micro. You would have to ask someone more experienced that me if you do build LM in lapstrake.
Be aware that there are two categories of lapstrake. The traditional one uses some kind of nail or rivet to fasten the laps. The modern one uses epoxy glue. Since the epoxy makes a stiffer boat, the internal framing is reduced a little, so if the designer calls for glued laps, it's best to stick to it. If the designer calls for rivets or clench nails, you can glue if you want to.
Mr. Bolger designed the Chebacco and the 26' big Chebacco for lapstrake construction. The bigger boat has accommodations similar to Long Micro. They both use a cat-yawl rig. These boats both use plywood for frames, seats, etc. I don't know if they would work for you or not.
In fact, all most all modern designs use some plywood. I'm sure there are ways for you to work around that, but it may be frustrating.
I'm thinking a Becky Thatcher would be great for some of the areas
shown. But maybe just too hot and humid to do much pedaling.
interested in building...
> I imagine that there is some nice wood there suitable for
> boatbuilding. I am curious what types of wood to boat builders use.
> Also, what is the Amazon River like in Peru, current speed, depth and
> the prevailing wind, etc.. And also, I am curious what kind of boats
> were traditionally used in that region, for fishing? or for
> transportation?
> Is there a reason that you are choosing a sailboat?
> I see that the flag of Iquitos has, could it be, pictures of boats on
it?
>http://peru-facts.co.uk/Images/iquitos%20flag.jpg
>http://en.wikipedia.org/wiki/Iquitos
>http://images.google.com/images?q=Iquitos%20boat
> I live in Iquitos, Peru a few miles from the Amazon River and I´m interested in building...
transportation?
I see that the flag of Iquitos has, could it be, pictures of boats on it?
Thanks
tom
